Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electronics & Connectivity > Audio, Video & TV
Old 02-07-2010, 12:37 PM   #1
1957 22' Flying Cloud
chipley , Florida
Bedroom Cable Problems
I have a 2005 25' Safari. The cable in the bedroom doesn't work. It has been checked and the cable is bad. Can the cable easily be replaced? Any suggestions?
marieffa is offline   Reply With Quote
Old 02-07-2010, 03:39 PM   #2
chipley , Florida
bedroom cable
This the tv cable in bed room. can it be replaced without taking camper apart? thanks.
Old 02-07-2010, 05:50 PM   #3
Cantrell's Avatar
1985 34' Limited
1960 24' Tradewind
Summerville , South Carolina
How can the cable in a 5 year old trailer be bad? Is it possible that only the end connections are bad and could be replaced? How have you determined the cable is bad?
Don't know how it is routed through the trailer on the newer models but if you can access both ends of the bad cable, you could attach a new piece of cable to the old piece and try to pull the new one into place using the same path the old one lived in. It would be critical to have as smooth a connection (to prevent it from getting snagged on obstructions in the wall) and a really solid connection that won't come apart with all your tugging. Some cable has housing on it that is more flexible than others--you don't want it anymore rigid than necessary.
Sure hope someone else more familiar with the layout of a 2005 Safari chimes in and offers a better solution because mine is a last resort option and the chances for failure are high.
Bill Cantrell
AIR 24338
TAC SC-1
__________________________________________________
Easily distracted by shiny objects.
Cantrell is offline   Reply With Quote
Old 02-07-2010, 06:56 PM   #4
chipley , Florida
we checked all connections & found ok. we moved cable on junction box to other legs still no go. run cable from juction box on flour & tv worked. ohmed cable & found open. don't know if it ever worked since we bought camper used & just now tried tv in bedroom. the cable is tied on both ends, but don't know if is clamped somewhere in route. I would like to put new cable on & pull . thanks.
Old 02-07-2010, 07:07 PM   #5
moderator
Airslide's Avatar
2016 27' International
Wilton , California
Images: 50
Hi.. welcome to the forums..
I had a bad cable in mine too. Not sure how your cable is run but mine was located in the rear curbside fresh water hookup cabinent. I pulled everything apart only to find that it was pretty easy to get that cable through without pulling everything apart.. I will try to find the link to some pictures I posted..
Vin
"Old fashioned service on your late model Airstream"
https://www.facebook.com/VinniesNort...ir?ref=tn_tnmn
Airslide is offline   Reply With Quote
Old 02-07-2010, 07:11 PM   #6
moderator
Airslide's Avatar
Wilton , California
Images: 50
Could be a completely different setup in yours.. but heres the link to what I did.
http://www.airforums.com/forums/f447...-tv-57588.html
Vinnie
Old 02-07-2010, 07:14 PM   #7
chipley , Florida
Thanks,mine is on street side & it appears to run toward back of camper,don't know if runs around back of camper or not. the junction box is on curb side in front of camper. there is a leg for the cable connection. don't know if it picks up with it or not . book shows seperate cables.
Thanks.
Old 02-07-2010, 07:16 PM   #8
moderator
Airslide's Avatar
Wilton , California
Images: 50
Hang in there.. someone here probably has the answer...
Good luck..
Vin
Rear bedroom in 20' or 24'? crispy13 Argosy Motorhomes 2 08-26-2009 03:38 AM
JC With Problems, Same Problems Goin Home ncbambi 2008 Safari SE 3 06-23-2009 09:44 PM
bedroom redo otek800 Repairing/Replacing Floor &/or Frame 2 05-10-2009 09:09 AM
I need help in the bedroom! Minnie's Mate General Interior Topics 32 08-24-2008 12:35 AM
Bedroom Conversion desmits General Interior Topics 9 01-01-2008 07:07 AM
