Old 11-08-2009, 05:26 AM   #1
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana , Pennsylvania
Marinco Electrical Connection
Has anyone installed the marinco electrical inlet on their Airstream. If so, is there a junction box between the outlet and main circuit breaker where you tie in? I'd like to make a clean electrical connection. Should I stay with the 30 amp? Any thoughts would be appreciated. Thanks!
Roadrunner is offline   Reply With Quote
Old 11-08-2009, 07:37 AM   #2
Images: 59
I don't think there should be a junction box, but I'm not familiar with the '78 Ambassador.
If you put in a 50a inlet you will need more room to mount the inlet, heavier wire to the main breaker, and the fittings are more expensive. But you can run everything at once.
Name:	Elec Inlet 003.jpg
Old 11-08-2009, 08:34 AM   #3
toastie's Avatar
1955 22' Safari
Great Lake State , .
I'm hooking up my Marinco today and finding out what a pain to run 30 amp wire from Marinco to breaker box, the pain is at the Marinco end, would you have any pictures of your hookup.
Toastie
toastie is offline   Reply With Quote
Old 11-08-2009, 09:43 AM   #4
Images: 59
I added a 4x4 extension box to provide enough space behind the receptacle to turn the wires and head them up through 3/4" plastic conduit. I believe I used #6 Stranded THHN, mine is a 50a though, you could use #10AWG for a 30a.
Here's a closeup of the box, and a wider view with the box at top center.
Name:	Elec Inlet 006.jpg
ID:	90541   Click image for larger version
Name:	Elec Inlet 008.jpg
Old 11-08-2009, 10:04 AM   #5
toastie's Avatar
1955 22' Safari
Smart, very smart.............thanks
Old 08-02-2016, 09:04 AM   #6
albert's Avatar
1970 29' Ambassador
1959 22' Flying Cloud
1957 26' Overlander
Ashland , Oregon
Send a message via AIM to albert Send a message via Yahoo to albert
Can someone tell me what type of wire I buy to run from a Marineco inlet to the breaker box... 30amp? AND, is it OK to run it from the street side rear to the curb side middle where I have my breaker box? Does distance matter for this?
LASTLY! what wire do I run from breaker box to 12v batteries?
Thanks in advance!
albert is offline   Reply With Quote
Old 08-02-2016, 09:18 AM   #7
A W Warn's Avatar
2000 25' Safari
Originally Posted by albert View Post
>> snip <<
Thanks in advance!
DO NOT run any wire from the breaker box to a 12v battery. It might explode.
120v goes from the breaker to the converter (actually to a receptacle near the converter where the converter is plugged in)
12v comes out of the converter and goes to the battery.
Get someone to help you!!!
Alan
Old 08-02-2016, 09:39 AM   #8
albert's Avatar
1970 29' Ambassador
1957 26' Overlander
Ashland , Oregon
Oops! sorry, I knew that but didnt type it correct. I do have someone coming to help, but wanted to learn on my own as well.
Do you know what gauge or type of wire I use for that connection?
Old 08-02-2016, 10:16 AM   #9
Naples , Florida
Airstream, along with many other RV manufacturers use ROMEX for all basic wiring.
I NEVER USE ROMEX, as I wire to ABYC marine standards ( as RVs should) and use 6 AWG marine cable for 50 amp AC circuits, 10 AWG for 30 amp AC circuits and 12 AWG for most 12 VDC circuits.
Cables from the batteries to your fuse block depend on the circuit length and carrying capacity that you require.
Lew Farber
lewster
Old 08-02-2016, 10:44 AM   #10
Hittenstiehl's Avatar
1962 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
Small Hijack:
Lewster,
Could you please compile all your posts on this forum into one thread so we stand a better chance of finding all these hints when we're ready for this project.
Your handout from Vintage Trailer Academy is so scribbled full of side notes from us we'll be lucky to ever figure if out.
End hijack.
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Old 08-02-2016, 11:06 AM   #11
Wise Elder
Jammer's Avatar
2010 30' Classic
I've been using armored cable for 120v circuits, particularly where exposed to possible damage or when going through holes in aluminum.
Old 08-02-2016, 09:20 PM   #12
Naples , Florida
After working on many large RVs with 50 amp service and that nasty, semi-solid THHN 'stranded' 6AWG cable (it is usually comprised 7 large strands, vs. several hundred 30AWG strands found in marine grade cable) over the last 16 years, the flexibility and ease of bending and working quality marine cable far outweighs any cost savings for big-box wire purchases.
I run thru thousands of feet of cable a year and would never dream of using anything but fine, multi-strand marine cable or similar welding cable.
lewster
Old 08-02-2016, 09:42 PM   #13
albert's Avatar
1970 29' Ambassador
1957 26' Overlander
Ashland , Oregon
Where does one find this amazing wire?
Old 08-02-2016, 10:44 PM   #14
Naples , Florida
Google 'marine cable' and many sources will pop up. West Marine is one, Waytek Wire another, Lawrence Marine Products another Ancor Products yet another.....there are many.
Your difficulty might be in buying less than full roll quantities. I have seen many sites that do sell marine wire by the foot in a variety of sizes.
I'm sure you will find pages full of sources.
lewster
Old 08-03-2016, 03:52 AM   #15
Dingo Girl's Avatar
1967 17' Caravel
Oak Creek , Colorado
Lewster recommended the marine grade wire for my restore. It is so nice to work with!
You won't be sorry.
Dingo Girl is offline   Reply With Quote
Old 09-11-2017, 09:19 AM   #16
baltimore , Maryland
Lew Farber
Hey Lew,
I plan on using Prestolite cables to rewire my 63. Have you ever used them? They are what the military use in their vehicles.
http://search.store.yahoo.net/yhst-5...500.1504408284
mane3215 is offline   Reply With Quote
What is advantage of Marinco type power inlet? SilverHoot Electrical - Systems, Generators, Batteries & Solar 5 07-15-2009 12:58 PM
Are Marinco and Hubbell interchangable? pauly g Electrical - Systems, Generators, Batteries & Solar 2 03-16-2008 06:53 PM
failed electrical connection on brakes on one side only Tin Diesel Brakes & Brake Controllers 3 04-20-2006 02:02 PM
Flush out connection JLD Waste Systems, Tanks & Totes 2 01-04-2003 09:06 PM
Wi-Fi connection? Krazykraut Airstream Motorhome Forums 8 11-25-2002 11:46 AM
