Old 07-15-2007, 03:04 PM   #1
Devils Lake , North Dakota
Question Wfco 9865
I pulled the UniVolt from my Argosy and have purchased the 9865.
After reviewing the manual I see that I am going to need to fabricate or buy a small buss bar/box to distribute the load. (old panel is with Univolt).
It is a simple buss with 6 lugs. 2 go to the battery and there are 4 DC circuits.
Where can I find a small unit?? Everything I see has a dozen or more lugs and way to "fancy" than I need.
Also, I don't see a seperate circuit for the battery.......... How is the battery charged by the WFCO??
As usual...... Thanks for the great advise.
Sundance is offline   Reply With Quote
Old 07-15-2007, 03:23 PM   #2
After browsing ebay I came across this. It has one input and 4 outputs.
Any reason this would not work??
eBay: Tsunami FDB1004-MANL (4) Pos Digital Distribution Block (item 250143380812 end time Jul-22-07 12:38:03 PDT)
Old 07-15-2007, 03:32 PM   #3
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
That's alot of bling with a price tag to match.
It will work, but you can do more for less money.
Tom
Old 07-15-2007, 03:42 PM   #4
Please elaborate Tom......... cheap is my middle name.......
Old 07-15-2007, 03:53 PM   #5
New Borockton , Alabama
Images: 21
This is what you need. The 9 position is $36. Look at the 2nd page of that pdf and it shows a typical installation for a deck mount converter and fuse block. Let me know if you need help.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp, Smartplug, AGM Batts
888-828-1893
Bestconverter.com
Old 07-15-2007, 04:28 PM   #6
That is fantastic Overlander........ WFCO could learn from that.
Old 07-15-2007, 05:27 PM   #7
2017 27' Flying Cloud
Altoona , Florida
Wink Thrifty is good
Go to your local "pull it your self" automotive salvage yard. probally a buck or two
Poprivet is offline   Reply With Quote
Old 07-15-2007, 06:33 PM   #8
Images: 21
They probably have no interest in producing one. We are their largest distributor and it's never even come up. The Parallax boards are very popular for Airstream owners upgrading the Univolt but by no means the only option. Some of the other manufactures we've talked to have similar boards but they are not popular like the FB9 so we don't want them sitting on the shelf.
The problem with converters today is that nobody produces one that is similar in design with ONLY the DC distribution connected to it. All of the power centers include AC and DC and are not deck mounts but rather wall mounts.
A good example for a deck mount even more popular than the Univolt is the old 3200 series Parallax found in 10s of thousands of old RVs like the Univolt in Airstream. Some had fuse boards on the end and some did not. If it did and your need to replace it, you have to purchase the fuse board separate and mount it on the wall next to it and run the old wires to it. Not a big deal either.
888-828-1893
Bestconverter.com
Old 07-15-2007, 07:23 PM   #9
The WFCO is a deck mount as well. I do like the car junk yard idea.......
Thanks all!!
The fulltiming adventure begins overlander63 Full-Timing 974 01-03-2023 11:55 AM
Got 3-stage charging yet? 68 Overlander Commercial Listings 76 09-09-2012 11:54 AM
Converter failure story guy99 Electrical - Systems, Generators, Batteries & Solar 10 01-31-2007 11:49 AM
wfco 9800? rama777 Electrical - Systems, Generators, Batteries & Solar 6 10-02-2006 10:14 PM
Electrical all over again Melody Ranch Electrical - Systems, Generators, Batteries & Solar 6 04-17-2006 10:34 PM
