10-25-2014, 06:48 PM
2012 16' Sport
2015 19' Flying Cloud
Seattle
Honda EU2000 storage box inquiry
Air Streamers........All hands on deck!!!!!! I just purchased two 2014 Honda EU2000 generators for my first road trip in my new,to me, Airstream. I was hoping that someone out there has gone through the learning curve on determining the best storage container for these units. I did see in a 2008 post that a 24 gallon Action Packer was the Bomb but testing shows that the new fuel cap design is problematic. Suggestions Airstreamers? Thanks Doug
10-25-2014, 08:25 PM
2005 19' Safari
GLENDALE
, AZ
The new gas cap looks huge! Is there any chance that a replacement cap for the earlier model will fit? That might be an option, unless there is some function that the new cap has/does that is important to you.
10-25-2014, 09:08 PM
1988 25' Excella
1987 32' Excella
Knoxville
, Tennessee
I carry a single 2000. I just put it in the truck. It does not leak, it is nicely contained in its cover. I would hate to have to lift it in and out of something else.
10-25-2014, 09:18 PM
2012 16' Sport
Seattle
Hmmmmm...... Maybe. Old cap is a good idea. I will check that out. Love that practical thinking. Others????
10-25-2014, 10:25 PM
2005 19' Safari
GLENDALE
, AZ
If you think you may later add an extended run tank and hoses, you might want to take a look at "The Upper Red Cap", instead of buying a Honda gas cap. That could save you buying two more gas caps at a later date.
See more information on extended run tanks, hoses, fittings and gas caps at this link:
http://www.airforums.com/forums/f448...ml#post1164539
10-25-2014, 11:12 PM
2012 16' Sport
Seattle
Phoenix....... You are introducing many things to think about. It seems I may need to consider extended run time tanks and I haven't even put oil in the new machines. Love the input and ideas...thanks.
10-25-2014, 11:18 PM
2012 16' Sport
Seattle
Bill M...... I will be transporting the generators in the trailer (on the floor of the living space) or in the tow vehicle ( I do not have a truck). My hope was to keep smells at a minimum via a second containment shield. You may be correct in that I may not need one as the units are well constructed. Thanks for the input.
10-26-2014, 06:44 AM
Oswego
Old, Non-California caps work fine. My Companion came as a Cal model and I swapped out the cap. You can also heat the lid at the cap area well with a hair dryer and re-install the lid over your existing cap. It will shape a "dent' in the inner lid layer and cool to that shape. Also get some foam tape weatherstripping for the lid and odors will be greatly diminished.
-Rich-
10-26-2014, 11:48 AM
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
Camping World has individual storage bags on wheels and lifting straps for the 2000 watt Honda generators.
10-26-2014, 03:09 PM
2015 30' FB FC Bunk
Troutdale
, Oregon
For what it's worth I did this ONE TIME, and the rubber feet of the Honda 2000 left permanent little "bullseye" marks on the light colored flooring in my 2013 International. I've tried everything I can think of to remove the marks, but so far no luck. So be careful with that option!
10-26-2014, 04:36 PM
2012 16' Sport
Seattle
Spamcan.....thanks for the lesson learned. I owe you one. D
10-26-2014, 07:22 PM
2010 28' Flying Cloud
Lower Alabama
, USA
I have carried mine in my trailer to reduce load in the truck. I put them in the hall over the rear most axle. I simply used the boxes they came in. Realizing these boxes will ultimately get destroyed, I too would be interested in a more permanent solution. I will look into Camping World's offering.
By the way, get the extended run setup. I use it most of the time I have the trailer on generator power. It will run one or two generators and is well worth the expense. I bet I have had 25 people stop and inquire about it. It will run the generators all night with no problem.
Alan
"If you must choose between two evils, pick the one you never tried before!"
Air #64439
Southeastern Camping Unit WBCCI #5033
10-29-2014, 02:31 PM
1995 30' Excella
Bowie
, Maryland
It's cheap, but: We bought some $10 storage containers from Lowe's. Ours are dark gray, but we also have some tan ones that have photos in them, and we have some others that we keep in the back of the truck for those times we want something back there to stay dry/out of sight (we have a cap on the bed, but it doesn't always stop water from getting in). I don't fully trust the containers; I always remove the generator from the container when I'm loading it into the truck, but on the other hand we've had them a couple years and no generator has fallen out yet. The lids lock reasonably well, not great; before we had the cap on the new truck, I strapped bungee cords around the containers+lids to be safe.
They're also large enough to cram in a 1 gallon gas can, cable lock, and the connection cables.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
10-31-2014, 11:28 AM
Alpharetta
, Georgia
As most EU2000i users will tell you, the fuel tank is vented to the atmoshpere via the fuel cap. The EU2000i has a flip-style vent control built into the cap; when open, a certain amount of fuel vapor naturally exits the vent. In 2010, both US EPA and California emission rules changed, requiring reduction of these evaporative emissions.
Honda elected to capture them by enlarging the fuel cap in fitting a charcoal "donut" for air to flow in/out of the tank. The charcoal captures the emissions, and is good for the life of the generator. To encourage continued use, the cap is also tethered to the filler neck.
It's true the smaller, older caps will fit newer models and vice-versa, but fitting an old-style cap to a generator not originally made for it technically violates EPA & California emissions regulations.
It is okay to fit the larger cap to an older model and you can sleep better knowing you helped reduce emissions a small bit.
Robert@Honda
Social Media Consigliere
Caveat: I work for Honda, but the preceding is my opinion alone.
10-31-2014, 05:17 PM
2006 19' Safari SE
Tucson
You could always STORE it in the Rubbermaid Action Packer (that's what we use) using the old cap...and switch the cap to the new one when in USE...that way you are covered in both instances...
TB & Greg and Abbey Schnauzer
AirForums #21900
PastPrez, 4CU/WBCCI
10-31-2014, 05:59 PM
2005 30' Classic
Burlington
, Ontario
Is there really a need for a storage box? We have carried a Honda gennie just "as is" for a few years now - I would think a storage box for it would be just something else to bring along.
Maybe I am missing something - we do carry ours in the back of the truck (with Leer cap) and maybe if carried in an SUV there might be more of a need for a box. But the gas cap has a shutoff valve on the vent and I have never noticed any gasoline smell at all.
Might be worth just trying it without a storage box first - unless there is another reason for a box?
Brian
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
10-31-2014, 10:13 PM
2006 19' Safari SE
Tucson
Not really. I don't think odors would be much of an issue either... That said, we carry one in the Action Packer and the other with just a cover on it...the tote is handy, though as there is room for cables, adapters, manuals, extra oil, a few tools, etc... We use the tote as a side table on the patio, too, or an extra seat ... so it serves double-duty.
AirForums #21900
PastPrez, 4CU/WBCCI
11-01-2014, 05:40 AM
1995 30' Excella
Bowie
, Maryland
We have a cap on our truck, but we prefer to keep the expensive generator completely out of sight when not in use. Also, we keep them in our shed at home, and they would quickly get covered with dirt and cobwebs.
11-14-2014, 08:59 AM
2015 28' Flying Cloud
Melbourne Beach
Honda 2000 Generators Mounted on Frame/bumper
This method is rather simple. The generators fold in to dransport and fold out to open the bumper storage and fill with fuel. When running for long time I put generators on the ground to reduce vibration and noise.
See the photo.
11-14-2014, 10:02 AM
Oswego
Robert, if EPA regulations are the same as vehicles, there's a loophole for consumers. While it is true that it is illegal for manufacturers and licensed repair facilities (dealers and other commercial repair establishments), to modify emissions equipment, it is not illegal Federally, for an individual to modify anything. However, (for vehicles) if you live in a non-compliance area with vehicle testing, you just won't get to renew your registration without returning the vehicle to OEM specs. This is a State run mandate, not Fed. (although the feds do "incentivize"the states to run emissions testing)
Basically an individual can do what they want to their Gennie....like modify it for tri-fuel, etc. Dealers and commercial businesses can't. (unless that mod, like propane carries an EPA certification on the equipment)
STATES MAY VARY on this though....particularly California.
-Rich-
