Old 11-19-2007, 01:15 AM   #1
1974 25' Tradewind
Muscle Shoals , Alabama
Antenna help
The gear drive that raises my TV antenna on my 74 Tradewind got broken and now my antenna will not raise. I am looking to update my antenna for HD. Does anyone here have any suggestions for a good replacement? Also, how difficult would replacing the entire antenna assembly be? The one I had had gotten incredibly difficult to crank up and I guess that is how it got broken. I jsut really think I need to update from 33 year old technology. Any suggestions would be greatly appreciated.
Thanks!
chuman70 is offline   Reply With Quote
Old 11-19-2007, 04:22 AM   #2
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
You can still buy parts for your old antenna if you want to keep it. We have a similar problem, have the parts but haven't dove into taking the antenna off the trailer to repair it. This link is similar to the parts we needed - not sure if you need a different kit....
RV Parts, RV, Mobile Homes, Mobile Home Parts : RV Antenna Parts : Worm Gear Kit
Old 11-19-2007, 05:32 AM   #3
1974 25' Tradewind
That looks like my part, but I think I want to upgrade the whole assembly to a new amplified antenna. How involved would it be to change that out?
Old 11-19-2007, 06:18 AM   #4
Liberator
klattu's Avatar
1972 Argosy 24
1989 34.5' Airstream 345
Heart of Dixie , Alabama
Images: 834
Going Batty
Get a bat wing type.
The amp is down at base plate and needs 12v.
Only a coax cable runs to roof.
Check for corroded<sp tip, if needed trim cable back and remake end.
Hole size could be different, but easy to make up a spacer plate.
Seal it all up, pop rivits too.
DO NOT get the omni type
Your opinion is valued, please not your opinion of someones else's opinion.
Click To See Me Wet
1989 Airstream 345 Liberator...
1972 Argosy 24'...
1954 Feathercraft Vagabond
klattu is offline   Reply With Quote
Old 11-19-2007, 07:04 AM   #5
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
You do not need a special antenna for HD. Amplifiers can help sometimes but can also introduce noise. If you gota have one, get one that can be switched off.
Ahab is offline   Reply With Quote
Old 11-19-2007, 07:31 AM   #6
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
We put new cable-type ends on our original antenna & it works great with our HD flatscreen. I had a '76 before our '86 where the antenna gear stripped. I got new gears from South Jersey RV & replaced them (not too difficult) and she went up & down fine after that. The '86 has the same antenna as the '76.
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 11-19-2007, 07:56 AM   #7
1974 25' Tradewind
What is the "omni" type? I would like to get a batwing as it seems that most of the people I have talked to have had good luck with those. Aren't they the ones made by Winegard? I want to make sure I get the best i can get. Any suggestions?
Old 11-19-2007, 09:45 AM   #8
More than one rivet loose
thecatsandi's Avatar
Los Alamos , New Mexico
You current antenna will work for HD. Maybe not as well as a new one but it will work. If you get a new one get the Winegard Batwing.
Michelle TAC MT-0
Sarah, Snowball
thecatsandi is offline   Reply With Quote
FM antenna Phil Gobie Electrical - Systems, Generators, Batteries & Solar 6 12-24-2006 11:28 AM
antenna on '61 heavyduty 1960 - 1964 Overlander 9 04-26-2005 02:11 PM
CB Antenna wyhjr Electrical - Systems, Generators, Batteries & Solar 14 05-02-2004 01:12 PM
cb antenna norbert Our Community 12 06-19-2003 09:57 PM
TV antenna davidz71 Audio, Video & TV 14 03-14-2003 08:14 PM
