Old 06-07-2018, 02:38 PM   #1
1997 25' Safari
mastic beach , New York
Leave converter on while pluggged to shore?
The title is the question. I also saw this same question but the answer is buried somewhere, probably under a " boiled battery"!
Between the constant humm n cost, possibly 2/3s cheaper than LI, NY rates, but still.
Is it ok to turn off the converter without damaging anything?
Thanks...
Mike
Quote: "I'M AGAINST THE MAN WHO SKINS THE LAND"
Teddy Roosevelt
pond is offline   Reply With Quote
Old 06-07-2018, 02:42 PM   #2
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
If you are asking about turning the converter off while in storage I think the answer is that the batteries will discharge and go very dead.
On the other hand if you have a stock converter then I think if you leave the converter on all the time the batteries will overcharge and go very dead.
One way to deal with storage is to put either the converter or the whole trailer on a timer so that the converter is only on for a few hours a week to keep the batteries charged.
And put in 4 stage converter if you have not already done so
Old 06-07-2018, 03:28 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
If you have a multi stage convertor it is safe to leave the convertor on all the time. Since Airstream does not install multi stage you will want to check if it has been replaced.
If not just turn the battery isolation switch off when in storage.
I installed a switch inline with the convertor supply that has a light in the switch to indicate when the convertor is off. That way if you enter the trailer while in storage you could have lights by just turning on the switch and working off the convertor.
2004 Excursion 4x4
Old 06-08-2018, 06:57 AM   #4
1997 25' Safari
Oops....I did leave out the fact Im living in for a few months while with full hookups.
The converter is a MagneTek series 900, model 950.
The label states it has "integral overload protection". It looks like the original one.
Thanks for the inspiration to read that!
So leaving the trailer plugged into shore power with the converter off, could that cause damage anywhere in the system?
The AS is a 1997 25' Safari. Thanks,
Mike
Teddy Roosevelt
Old 06-08-2018, 07:05 AM   #5
fran&frank's Avatar
2016 27' Flying Cloud
Hartsburg , Missouri
One solution is to install a battery disconnect switch at the battery so when it is off there is no parasitic drains on your battery when in storage. If you make sure your batteries are fully charged and disconnect them they should be OK for months when in storage. Also just to get terminology straight, a convertor provides 12 volt power to your trailer 12 volt circuits, a charger charges the battery. Airstreams come with a combination converter/charger and some with a separate invertor for AC power. Some people upgrade to a better multistage convertor/charger while others who are doing more substantial electrical upgrades go to an invertor/charger and eliminate the converter component all together --Frank
Frank & Fran
2016 27' FC FB with 600 W solar
2016 Ford F150 EcoBoost
Equalizer Hitch
fran&frank is offline   Reply With Quote
Old 06-08-2018, 08:41 AM   #6
A W Warn's Avatar
2000 25' Safari
Davidson County , NC Highlands County, FL
If the converter is functioning properly, it is safe to and you should, leave it on while you are using the trailer, since you discharging the battery continuously using lights, fridge, fans, etc.
The key to not damaging the battery is:
1. make sure the electrolyte (water/acid) level in the battery is not low. If the top of the plates get exposed to air it will create corrosion permanently damaging the battery.
2. make sure the output of the converter is not too high or too low. There is a placard on the converter giving the output rating. (mine started outputting higher voltage before I replaced it)
Mike
Alan
Old 06-08-2018, 09:01 AM   #7
Mollysdad's Avatar
My plan is to leave the trailer unplugged.
Then I have a NoCo Genius 3500 into a permanent connector (NoCo to ring terminals on the batteries) and use the trickle charger while the trailer is in storage. Instead of the shore power cord, I have an extension cord to the battery box.
I have the luxury of power at the storage yard. If I didn't, I'd install a battery disconnect, then leave the batteries off. (or take them home over a long sit)
Old 06-08-2018, 11:32 AM   #8
2017 25' International
Framingham , Massachusetts
Thanks...
Mike
If you don’t have your converter on, then all your 12v items won’t work. So, unless you’ve installed other (110v) lighting and fans etc, your converter HAS to be on. The question that is usually asked it whether to leave the batteries connected to the converter or not to avoid possible overcharging.
quietguy is offline   Reply With Quote
Old 06-08-2018, 12:11 PM   #9
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
We get really confused really quickly between converters that went in back in the 1950's and stuff that comes stock in 2018. If you go back 20 years, you are indeed in a bit of a limbo land. You don't have an antique, but you do have something that likely has served out it's useful life. With brand new converters costing around $200 or so .... just replace it after 20 years.
Old 06-08-2018, 01:36 PM   #10
1973 31' Sovereign
1978 Argosy 30
1985 31' Excella
Sacramento , California
Ahhhh Hmmmm... well.... indeed a battery disconnect swtich is nice.. but just make sure everything is OFF... will work too... that being said.. instead of going around and turning everything off the switch takes care of that in one motion... My trailer came with it...
As to bats lasting through storage times... attt wrong answer... sure if you charge them up.. they are going to last longer.. but... through the ages we have found that a fully charged battery will self discharge in about 90 days... most auto manufactures claim that you need to run the vehicle ever two week (14 days) or sedimentation will set in. By this we mean the battery will start to sulfate... and die a death of inability to provide its current capability.
So with Solar and others... you will keep the bat topped off and working while in storage ...most of the time... A lot of the solar controllers have built in functions to keep the battery conditioned... but, your relying on the sun to keep 'em up...
Ahh yes the converter vs battery charger issue... that always seem to come back around... some even call them inverters... but which is right...
Well first off the inverter is the thing that takes the 12 volts and makes it into 120v ac. The battery charger is the thing which only function is to recharge the battery as quickly as it can. They have very little regulation and so after the battery is charged fully... will start to boil them because they contenue to put out voltage that will go above the batterys requirement for MAINTENANCE charge. Thus they will kill a battery if left on as it boils away the plates and liquid inside.. over heating and warping the plates.
THE CONVERTER... that most of the Airstreams had before the 90's were of the transformer type.. and again had very little regulation... if the shore power input was 132 v ac... then they put out 14.7 volts dc... and again boiled the battery.. if on the other hand the input was 108 v ac then the univolt would only put out about 13.2 volts dc.. not enough to bring the battery to full charge. They were good because they were simple.. and cheap. Most were rated for about 50 amps... which was more than enough for run'n the heater motor and a few lights...
THEN CAME THE NEW TECHNOLOGY... Airstream went to a more effecent switching type converter... but, they had failures... and most either boiled the battery or would not recharge the battery fully. i.e they were junk.
but, they did recharge the battery AND would provide 12 v dc power for the motors and lights. They did do a little better on regulation of the voltages.. but more they were more effecent... (transformer types.. that hummed right along were only rated for about 60% effecent... the new switching types... are rated for over 80% effecent. More a issue was that they could take the 108-132 v ac... and still recharge a battery fully... when they worked right...and were quiet... physically... but not electrically due to the nature of the electronic circuit.
NOW COMES THE NEW KID ON THE BLOCK... Today we have converters that have 4 stages... (sad'ly Airstream hasn't gotten on board with them yet) Some have said that their new ones are 4 stage.. but again failure rates without the owner knowing has been higher than acceptable...
So we did a lot of research on the topic.. when we decided that our old converter had to go... it just made too much physical noise... otherwise than noted above.. it took almost a day to recharge the bats to 90-95%... and that ment that you had to run the gen set for hours on end... etc...
We went with the new progressive dynamics 4 stage converter... its rated at a whopping 80 amps... yahoo... (we will get back to the current ability) First off we found it lighter and smaller than the old unit... has a fan cooling when needed for the BIG loads... (has yet to come on as the unit hardly gets warm at 90% full load)
Its quiet... big factor... and has the 4 charging stages.. of which you can override the auto function and go manual with the external pendent switch.
Ok so what makes these better... well they have the first stage that no matter what the frequency (line current is 60 cycles) will put out its rated voltage.. and current. It works from about 100 volts ac to 137 volts ac.. so that takes care of the campgrounds where everyone is pulling current run'n A/C and you want to get the battery back up to full from boondocking...
Its first level voltage set is at 14.7 volts.. similar to the TV alternator output... it charges the battery up more quickly... where we said the old one takes a day.. this one can bring the battery back up to 90% or so in less than 4 hours. This saves on the genset time or time just waiting for them to get recharged back up from 50% (you never let yours get below 50% DO YOU....) to about 90%...
The second voltage it then goes to is 13.7... now that may not seem like a lot but of voltage drop.. but it does keep the battery from boiling out... and maintains that voltage so that all the appliances in the RV will run at peak.
If no electrical load is being used then the converter (wizzard as I call it) will go to the third stage at 13.2 volts... this is a surface maintenance charge for the battery... it can stay their forever.. well almost... and never hurt the battery..(well kinda) So you can turn this puppy on and leave it forever...(glamping) and not have to do much to maintain the battery.
But, you say.. wait a min you said 4 stages... what is the 4th stage.. Ok... the battery now is on maintenance charge... and has been their for a couple of days.... bad thing can happen inside the battery when it get sedmentary... first off they found through technology. that the battery will cause the more consentrated acid to sink to the bottom of the cell... here it then can start to crystalize... sulfate... (not good) In your TV your battery get subject to physical motion and so the acid in the cell get shook up and mixed... not so in your RV that is glamping.. it just sits their... so what the brainiacks have come up with.. is... to have the converter jump back up to 14.7 volts for about 20 min every 21 hours... according to DPs operating chart..
So what does that do.. well when the battery is fully charged.. or nearly so... at that voltage it will cause the battery to boil... (lightly).. this action is like your perk coffee pot.. it cause the acid at the bottom of the cell to bubble up (in a way) and cause mechanical mixing in the cell... as well as clean the battery plates so that its at peak effecency.
Neat huh... boy wait till Airstream engineers (are they any left) find out about that... only problem is.. they squeek when they walk.. so to speak... and all go around saying cha ching $$$... hate to spend a bux... without out a high return from the buyer...
So you have to go aftermarket to someone like Progressive dynamics and get the 92xx converter if you want the latest and greatest...
Oh and some of the solar controllers have similar stages too now.. as that is the current technology and thinking to max your battery life.
... and we mentioned that this one is 80 amps.. why so much you say... well another technological issue is recharge rate... seems that you will keep the plates in the battery cleaner if you provide them with the max current they can demand... once the battery starts to recover... it start building a higher internal resistance and tapers off in its current demand... If you restrict the amount of current first applied... the battery will not recover as quickly... and it has been found the plates in time will coat out and not provide the current capability it was rated at...
besides... with 80 amps.. I can light up the whole trailer.. inside and out and never put a demand on the battery... where as the current converter in AS are rated for 45-50 amps.. and if you turn everything on... your current demand is up their around 60 amps... so the battery then has to provide the extra 5 amps or so.. in a discharge mode... not what we want when glamping etc...
So their you have the newest of the new thinking and products to improve your electrical issues.. and max your battery life...
Oh if your stor'n your trailer.. /RV... I think it wise to do the old school thing and remove them.. take them home place them on a piece of wood...(old wives tale) and recharge them frequently.. then take them back and put them in the trailer when you are going to use it. (labor intensive) but at todays prices and increases.. you want to optimize your battery life to the max.. after all you can hear cha ching $$$ when you get new ones and never got full usage out of the old ones your lugging into the dealership.
The adventure contenues... WA6CDE
GM Airstream is offline   Reply With Quote
Old 06-08-2018, 03:57 PM   #11
zapper's Avatar
2007 25' Safari FB SE
2017 30' Flying Cloud
Highland , California
Whew......
zapper is offline   Reply With Quote
Old 06-08-2018, 06:16 PM   #12
Iron tepee #35
1993 34' Excella
andalusia , Illinois
Well said, GM Airstream!!!!!!
mikeoxlong is offline   Reply With Quote
Old 06-08-2018, 06:59 PM   #13
1997 25' Safari
Thanks Folks all big help!
GM.....that was amazing, will abide!
Mike
Teddy Roosevelt
Old 06-08-2018, 07:28 PM   #14
Ray Eklund's Avatar
2019 27' International
2014 25' International
Boulder City , Nevada
GM Airstream... I love the battery enthusiasm! You are charging us at 14.7volts. Obviously not tweeting this one.
Human Bean
Ray Eklund is offline   Reply With Quote
Old 06-09-2018, 07:56 PM   #15
Julie-Bob's Avatar
2009 25' FB Classic
Scottsdale , Arizona
I have a 2009 25’FB Classic and the AS installed battery switch DOES NOT turn off the Propane Detector so it will over time bleed off the battery’s. So if the trailer will not be on shore power I disconnect the battery cable. Turn off your AS battery disconnect switch and look at your propane detector and see if the light is blinking. My detector light blinks with battery switch off.
Bob & Julie # 5587, 4CU in AZ
Julie-Bob is offline   Reply With Quote
Old 06-10-2018, 07:45 AM   #16
Half a Rivet Short
2022 Interstate 24X
Hi
Indeed pretty much all manufacturer installed disconnects shut off everything except the propane detector. i suspect the lawyers had something to do with that ....
Old 06-24-2018, 07:08 PM   #17
2018 27' Globetrotter
Paradise Valley , Arizona
Good data GM. So what does top line Progressive unit cost? Is it fairly easy to install in a new AS?
xisme2 is offline   Reply With Quote
Old 06-26-2018, 01:18 AM   #18
1973 31' Sovereign
1978 Argosy 30
1985 31' Excella
Funny you should mention that... I am in process of writing a article for the progressive unit on changing it out and upgrading to new technology. I have it almost complete and packaged to go to the mag. (with pix for a step by step.)
As to the price... I went with the larger one.. you can never have enough power... and it is rated at 80 amps... you can pick them up on line for about 230 bux... I found that several mail order places were cheaper than buying it local.
However... the orginal converter had only 50 amps... and if your using new LED lights do a total on power sheet.. so you know how much you really need for current. You want to make sure the converter can supply ALL the current needed so that your not cycling the bats and using them up when your demanding higher current than the converter can provide... I think you could get away with a much cheaper PD unit.. as they make several different amp ratings.. but, you want the 92xx (xx being the current output of the unit)
As to changing them out... on mine it was a breeze... the 120 volt plug is right their under the couch/bed in front... so you unplug one (old one) and plug in the new... (that being said.. my 80 amp one has a 20 amp plug on it... that has a funny lug that goes sideways... the wall plug AS used is not up to code.. and uses a special 120 volt 15 amp style )... I had to make a adapter to go from the AS recpt... to the 20 amp one.. easy to do.. short piece of 10-3 stranded wire cable...and a plug and receptical..
Remove the hold down screws from the old one.. and add some spacers and re attach to the floor with new SS hardware...
I show this in the article...
however... the 80 amp converter does not take 20 amps... actually it takes less that 15 but, they put the plug on.. and you can't cut it off or it voids the warrentee... pooo...
The rest is easy... about 6 ft of No. 6 stranded wire... (I used west marine wire that is rated for 105 deg C and is tinted wire).. very flexable... and easy to hook up.
Mine went from the battery cutoff switch... red cable... with lugs crimped on... the other was the black w white heat shrink to denote ground or negative cable that went to the 12 volt ckt breaker panel... again located behind my couch on the front wall of the trailer...
Man what a difference... the new PD 92xx unit makes... no more boiling bat's and what a great voltage range to boot... so now when you in low voltage parks... it works... and actually charges the bats... then again if your in a high voltage park... it maintains it regulation... and keeps the bats in tip top shape.. ready to go...
Old 06-26-2018, 01:21 AM   #19
1973 31' Sovereign
1978 Argosy 30
1985 31' Excella
Oh and one thing more.. for those of you who worry a lot... you can for 100 bux get a lifetime warentee... so that if anything goes turtle.. you box it up and send it back... for repairs... not bad... because eventually everything need some attention in time...
Old 06-26-2018, 05:18 PM   #20
HClews's Avatar
2019 23' International
Jensen Beach , Florida
As I wrote (Post #23) on the Battery Drain topic, we have successfully stopped drain during unplugged storage by: 1 disconnecting the inverter wire (with a switch at the battery) and disconnecting the propane detector (with a little switch next to the unit). With our little 10 W solar charger mounted on top of the propane locker, the batteries stay charged for months.
Since we still have the Factory-supplied (2017) inverter/charger, we make a practice of switching to the "store" mode when we're plugged in for any length of time. This turns off the charger and prevents it from overcharging the batteries. After a day a travel, our batteries are usually right up to 12.8 volts, so they usually don't need to be charged further by shore power. In our case, we believe that turning off the charger when on shore power helps to prolong battery life.
Obviously, a better charger would be a good solution, but with a bit of management we make do with our Factory charger.
Henry
HClews is offline   Reply With Quote
Dometic refrigerator won’t run on shore power& water heater light on when on shore po fotoman1527 General Repair Forum 23 05-03-2022 05:29 PM
Interior vinyl and wood layer, to leave or not to leave? amaelish General Interior Topics 0 05-29-2017 12:18 AM
Leave Shore Power Connected 24/7 Ron_CA Sprinter and B-van Forum 40 09-01-2014 06:19 PM
OK to Leave Water Heater Pilot Lit While Driving? John&Vicki Water Heaters, Filters & Pumps 3 01-29-2014 10:04 AM
Battery drained while on shore power 68International Electrical - Systems, Generators, Batteries & Solar 4 07-15-2002 02:51 PM
