Old 07-17-2018, 12:21 PM   #1
Santa Rosa , California
Blinded by the light (closet)
We have a 2018 25' Cloud, rear bed. Because I'm not tall, the LED light in the closet is a above eye level and almost counter-useful (is that a word?). It shines so brightly into my eyes, it makes me squint. I opted to cover inside the half of the translucent cover closest to me in aluminum tape.
https://i.imgur.com/h3oh4Q4.jpg
Now I can see into the closet without the light glaring in my eyes.
https://i.imgur.com/HfjARUx.jpg
It doesn't seem to diminish closet illumination and it's easily removed if I later change my mind
--Sean
SeanWasHere is offline   Reply With Quote
Old 07-17-2018, 01:58 PM   #2
Mollysdad's Avatar
Another good idea today!
Old 07-17-2018, 02:12 PM   #3
rowiebowie's Avatar
2012 Avenue Coach
Corpus Christi , Texas
Just the kind of solution I like. Quick & easy.
I must say, I was expecting to see something cheesy. But looks good!
rowiebowie is offline   Reply With Quote
Old 07-17-2018, 03:05 PM   #4
2007 22' International CCD
And, if you take the time to carefully remove the cover (assuming it's removable), the aluminum foil tape could go on the inside to make it look deliberate...
I'm going to try this on my rig--the closet light is incandescent at the moment, but it does dump light all over the place instead of just where it is needed...
Sean, "Counter-useful" may not be a word, but it SHOULD be...IMHO.
rmkrum is online now   Reply With Quote
Old 07-17-2018, 04:36 PM   #5
rmkrum, I now see that the photos are a bit unclear, the foil tape is on the inside, I took another photo that may be a little more clear
https://i.imgur.com/Z3QOGot.jpg
Also, if your cover is like this one, here's how to remove it without breakage. Looking at the photo below for reference, squeeze the two tabs indicated by the knife blades. Once these are depressed, the "un-tabbed" side of the cover can lower, which then allows the other two tabs to slip away from the assembly, freeing the cover.
https://i.imgur.com/od9eaVp.jpg
--Sean
Old 07-17-2018, 09:05 PM   #6
Perfect. Great write-up and photos. Thanks for taking the time to write it up and explain!
Old 07-18-2018, 09:36 AM   #7
2012 30' International
Livingston , Texas
And if you don't have enough light like the top shelf in the 30 Signature closet, get one of these.
https://www.harborfreight.com/200-lu...ght-63922.html
glenrms is offline   Reply With Quote
Closet light bulb Tarheel Electrical - Systems, Generators, Batteries & Solar 5 10-23-2020 07:09 AM
Blinded by the light! badkat On The Road... 0 05-22-2016 07:48 PM
Need replacement light fixtures for closet frankfarmer Lights - Interior & Exterior 2 01-28-2012 08:55 AM
New Light for the cedar closet Dan@LED4RV Commercial Listings 6 04-07-2011 07:04 PM
closet door knobs buckmaster Cabinets, Counter Tops & Furnishings 5 11-07-2002 08:09 PM
