Very complete reply from GM Airstream... But keeping it simple, we make a practice of turning OFF the converter whenever we're connected to shore power for extended periods. We've discovered we can do this very simply by flipping the switch near the door to the "store" mode. We have a 2017 27FB model with single-stage (dumb) converter/charger - which clearly overcharges the batteries if it is left on continuously.
A possible disadvantage of this procedure is that all power, including the fridge, will shut off in case of a shore power outage.
We've also found that the batteries will stay charged much longer in storage if you 1) turn off the propane sensor and 2) disconnect the battery wire to the Inverter. (We've installed a disconnect at the batteries for this.) These two items draw a small load; without them, the batteries will stay charged for months.
Cheers,
Henry
