Old 11-26-2015, 10:58 AM   #1
Tincampers's Avatar
Sneedville , Tennessee
need 12v in bathroom
I need to get a 12v line into the bathroom. The refrigerator is between the bathroom and the power panel. What's the best route?
I have this floorplan:
Tincampers is offline   Reply With Quote
Old 11-26-2015, 11:19 AM   #2
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
I would consider tapping into the 12v supply behind the fridge (use the outside access door to get to this) then run the line into the bottom of the vanity cabinet from there. The fridge only uses 12v to power the logic board so there is plenty of capacity for most 12v devices so tapping in there shouldn't be an issue. If you don't want to do this and want a dedicated 12v line, you can still run it from the power panel snaking it behind the fridge (using the access panel to get the line across the back of the fridge) and into the vanity.
Bob Martel
WBCCI# 5766
Old 11-26-2015, 11:35 AM   #3
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
We have the same floor plan. Here is some in-progress photos of our living area/recliner conversion, it shows what things look like behind the converter/charger in a couple photos. Maybe you could tap into it there, and run a 12v line under or through the fridge compartment.
https://www.flickr.com/photos/398600...7637145551816/
Doug and Cheryl
Old 11-26-2015, 11:35 AM   #4
Tincampers's Avatar
I'm just powering a small fan so, using fridge power shouldn't be a problem. Thanks.
Old 11-26-2015, 11:42 AM   #5
Tincampers's Avatar
That looks really nice. I have tried this fish under the fridge but can't seem to get all the way through. Do your new cabinets match the original?
Old 11-26-2015, 11:51 AM   #6
dkottum's Avatar
In the photo it looks like some of the wires go through a space under the fridge but I didn't pay much attention at the time.
We had the work done at Jackson Center so they used all Flying Cloud factory material to match everything. Interesting, this is one of the few (maybe only) late Airstream floor plans where you can pull out the dinette/lounge and have an open space for any conversion that suits you.
Doug and Cheryl
Old 11-26-2015, 12:06 PM   #7
Tincampers's Avatar
Very nice. I'd probably have to sell a kidney to duplicate that setup.
Old 11-26-2015, 06:56 PM   #8
Tincampers's Avatar
Managed to get a wire from the fridge compartment into the bathroom. Took some mild cussing but nobody got hurt.
Old 11-27-2015, 11:38 AM   #9
loudruff's Avatar
1978 Argosy Minuet 6.7 Metre
1989 29' Excella
Lorain County , Ohio
Send a message via AIM to loudruff Send a message via MSN to loudruff Send a message via Yahoo to loudruff
That's weird that they discontinued 12v in the bathroom. Our 1989 has an outlet under the upper mirrored cabinet, above the sink. The Argosy 1978 has it inside the mirrored cabinet. Glad you got it done with only mild cussing.
Larry and Lou
CP: Water/30 amp/waste dump/WIFI & Room for 2-3 units; PM us if you are headed our direction!
Air #2695
TAC- OH 2
#1420 NOVA 4-006 Charter member
loudruff is offline   Reply With Quote
Old 11-27-2015, 12:59 PM   #10
Tincampers's Avatar
This model has no upper cabinets in the bathroom as it has a window in there. Not sure if there is 12v in the FB. The only 12v outlet is in the front overhead cabinet.
Old 11-27-2015, 01:13 PM   #11
greghoro's Avatar
2013 25' Flying Cloud
Wheaton , Illinois
Aren't the lights in the bathroom 12v?
Couldn't you somehow leverage that circuit?
Greg
greghoro is offline   Reply With Quote
Old 11-27-2015, 01:34 PM   #12
Tincampers's Avatar
Greg
I looked at that, but there is a rib between the newest light and where I needed ti wire to be.
Old 11-27-2015, 01:37 PM   #13
loudruff's Avatar
1989 29' Excella
That's Airstream! 2 steps forward, one step backwards!
Larry and Lou
Air #2695
TAC- OH 2
Old 11-27-2015, 01:41 PM   #14
Tincampers's Avatar
Or is it 1 step forward 2 steps back. Sometimes (actually a lot of the time) I wonder who makes the decisions on the products that they use in their trailers.
Old 11-27-2015, 01:48 PM   #15
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Probably a bean counter that has never used one of their products. Only the cheapest components will do.....
12v
LCD Tv has a 12v converter... Can I use it on 12v? Keyair Audio, Video & TV 6 05-11-2010 03:40 PM
Bathroom vanity and Bathroom vent lights... sovereignrwe Electrical - Systems, Generators, Batteries & Solar 10 01-05-2010 06:30 AM
Can I Replace 12v light with AC fixture and still work off 12v M&M CAPECOD Electrical - Systems, Generators, Batteries & Solar 5 07-11-2005 10:58 AM
