Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > General Appliance Topics
Old 10-22-2014, 04:06 PM   #1
Mossyrock's Avatar
1992 29' Excella
Mossyrock , Washington
Talking '92 29' Excella - monitor wiring
I sure hope you can justify my purchase of a Benzomatic soldering tool yesterday at Home Depot! So, I was checking my monitor closely after draining black and gray tanks because it always shows them more full than they are. If you can tell me of an adjustment to the monitor for that (I know they are totally empty and they still show 1/4 full on monitor) that would be great BUT....
What I really am writing about is a blue wire that has come unattached from the back of the panel. I've just tried to add two photos - not sure if that worked. The wire is light blue and seems to have come unattached from a spot about one inch to the right of a Phillips-head screw located at the bottom center of the green panel-board. If you can verify that that is the right spot I will use that Benzo-solderer to reattach...hopefully with no bad results. By the way...that wire doesn't seem to make any change to the reading I get so if you can tell me what it does that would be appreciated. Tim L
ID:	224937   Click image for larger version
Mossyrock is offline   Reply With Quote
Old 10-22-2014, 10:00 PM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Can you get a clearer picture of the spot where you expect to 'reattach' that wire.
BTW, too much heat can damage the board... so, it is helpful to 'tin' the wire you plan to solder to the board FIRST. Then you will be able to place the wire onto the spot and place the 'heat' of the soldering iron on the wire....as heat transfers through the 'tinned' wire, it will easily transfer the heat to the spot you have chosen. Once you see the solder begin to 'flow', remove the heat while holding the wire in place... using some needle nose pliers keeps your flesh from cooking.
Peace and Blessings..
Channing
WBCCI# 30676
Monitor panel/board for 89' Excella BillTex Waste Systems, Tanks & Totes 1 10-06-2019 06:52 PM
wiring at monitor panel Walkabout6 Electrical - Systems, Generators, Batteries & Solar 1 04-10-2013 11:14 PM
Does the Micropulse Monitor Panel Monitor LP? KJRitchie LP Gas, Piping, Tanks & Regulators 5 03-21-2013 02:20 PM
Monitor panel '89 Excella BillTex General Repair Forum 9 09-26-2007 03:40 PM
