11-10-2019, 09:36 PM
#21
2014 25' FB International
2007 20' Safari SE
2005 19' Safari
Qualicum Beach
, British Columbia
Crown 6v 235amp. Absolutely no reason to go AGM on the outside compartments of a trailer unless you are planning on spending part of your trip upside down.
If your batteries are on the inside then different story go AGM or if you can afford it and don't spend a lot of time in a cold climate go Lithium.
11-11-2019, 06:23 AM
#22
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
Any time you have batteries die early (2 to 3 years is early ) you should step back and ask why. Indeed a very few will run a full charge / discharge cycle 365 days a year. Much more common is < 50 cycles a year. Even with minor abuse that’s not enough to kill a set.
Letting them run flat / dry for long periods is not in the “minor” category..... Some brands of automotive chargers will kill batteries if run to often / to long. Better monitoring may be a more important upgrade than fancier batteries....
11-11-2019, 07:59 AM
#23
1985 31' Excella
st. Paul
, mn
Originally Posted by ProTech
Our Trojan 6 volt AMG batteries have failed after two years. So we are going with lithium with the hope of have something that will last longer and give more AH.
If you killed your Trojans - you are doing something wrong .
Mis-use can kill any battery / chemistry .
85 Excella , 31' , electric brakes , R. twin [ would like it to be a single ] , future upgrades , composting toilet [ replace black water tank with a 2nd fresh ] , solar power , instant hot water heater .
Tow 94 Dodge Ram , 4x4 , Cummins , AT .
11-11-2019, 08:08 AM
#24
2018 27' Globetrotter
Apollo Beach
Originally Posted by Milo1952
You can buy extenders to make the box taller
I did this on my 2017 25' Airstream so I could install a blade cut-off switch, but this cannot be done on a 27' Airstream because the front storage door would not work with an extended battery box. I just did not install the cut-off when installing my 6V golf cart batteries in my 27' because I have solar and never disconnect the batteries. I would disconnect the battery when in storage without either shore power or solar charging. I think that most battery damage occurs in storage because my batteries would be nearly dead in less than 30 days of storage before I added the solar.
2021 Northern-Lite 10-2 & F350 DRW PSD, 600W Solar/Victron/600A BattleBorn
146 nights 31,000 miles (first 10 months!)
Sold: 2018 GT27Q, 74 nights 12,777 miles
Sold: 2017 FC25FB, 316 nights 40,150 miles
Sold: 2013 Casita SD17 89 nights 16,200 miles
11-11-2019, 10:16 AM
#25
2013 27' FB International
El Dorado Hills
Why the AGM batteries? The 27FB has an exterior battery box. The benefit of AGM's is they're sealed so can be used in an internal storage environment. I guess the other benefit is no having to add distilled water on occasion.
On the flip side AGM's are pretty expensive, maybe around $400 each whereas an equivalent wet cell is $100 to $150 each.
11-11-2019, 10:45 AM
#26
2018 27' International
Conroe
I would not put AGM batteries inside my trailer. They do vent and the hydrogen gas is very explosive. How likely they are to vent is unknown and I know many folks have done it for years. I believe the RVIA standards say not to do it. The only battery I am aware of that truly will not vent are the lithiums. FWIW
11-12-2019, 04:46 AM
#27
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
Unless you have a very unusual charge profile, the amount of gas coming off of an AGM is quite small. Any gas (hydrogen included) needs to get to a certain concentration before it will ignite. They generally need to be at a higher concentration before they will explode. For hydrogen, you need about 4% by volume before it will ignite. To detonate you need to get up around 18%.
Even a small trailer represents a very large volume of air. At the detonation point you would have almost as much hydrogen in the trailer as oxygen (it's 21% ). You are not going to get to this level (or the flammability level) with any rational AGM setup.
If it still concerns you, put in a vent. Hydrogen is much lighter than air. It will rise out of a space if you give it someplace to go.
11-12-2019, 06:49 AM
#28
Conroe
Hi
Hi:
You may be completely correct in how small the risk is by having AGM's inside the trailer. What you are not factoring in is how hot is inside the trailer (the hotter it is the more likely an AGM will vent) and how close they are to an ignition source. This may never ever be an issue 99% of the time but there is a reason RVIA standards do not recommend it. Each person should make their own decision.
11-12-2019, 07:01 AM
#29
Oswego
Hi:
Well, let's see. Auto manufacturers put AGMs inside the passenger cabin. How hot does the interior get in AZ? Even here it is commonly 120* inside during the summer. The do install a vent hose, typically through the underbelly in case the pressure valve opens. I wouldn't hesitate to put AGMs inside the AS, WITH a vent hose to the outside.
Question: do the common brands for RV use have a nipple for those attachment like the auto batteries?
-Rich-
11-12-2019, 07:38 AM
#30
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi:
Hi
With a battery just sitting there, you don't get any hydrogen coming off. The only time you see hydrogen is in the charge mode. Hydrogen is very light. It will rise / move around. If it's close to anything, it wold be close to the ceiling. If the Fantastic Fan is running then it's blowing air out of the trailer.
Again ... you need a *lot* of hydrogen for it to be a problem.
11-12-2019, 07:51 AM
#31
Oswego
AGMs dont gas at all, unless there is a problem. Then the pressure valve pops off. They are completely sealed prior to pop off. The hose is for a failure only.
Hi
-Rich-
11-12-2019, 08:34 AM
#32
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
If you have ever run leak tests on stuff, that little rubber gizmo isn't doing much to stop hydrogen .....
11-12-2019, 09:15 AM
#33
Oswego
Hi
True, Hydrogen molecules are the tiniest. But as you said above, that amount is virtually undetectable at any given time, and certainly is not ANY explosion threat.
Hey, your tire carcasses leak oxygen molecules....you're going to have a blowout!!!!
-Rich-
04-06-2022, 01:46 PM
#34
2014 16' Sport
2019 19' Flying Cloud
Madison, WI
Originally Posted by GMFL
Hello,
We have a 19' flying cloud with 2 dead intrastate group 24 batteries. Looking to purchase new for this season. I was wondering if you still like your 6 volt batteries? Are the amp hours for one 6 volt, 220 amp hours?
Thank you!
