Old 11-02-2010, 05:50 AM   #1
Waters , Michigan
Are there two batteries,or just one ?
Any idea where the two batteries go in a 1963 sovereign? I was told it has a compartment for a spare,any truth to this? Thank You
PINKBIKE is offline   Reply With Quote
Old 11-02-2010, 07:19 AM   #2
Ottawa , ON
Don't quote me, but I think it was late '70s b4 AS started installing two batteries, maybe even early '80s.
I can tell you my '74 certainly only has one.
Old 11-02-2010, 11:47 AM   #3
Waters , Michigan
Okay,I have a small battery sized door on the street side.I thought this space was for the spare battery but it appears I am wrong once again,Thank You
Old 11-02-2010, 02:22 PM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
If you are interested in boon docking and want more battery life you can install as many batteries as you want inside the trailer just as long as you install Sealed Jell Cell batteries that never out gas.
If you do this all the batteries should be of the same type. Don't have a wet cell battery outside and sealed jell cell battery inside a they will not charge and i=discharge at the same rate
2004 Excursion 4x4
Old 11-02-2010, 04:51 PM   #5
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
Our '97 34' widebody has two exterior battery compartment doors. They are located on either side of the tongue on the front of the trailer. The interior wiring is set up so that the batteries are wired in parallel.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 11-02-2010, 07:23 PM   #6
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
We have an 84 Excella with the same setup as Aviator.
Our 66 Tradewind was designed for one battery, but there is actually room for 4 batteries- two on each side of the toilet. Replacement of the Univolt with a new compact convertor provides some additional space to install two more batteries. I will provide pictures when I complete the installation.
Dan
Old 11-02-2010, 07:28 PM   #7
Waters , Michigan
Are there any 1963 sovereign owners out there?
Old 11-02-2010, 07:38 PM   #8
Ottawa , ON
There probably are, although after looking through 11 pages of the Members List, I didn't see one. So, not too many then. But members with '63 Tradewinds would have very similar trayahs.
What is it you would like to know? Perhaps us dumb'uns with other year trailers could help...? Do you have the rear bath, by the way? On my '74, the battery lives in a nicely decorated little area on the curb side, ALMOST at the very back.
No room in there for another battery, but just ahead of it, under one of the beds, a person might be able to build a proper spot for another one...
Old 11-02-2010, 08:24 PM   #9
Waters , Michigan
I never implied you were "dumb uns"...I just need some questions about my trailer answered,and hoped to ask a few other questions answered... a bit of web camaraderie ,if you will...no harm intended..
How many batteries do you have? Jammer Electrical - Systems, Generators, Batteries & Solar 6 12-18-2009 09:58 PM
New Batteries woodedareas Batteries, Univolts, Converters & Inverters 3 03-09-2009 08:43 AM
batteries woodnhair Batteries, Univolts, Converters & Inverters 1 02-05-2009 06:21 PM
batteries jhenry Member Introductions 5 10-19-2008 02:03 PM
Batteries SJ Brown Batteries, Univolts, Converters & Inverters 9 06-17-2008 05:59 PM
