Old 04-01-2010, 07:38 PM   #1
toastie's Avatar
1955 22' Safari
Great Lake State , .
running lights
Tested my running lights by running a line from positive side of battery to lights, then grounded the battery to shell and everything work, all running lights came on. My question is how does one hook-up running lights to the TV (7 pin bargman cable)..............thanks
toastie is offline   Reply With Quote
Old 04-01-2010, 09:06 PM   #2
6PackCharlie's Avatar
1995 30' Excella
Logan , New Mexico
Maybe this will help. If you still have questions, let me know.
Charles & Annette
WBCCI # 1407 -- Member 4CU
1995 31' Excella
Dodge 2500 Diesel-Tow Vehicle
___________________________________________
6PackCharlie is offline   Reply With Quote
Old 04-01-2010, 09:38 PM   #3
soldiermedic's Avatar
Florissant , USA
Wire them to the green wire on the 7 pin.
Streaming Soldiers Blog
soldiermedic is offline   Reply With Quote
Old 04-02-2010, 07:38 AM   #4
toastie's Avatar
1955 22' Safari
Thanks, everthing is working now, however, when the running lights are switched on using the TV the turn singal lights become very weak.
Old 04-02-2010, 07:51 AM   #5
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Sounds like you don't have a good ground from the Airstream to the TV. Hard to say without standing there to see what you see.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 04-02-2010, 07:56 AM   #6
toastie's Avatar
1955 22' Safari
When I turn the running lights off, turn siginal lights are ok........
Old 04-02-2010, 08:00 AM   #7
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Is the engine running on your TV? If the lights get brighter with the engine running, you have a voltage drop problem. Could be a marginal battery, bad connection(s) at the battery, bad connection(s) at the plug for the trailer. Since the tail lights also come on with the running lights. Are you sure that the turn signal lights are weaker or just being masked by the tail lights being on. With one turn signal on, step on the brakes and see if there is a difference in brightness between the brake light on one side and the turn signal on the other. Unless you have amber turn signals which are totally separate from the brake lights. The same filament is used for the brake and turn lights. I'd be cleaning bsttery terminals and trailer connectors and checking for lose connections before buying anything.
Old 04-02-2010, 09:48 AM   #8
1980 31' Excella II
Drummond Island , Michigan
This is probably a very common ground problem between the TV and the A/S. If the lights (running and turn signals) work well with the trailer isolated from the TV. There could be another problem that is really hard to discover and easy to fix. A friend of mine who happens to be a Ham operator with an advanced license and excellent electrical knowledge was having the same problem as described with good running lights and weak turn signals. He went over every inch of his T/V and trailer and was losing sleep becuause he could not troubleshoot the problem and solve it. He asked me to take a look at it. I knew what he had done up to that time and it was everything I would have done but to help him out I said ok. The first thing I looked at was the lights themselves I wanted to make sure there wasn't some fault, moisture broken or cracked recepticle, etc. Took the lense off and pulled the bulb on one side and discovered that the bulb had been installed incorrectly. Those are double filament bulbs with a high and low post on the base. Somehow the bulb was jammed in with the posts reversed. Don't know how it happened or how he managed to do it to both the right and left sides. But it is a simple fix tough to find like most electrical problems.
Ahzmyrah is offline   Reply With Quote
Old 04-02-2010, 09:52 AM   #9
toastie's Avatar
1955 22' Safari
Starting over
1) 2008 GM TV with towing package, works great with our other trailer
2) The bargman cable is brand new.
3) This is a full restoration with interior panels off with all new wiring.
And this is how I have it hook-up so far:
1) Brown wire....Right Stop & Turn....one wire to bargman brown wire and the other to the bargman white common ground
2) Red wire.......Left Stop & Turn......one wire to bargman red wire and the other to the bargman white common ground
3) Green wire....Tail & License and Running lights.........all wire's to green bargman
4) Black wire.....Battery Charge.....one wire to positive battery post and to bargman black wire battery, negative post ground to shell
5) Blue wire ......Electric Brake.......haven't hook-up yet
6) Yellow wire....Center Auxiliary.....haven't hook-up yet and don't know what in the hell it is.
Old 04-02-2010, 10:10 AM   #10
1967 22' Safari
1960 Caravel
Images: 8
Starting over
Which Airstream is this and did you rewire the trailer or just attach a new 7-pin connector?
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
Old 04-02-2010, 10:25 AM   #11
toastie's Avatar
1955 22' Safari
Old 04-02-2010, 10:53 AM   #12
1967 22' Safari
1960 Caravel
Images: 8
Starting over
Brown wire running lights
Green wire right turn and brake
Yellow wire left turn and brake
Take a look here. etrailer.com | Trailer Wiring Diagrams. Scroll down for 7-way.
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
Old 04-02-2010, 11:10 AM   #13
toastie's Avatar
1955 22' Safari
Wrong wiring diagram, below is the correct one for my job, thanks anyway......
ID:	99263   Click image for larger version
Old 04-02-2010, 11:42 AM   #14
Bettye's Avatar
2010 25' FB International
Mobile , Alabama
Images: 18
Hubby is having trouble with brake lights and turn signals. I hope this info will help him determine the problem so we can get this show on the road!
Bettye is offline   Reply With Quote
Old 04-02-2010, 11:49 AM   #15
Florissant , USA
On my 53, I run the red and brown wire to their respective lights, but the grounding of the lights come from attaching the fixture to the shell. I guess the lights are different.
Steve
Old 04-02-2010, 12:11 PM   #16
toastie's Avatar
1955 22' Safari
Steve
I think you just solved one of my problems, I was running ground to the bargman common ground when I should be grounding the light right to the shell, will give it a try..........thanks
Old 04-02-2010, 12:19 PM   #17
1967 22' Safari
1960 Caravel
Images: 8
Hard to wire over the Internet. Just curios, what is the diagram from?
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
Old 04-02-2010, 12:23 PM   #18
toastie's Avatar
1955 22' Safari
Sure
Bargman 7-Way Cable
Old 04-02-2010, 12:29 PM   #19
1967 22' Safari
1960 Caravel
Images: 8
Is the Chevy side wired by you or the factory? I'm concerned that two different standards are being used.
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
Old 04-02-2010, 12:43 PM   #20
toastie's Avatar
1955 22' Safari
factory
Running lights nilesrob Lights - Interior & Exterior 16 10-09-2010 06:36 PM
No running lights or tail lights... goswick Lights - Interior & Exterior 24 02-27-2010 09:31 AM
Running lights Devoman Our Community 16 03-21-2006 08:45 AM
No Running Lights Craftsman Electrical - Systems, Generators, Batteries & Solar 5 09-12-2005 07:47 PM
Running Lights/Backup Lights 85 Sovereign GRAYMAN Lights - Interior & Exterior 7 08-10-2004 08:54 AM
