Old 01-19-2017, 09:52 AM   #1
Registered User
2018 33' Classic
McKinney , Texas
Send a message via AIM to Herm26U Send a message via Yahoo to Herm26U
Porch Light - Yellow?
Is it possible to change the led light over the door to yellow to help avoid attracting bugs?
Thanks!
Herm26U is offline   Reply With Quote
Old 01-19-2017, 10:16 AM   #2
Boxite's Avatar
2008 22' Safari
Amber LED lamps are available online.
https://www.ledlight.com/ is one place I've found them.
It's important to realize that simply installing a yellow (Or any color for that matter) lens does not usually work well. The reason is that a colored lens is a filter.... and of the entire color-spectrum emitted by a lamp... all spectrum NOT in the lens-color is blocked, therefore the total light emitted is reduced and often the amount of spectrum within the lens-colors is very small.
Example: I put a bright-white LED behind a red lens... and got a low-light amber. I put a bright-white LED behind a green lens...and got blue.
The BEST solution is to order the LED in the desired color...AND place it behind the desired color lens. For example, I found a RED LED behind a RED lens...gave an EXTREMELY BRIGHT RED light, and a Green LED behind a Green Lens gave a very bright GREEN. This made sense because the lens allowed the primarily red or green LED to pass thru the majority of it's lumens.
Hope that helps.
Old 01-19-2017, 10:17 AM   #3
Hittenstiehl's Avatar
1962 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
A yellow gel film, (that's not the official description) placed inside the glass would likely accomplish it.
The kind they use for movie sets, stage performances they can take the heat.
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
'Porch' Light Replacement Fixture with 1141 Bulb AirConditioner Electrical - Systems, Generators, Batteries & Solar 4 09-10-2015 11:56 PM
Yellow light roof corner have water in it!!! Tino643 General Repair Forum 6 05-10-2013 09:50 PM
yellow wire in right rear light assembly. robertel Lights - Interior & Exterior 6 09-18-2010 06:14 AM
Tail light red, green, yellow wires? PKelley Electrical - Systems, Generators, Batteries & Solar 2 06-08-2005 07:28 AM
The $8 Porch Light Silverfly 1960 - 1964 Overlander 2 09-21-2004 06:25 PM
