11-23-2008, 05:18 PM
Allentown
, New Jersey
Wiring Problem
I just did something stupid. I moved my new 2005 Airstream Safari without disconnecting the electrical cord in my garage. It tore all the wires out of the three prong plug that attaches to the side of the trailer. In trying to take the plug apart so I could rewire it, the pieces feel apart and I can't figure out which wires go to which terminals. Does anyone have a diagram of how to rewire this plug. It is the female end with one short curved slot, one slightly longer curved slot and one slot in the shape of an L. I have a green, white and black wire. Thanks for any help.
Larry
1971 Safari
2005 Nissan Titan
11-23-2008, 05:31 PM
Corona
Larry
I am out of town, but hope this will help you.
The green wire goes to the L terminal, which is ground.
The white wire is a common wire.
The black is the hot wire.
Best way to make super sure, is purchase a polarity tester at Home Depot. They are cheap. Then connect the white and black wires as you wish.
Next check the polarity at an outlet in the trailer. It will either right or wrong.
If it's right, good.
If it's wrong, then reverse the white and black wires.
You should always use the polarity tester when you travel and plug into city power wherever you may be.
We would like to think that all power sources are correct, but they are not.
The polarity tester will always give you a heads up.
Reversed polarity sources simply means that if your standing on the ground, especially if it's wet, and then touch the trailer shell, you will get an electric shock.
Shocks are OK, for the axles, but not for the human body.
11-23-2008, 05:48 PM
1970 27' Overlander
Houston
Stupid, Ha
You think thats bad, I was turning around in our yard and we have some thick wild grape vine growing over some trees. I needed to back up just a couple of more feet so thinking is was just some vines I backed up just a bit more (I'm still sick about it!) and put a nice dent in the upper left panel, there was a broken limb just under the vines. I named that dent dumb-#ss!
James
____________
1970 Overlander
11-23-2008, 06:20 PM
Corona
James
Replacing the upper segements on your 1970, are not that expensive.
They run about $1200.-- or so each, plus perhaps some freight.
Contact your insurance company.
They pay for "sudden, accidental and direct" losses, less your deductible.
Their definitions in this case is called "negligence," which is a nasty word that simply means, as a human being, your screwed up.
So? So what? Thats why you have insurance.
However, have the repairs done using "olympic rivets".
If you insist on buck rivets, most of the bathroom furniture and headliner would have to be removed, which is not good in itself, but you may then also be flirting with a constructive "total loss."
Bob Jones, in south Houston, would do a good job for you.
11-24-2008, 07:56 AM
1970 27' Overlander
Houston
Andy, they did total it, I could have given them the trailer and taken 5500 (because I didn't up the value of the trailer with insurance company after putting I don't know how much $$$ into it, more human error). So I kept it and took 3200 and will keep the dents and use the money for other repairs. I was thinking of buying the segments and doing it myself but yikes, that is major damage if I mess that up to.
James
____________
1970 Overlander
11-24-2008, 08:21 AM
Princeton
, New Jersey
Normally electrical receptacles, plugs and wires are color coded.
Within the wire Black is power White is common and Green is ground.
Within the receptacles/plugs green is ground, also in the plug as Andy mentioned the L shaped lug id ground, the Gold lug is power, the Silver lug is common.
I would also remove the receptacle from the side of the trailer and make sure things are OK on the inside of the trailer and inside the receptacle itself.
2004 Excursion 4x4
11-24-2008, 07:52 PM
Allentown
, New Jersey
Andy and Howie - thanks for your advice. I finally got the plug back together and it is working fine now.
Larry
1971 Safari
2005 Nissan Titan
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
wiring diagram
banjoman |
Vintage Kin |
2 |
07-23-2008 05:03 AM |
Wiring diagram
2Coaster |
1970 - 1973 Overlander |
9 |
04-13-2008 07:48 PM |
Anyone have a Wiring Diagram?
Chopper |
Electrical - Systems, Generators, Batteries & Solar |
14 |
09-22-2006 09:49 AM |
Wiring Diagram please
Drifter |
1 |
06-04-2004 06:21 PM |
wiring diagram?
nu2argosy |
2 |
04-20-2004 07:30 PM |
