08-08-2017, 07:10 PM
Austin
Car Generator
Has anyone bought or tried this product? Found it on the Airstream store and it looks interesting.
https://store.airstream.com/product/car-generator/
08-08-2017, 08:01 PM
Don't think I'll be spending $695 for a mystery box.
08-08-2017, 08:23 PM
diesel maniac
Airstream - Other
Tucson
, AZ
It's just a fancy inverter with a fancy price tag. Inverters can be had for much less than that. Output is usually limited by your battery/charging system, don't expect to run all that stuff at once. Your engine has to stay running or your starting battery will soon be depleted. Extended idling with most engines is not good for them, and charge rate at idle may not be enough depending on your load. You can get idle controllers for most diesel vehicles to raise the idle sufficiently to avoid engine damage, but then you have a roaring, fuel sucking engine to listen to. And the risk of CO poisoning at any RPM.
Inverters have their place and IMHO that is for short term use and emergencies. You would probably be better off with a small gas powered inverter generator, there are some out there costing less than that inverter you linked. Personally I like the Honda inverters, very dependable and you can hold a normal conversation while standing next to one, although the priciest of them all.
08-08-2017, 08:46 PM
diesel maniac
Airstream - Other
Tucson
, AZ
leave the car engine running and lock the car with a spare key
Really??
08-09-2017, 12:27 PM
The Aluminum Tent 3
2014 23' Flying Cloud
Park City
, Utah
Running a big V-8 engine to supply power? Umm, no. Your batteries will run everything this does...then use portable solar or a small 1000 watt generator to keep them charged up.
No specs on this thing either. Like earlier poster said...a 'mystery box.'
Read up on all the threads here about solar, generators, boondocking...lots of good information to absorb.
08-09-2017, 12:50 PM
1977 Argosy 24
Milltown
, Wisconsin
It's not generating anything but heat converting 12 volt dc to 110 volt ac. Good scam, and no stats on output. Total waste of money.
08-09-2017, 01:49 PM
Biloxi
, Mississippi
Ad copy seems to have been written by a 12 year old that knows nothing about automobile or trailer systems.
MICHAEL
08-09-2017, 02:59 PM
Figment of My Imagination
2012 Interstate Coach
From All Over
, More Than Anywhere Else
Could be worse. At least it seems that English is the person's native language.
When I needed information about my Fiamma awning and looked up their web page, the ad copy on the page read like it was translated from Italian to English by a person whose native language was German!
Anyway, save your money and buy a portable jump-starter. This one does a whole lot more than the so-called "car generator" and costs a whole lot less (but don't use it as a car generator, charge it beforehand and carry it with you): https://www.amazon.com/DEWALT-DXAEPS...34WV09YNXTS24A
08-09-2017, 04:54 PM
2007 27' International CCD FB
San Diego
While I wouldn't pay that much for a 1000W inverter, it could serve a need for certain low use scenarios. For higher duty cycles, or full timing, this wouldn't make sense.
This got me thinking, since I have remote start on my vehicle...
Not that I would do this, but I could see one mounting a high wattage inverter on the trailer. With a high amperage aux pigtail to the tow vehicle. For those less used instances of making coffee/dryer/microwave - easily fire up the vehicle from within the trailer to support the inverter for those durations. Heck, I've certainly idled my car for lesser uses.
08-09-2017, 08:56 PM
1999 34' Excella
Hillsboro
No.
Peace and Blessings..
Channing
WBCCI# 30676
08-12-2017, 07:46 AM
diesel maniac
Airstream - Other
Tucson
, AZ
Somehow a gasoline generator disappearing does not seem as traumatic as having someone drive off in your tow vehicle, especially if it is still hitched to your trailer!
How do you address the issue of extended idling, which is detrimental to many automotive engines?
08-15-2017, 10:39 AM
1999 34' Excella
Hillsboro
Sure, this is a temp, specific option... even for tent camping where vehicle is close by.
There is significant idling concerns... especially for the new diesels which are edicted to run DEF... 10 minutes idling, the filter stsrts clogging.. at 20 minutes continued idling, the exhaust system is having problems... soon, a "regen" will be required on the Duramax, requiring driving over 45 mph until regen clears the filter.
Just an FYI for you to be aware of... might be good to inform customers...
Channing
WBCCI# 30676
09-02-2017, 07:41 PM
2008 34' Classic S/O
Arnprior
, Ontario
Nice to see what happens when opinions, " unhampered with facts" are replaced with facts, unhampered with baseless opinions. Interesting!
Pete
Pete Crook
"Put it all behind you!"
S/OS#88
12-22-2021, 11:24 AM
2010 22' Sport
Sarnia
, Ontario
$50-$80 thousand dollar generator, running and overheating exhaust system. Also probably polluting more than a small generator. The guy sell these is a absolute genius and probably sells fridges in Alaska. Merry Christmas and Happy New Year
12-22-2021, 04:08 PM
2014 25' FB Flying Cloud
Down the Shore
, New Jersey
Fast forward 3 or 4 years from the OP and you have the Ford F-150 V6 twin turbo Hybrid Pro Power Onboard 7.2 kW idling in your driveway…..
Rich
12-23-2021, 06:34 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
BooYa...another total waste of a perfectly good driveway.
