I've got one of those plugged into the TV outlet in the bedroom. It doesn't move off the current voltage when the TV is connected and running which confirms my statement above the
12v lead of the trailer harness in not at all connected to the trailer
12v system, only the Dexter brake controller. I found my
12v plugin meter was inaccurate compared to my voltmeter so I took it apart and found a small dial and was able to adjust the voltage reading to match my voltmeter.
My next step is to understand the 12v bus next the Use/Store relay. It has power to it when the Use/Store relay is in Store mode so its always connected to the two batteries.
My question about the buss is there an input side and an output side? There are several connections to this bus. As above, one of them was the LP detector, connected last in the line of post, far right. This allows the LP detector to have power when the Use/Store switch is on Store. The LP detector has its own fuse.
The youTube video above, the technician points to the first pole looking left to right on that buss and indicates it is from the 12v lead of the tow vehicle harness.
There is a junction box to the left of this buss. I don't remember seeing any wires running from that box to the buss.
I may disconnect the first lead on the 12v buss and see if power is lost to the buss.
I guess my question is if I connect the 12v trailer harness lead and the brake controlle 12v line to the same lead will this work. With it connected this way and with the trailer disconnected from the tow vehcile and the trailer not on shore power will the Dexter controller still draw power in run down the batteries or is in deactivated because there is no signal from the brake controller in the TV.
For electric brakes they don't activate when the trailer is disconnected so why should the Dexter hydaulic actuator.
I'm I one the right track?
Kelvin
