Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > General Appliance Topics
Old 10-01-2002, 09:30 AM   #1
Oak
Profile:  1986 Argosy
Appleton , Maine
Wiring & Plumbing diagrams - '86 Argosy
I think I just bought (made an offer) a 1986 Argosy. Does anyone know how I can come up with wiring and plumbing diagrams? I will also have to replace a piece of floor in front of the door due to moisture getting at it and making it soft and spongy. I am assured that the previous owners had show dogs and that is where the water bowl for the dogs was, as opposed to a leak. Anyway, I will need to replace about 4 square feet of floor and probably all of the linoleum.
Any help for this newbie is greatly appreciated!
Oak
Oak is offline   Reply With Quote
Old 10-01-2002, 09:32 AM   #2
Oak
Appleton , Maine
addendum to above
In reference to the above 1986 Argosy, it is a 29' model.
Thanks again, Oak.
Old 10-01-2002, 10:07 AM   #3
BobbyW's Avatar
Profile:  1965 20' Globetrotter
Houston , Texas
Door leaks are very common, especially on older trailers as the weather stripping fails. Windows also. I would check the ENTIRE floor, particularly under the water heater, water tank, access doors, under the bath area....
Replacing flooring is a major project. Really hard if it goes under the built in furnishing. Get a deduct on the price you are paying for this, if possible.
Owning sloppy drinking Boxers all my life (7 todate), all house dogs, I cannot imagine dog bowls causing a rotten floor. I smell smoke.
-BobbyWright
-BobbyW AIR# 123
-Guess what? I got a fever! And the only prescription.. is more cowbell!
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."
-Red Green
www.bobbywright.com/gallery
BobbyW is offline   Reply With Quote
Old 10-01-2002, 07:10 PM   #4
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
Airstream Registry
As far as the diagrams & manuals, they should be available from:
Helen Davis
Secretarial Services
PO Box 484
Sidney, OH 45365
(937) 492-8885
Good luck on whatever you decide to do...keep us posted!
Shari
[IMG] code is Off
1991 60th anniversary Airstream 120 volt wiring diagrams ron barrow Electrical - Systems, Generators, Batteries & Solar 5 07-20-2009 07:03 AM
Wiring and Plumbing Question LittleA General Repair Forum 0 04-12-2009 07:00 PM
Umbilical Wiring Diagrams thenewkid64 Towing, Tow Vehicles & Hitches 16 03-31-2009 12:03 AM
Plumbing Diagrams for 27' 1970 Overlander Patsyj1 Fresh Water Systems 4 05-23-2008 02:31 PM
frame and wiring diagrams B Stover Electrical - Systems, Generators, Batteries & Solar 0 08-16-2005 05:48 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
