Old 10-08-2012, 04:28 PM   #1
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Hot Water Bypass
I have had this Atwood hot water heater in my 71 Tradewind for a few years. I'm no plumber. I would appreciate any advice on installing a hot water bypass. Obviously I am going to have to do a little replumbing. A plastic section was added when I had the Atwood installed. otherwisee, the plumbing is the original copper.
Note: 3rd photo should be rotated 90 degrees. The last photo is the bypass I just bought
ID:	169833   Click image for larger version
ID:	169837   Click image for larger version
Old 10-08-2012, 07:22 PM   #2
Splitrock's Avatar
Sioux Falls , South Dakota
I just made my own.
Looks like this . . .
http://www.airforums.com/forums/blog...0&d=1310436203
I wanted to located it where it's easy to access with the toilet installed.
Good luck with your project.
Old 10-08-2012, 09:21 PM   #3
Lumatic's Avatar
1993 34' Excella
Images: 16
Originally Posted by Splitrock View Post
I just made my own.
Very pretty install. Thanks
Old 10-08-2012, 09:43 PM   #4
Lumatic's Avatar
1993 34' Excella
Images: 16
What is the best material or system to splice into the existing copper water lines?
Old 10-09-2012, 05:57 PM   #5
Splitrock's Avatar
My trailer had been allowed to freeze up by the previous owner. That left many of the copper pipes expanded so new copper parts and even sharkbite connectors won't fit. If the copper isn't expanded, then there are several good choices to splice in. Where my copper was expanded I attached the pex with braided nylon tube and ratchet clamps.
Where the copper wasn't expanded I just used sharkbite fittings. Just push em on and go.
