Old 05-09-2014, 06:49 AM   #1
1984 31' Sovereign
charleton , Illinois
Convertor / Charger replaced.
Just swapped out the original Triad-Utrad TU-750-6 for a new 4 stage unit. The original unit had a red and black #6 gage for + and - and an additional #14 gage black wire to the 12 volt fuse block.
Does anyone know what load the black #14 gage powers?
All the interor circuits seem to be working, yet I have not connected this #14 gage circuit.
jerry d is offline   Reply With Quote
Old 05-09-2014, 07:48 AM   #2
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
I just did this in my classic 310 motorhome. It sounds like the original wiring is similar to your trailer. The separate black 14 gauge wire goes to your control panel "ac power on" light. Nothing else. I guess there is some way to modify the wiring to make this continue to power up that little light bulb but i was told on the forum here that most folks just abandon it all together. If you care to, pop a night light in the closest ac outlet and it will do essentially the same thing. It just tells you that you now have ac power.
mayco is offline   Reply With Quote
Old 05-09-2014, 08:11 AM   #3
mayco's Avatar
Are you located in charleston? Im an eiu grad and still have property just outside of charelston in hutton township.
Old 05-10-2014, 04:15 AM   #4
1984 31' Sovereign
Thank you, very much.
Old 05-10-2014, 04:16 AM   #5
1984 31' Sovereign
Yes, I live in Hutton Township, about 3/4 mile from Fox Ridge.
Old 05-10-2014, 04:22 AM   #6
mayco's Avatar
Do you know the folks from "goods from the woods" on snake trail road??
Converter/Charger vs. Inverter/Charger moosetags Batteries, Univolts, Converters & Inverters 5 11-22-2013 10:21 PM
power convertor ifly4cal Electrical - Systems, Generators, Batteries & Solar 4 12-07-2005 08:40 AM
Convertor question - 2005 Classic Pappy 2001 - 2005 Classic 2 05-30-2005 09:42 PM
Adding charger where no charger has gone before Jabba Electrical - Systems, Generators, Batteries & Solar 4 03-08-2003 09:39 AM
New power Convertor HOT! silverbullet Electrical - Systems, Generators, Batteries & Solar 4 09-24-2002 10:01 AM
