Old 07-14-2018, 07:01 AM   #1
1964 24' Tradewind
2006 39' Land Yacht 396 XL
Lawrence , Kansas
Voyager Backup Camera Power
Some help needed for the electricly challenged. I am hoping to install a 12-volt back up camera just above the license plate light on my 64 Tradewind. I pulled the the light expecting to see two wires but, I only find one wire running from the plate light and spliced into one green wire. I assume the green wire is the hot 12- volt and the ground for the licence plate light is achieved by attaching the light to the body of the trailer. If this is correct, can I still use this green power wire to attach the camera which has 2 wires (black and red)? And if so, how do I go about it?
Name:	camera power.jpg
ttbikes is offline   Reply With Quote
Old 07-14-2018, 07:11 AM   #2
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
Easy peasy,
The red would go to your +12 volt which “seems” to be the green. And the black would go to the ground/skin. You could use a eye crimp and mount black cam wire under one of the tag light mounting screws.
Old 07-14-2018, 07:42 AM   #3
1964 24' Tradewind
Lawrence , Kansas
Thanks GMFL. That is what I was hoping but hear.
Old 07-14-2018, 08:05 AM   #4
"Cloudsplitter"
Consider mounting it higher up...gives a better view of how much traffic is behind you. Plus the newer rear view cameras give you a reference grid to determine distance.
I just installed a Furrion on our Classic, good range, clear picture.
Old 07-14-2018, 08:22 AM   #5
2018 28' International
Fayetteville , Georgia
Check the wiring with a multimeter. Consider a higher mounting position, get power from a marker light.
brick
brick
2018 International Serenity
Cute wife...
brick1 is offline   Reply With Quote
Old 07-14-2018, 09:01 AM   #6
1964 24' Tradewind
Lawrence , Kansas
I did consider a higher positioning but the 64 doesn't have marker lights up high. I have have test rigged the system (Voyager WV05410) by taping the camera to the intended placement to check out the field view. I too was a little concerned also but the field of vew was surprisingly good (no road test though). The license plate is high on the 64 and the trailer has a 3" axle lift. The camera will be about 53" off the ground. I plan to post results after I road test the final installation for my vintage brethren in case anyone is fighting the same problem. I can move the camera above the window and fish wires from a cigarette lighter for a power source but, I had hoped to avoid that. I will temporarily mount it with just 2 screw holes for a road test just in case but, I could see both my bumper and the fence (and above it) 30 ft back in the first test.
Old 07-14-2018, 06:26 PM   #7
AFTER TAXES's Avatar
1964 22' Safari
1993 25' Excella
Flagler Beach , Florida
brick
following the brick...........lol
AFTER TAXES is offline   Reply With Quote
Old 07-15-2018, 06:28 AM   #8
"Cloudsplitter"
I have a rule...do NOT drill holes unless no other option available. 🙄
I used industrial strength Velcro to mount the camera just under the AS logo. Running a very small diameter power wire under the window gutter thru the seal into the rear 12v power port with a switched plug. I don't have to turn on any lights to power the camera.
Plus...the camera can be removed easily during our WNY Winters.👍
Old 07-15-2018, 07:22 AM   #9
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Robert,
How does the Velcro do holding the camera steady. Does it bounce around any, or did you use the rigid mounting Velcro
Thanks for the info.
Old 07-15-2018, 07:52 AM   #10
"Cloudsplitter"
Originally Posted by GMFL View Post
Robert,
So far it's been very good.
I attached a 1/8" thick piece of high density sign board to the camera base, and countersunk the 3/16" stainless machine screws. The Nylock nuts just fit the openings so no wrench needed. The signboard gives the velcro a good area to adhere to and the area below the AS logo is flat enough to give a base.
ID:	316984   Click image for larger version
ID:	316986   Click image for larger version
Old 07-15-2018, 04:55 PM   #11
Link’s Travels
2002 25' Safari
1999 35' XL 350 w/slide
LINCOLN , Nebraska
Rear Camera
Has anyone mounted a camera inside, at the top of the rear window. I am considering doing just that. What could be the down side, other than reflections on the window??
MissingLink5 is offline   Reply With Quote
Old 07-15-2018, 05:13 PM   #12
"Cloudsplitter"
I haven't tried it, but our rear window has a pretty dark tint so I'm sure it wouldn't be doable for us.
Easy enough to try though. 👍
Old 07-15-2018, 05:19 PM   #13
2018 27' International
Southeastern MI , Michigan
Works great for rear view and for passing. There’s no doubt when it’s safe to move back over.
2018 International Serenity 27' FB
Michelin 16” tires
Hensley Arrow hitch
Tow Vehicle: 2020 F-350 6.7L Diesel
Countryboy59 is offline   Reply With Quote
Old 07-18-2018, 10:37 AM   #14
2015 22' FB Sport
Westminster , California
Using camera inside
We have a camera that uses a magnetic attachment and have mounted it in our bathroom window (2015 22 Sport FB) It is battery powered. There has been no problem with the picture, it is not super clear (may be the camera) but we can see when there is a car there. Our problem has been battery life and signal cutting out and delay. Again it may be the camera (a gift, so it was not well researched), or there may be additional interference with having the camera inside the trailer.
Hope that helps.
ParkTreader is offline   Reply With Quote
Installing Voyager Wireless Backup Camera 25Twin Audio, Video & TV 26 03-23-2021 01:07 PM
Running Power to Voyager Rear-view camera garybair Audio, Video & TV 55 08-01-2018 06:54 PM
Voyager Rear Backup Wireless Camera System WVOS511 moosetags Airstream Classifieds 0 04-13-2018 01:31 PM
Voyager Wireless Backup Camera dmilem General Repair Forum 2 10-17-2017 05:16 AM
Backup Camera as Rear View Camera Rapa Nui Tow Vehicles 10 07-10-2013 04:37 PM
