Old 04-28-2016, 03:33 AM   #61
Sag Harbor , New York
Back to the basic question of 1000 vs. 2000 --
Per Michael's [CWCHIEF] recent post on this other thread:
http://www.airforums.com/forums/f448...ne-148661.html
that Yamaha generators can be purchased from US Carburetor, complete with the propane conversion AND with the Yamaha warranty, we are considering the 1000i, per the quote below, mainly to keep our batteries charged in the FC20. I will check our owner's manual, but my recollection is that the battery charger does not draw more that the 1000's rated output of 7.5 amps. Thank you for any thoughts on this capacity issue. The weight savings seem worth it to us.
Peter
PS -- edit -- On p. 8-23 of our manual:
https://www.airstream.com/wp-content...gcloud2014.pdf
the converter is rated at 8 amps. [p. 91/114 of the PDF] Seems like the Yamaha 1000 could handle this, albeit just barely, as the maximum draw of the converter would normally be quite a bit less than 8 amps . . . right? Thanks.
Originally Posted by OTRA15 View Post
Thanks for this info. Michael. Here is the Yamaha 1000 available complete for $1071.19.
http://www.yamaha-propane-natural-ga...m/ef1000is.htm
Comparison of the 1000 vs. 2000:
https://www.yamahamotorsports.com/ge...20091d7ca01773
We are considering the 1000 for our FC20 to save on weight (27.9 lbs. vs. 44.1 lbs.). Its only function would be to keep the batteries topped off (7.5 Amps rated AC current).
Thanks again,
Peter
PS -- I will also post this in the following Honda 1000 vs. 2000 thread:
http://www.airforums.com/forums/f448...0i-147804.html
Old 04-28-2016, 04:31 AM   #62
Correction -- "AWCHIEF" for Michael -- apologies.
Peter
Old 04-29-2016, 12:18 AM   #63
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Since the 12Vdc output of most generators is typically at a constant voltage, it is possible to cook the batteries since the charge is not altered as the voltage in the battery increases. This is why the single rate cheap Airstream installed converter typically has the capability to cook the batteries.
When the user connects their trailer to the 120Vac output of a generator (and hopefully have a multi-stage converter to properly adjust the charge rate to the battery condition) the battery has the chance for a proper charge cycle and which results in longer life..
Solar charge controllers also have to be programmed to the charging characteristics necessary for the trailer's battery type.
Old 05-27-2016, 06:02 AM   #64
Our Yamaha 1000 tri-fuel is supposed to ship in the the next day or two FYI:
http://www.airforums.com/forums/f448...ay-150492.html
Old 06-18-2016, 05:08 AM   #65
FYI on a recent trip, the new tri-fuel Yamaha 1000 gen worked out great for our FC20. It handled both the battery charger/converter and the fridge on electric. We still have the OEM charger, and the batteries were fairly well charged already, but a new Progressive 4655 converter might overload the 1000 gen? TBD
The RPMs went up for the combined load, so guessing this was maxing out the gen, but the breaker did not trip.
The 1000 is really small for storage and very light at 28 pounds.
Yes!
Old 06-18-2016, 05:17 AM   #66
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
The RPMs went up for the combined load, so guessing was maxing out the gen, but the breaker did not trip.
It's normal for the RPMs to increase under load and does not necessarily mean it was maxing out.
2019 Ford Expedition Platinum
Old 06-18-2016, 05:25 AM   #67
Yes I realize that, but the two loads combined have to be approaching 1000 watts, right? [converter/charger plus fridge] The gen has a tachometer but I forgot to check it.
Plus I think the gen output is actually slightly less than 1000 watts.
PS edit see earlier posts re our OEM charger/converter load.
Old 06-18-2016, 05:35 AM   #68
Mantua , Ohio
I want to buy four 1000 gen and hook them up parallel, parallel. That way I can custom exactly how many watts I need. I can use one, two, three or four or any combination of these! Have I overthought this?
Old 06-18-2016, 06:17 AM   #69
r carl's Avatar
Lin , Ne
You are joking right?
Old 06-18-2016, 06:21 AM   #70
Yes
Old 06-18-2016, 06:24 AM   #71
Mantua , Ohio
Of course,
Old 06-18-2016, 06:28 AM   #72
Images: 59
Why wouldn't you buy two 1000 watt and one 2000 watt? It would be cheaper and less weight.
And it wouldn't sound like a beehive.
Old 06-18-2016, 06:42 AM   #73
I would only buy multiple similar gens if the mfg. already has a set up for linking them for more amps. Custom building anything is not cost effective IMO. The standard is Honda 2000 x2. I don't think Honda or Yamaha market a combined set up for 2 1000 watt units.
Plus wiring up your combination of gens could be dangerous and shocking in outcome!
KISS
Plan ahead for your electrical needs, and buy what fits.
A/C use is one deciding factor of course.
Happy Trails!
Peter
Old 06-19-2016, 08:25 AM   #74
switz's Avatar
2014 31' Classic
Honda also does offer a kit to parallel two EU3000iS 3,000 watt units . The two units cost more than one EU7000iS 7,000 watt unit but weigh about the same.
Old 06-20-2016, 09:08 PM   #75
2013 22' FB Sport
College Place , Washington
If you are mostly camping in the mid spring to mid fall, go solar you will be amazed how fast a few hundred watts of solar panels will recharge your batteries. If you are doing winter camping, or want a spare generator in case of power outage go with the 2k. If you really only want it for topping off your batteries for lights and such, go with the 1k, much lighter.
-Dwight
morgandc is offline   Reply With Quote
Honda EU 1000i chrij0ir 2009-2015 Flying Cloud 11 10-31-2014 12:52 PM
Honda 3000is vs 2x Honda 2000i ILOVESALLY On The Road... 64 05-16-2014 09:13 AM
Honda 2000i companion + 2000i or just 2 2000i's??? socdiva Generators & Solar Power 5 10-27-2009 02:53 PM
Unregulated DC-Honda 1000i doorgunner Generators & Solar Power 23 09-06-2007 05:16 PM
Honda 2000i generator wayner1239 Generators & Solar Power 22 02-28-2003 02:48 PM
