07-14-2011, 04:50 PM
1967 24' Tradewind
Greenville
, South Carolina
Light switch question
I see all kinds of 12V switches for sale. They are usually toggle/ or rocker type. Will a regular household 110V light switch work for 12V switching?
07-14-2011, 05:18 PM
1972 31' Sovereign
Lexington
Yes
Chris
07-14-2011, 05:27 PM
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown
Some of the 50's and early 60's trailer used them in the 12 volt systems and i have used them in some added circuits
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
07-14-2011, 06:00 PM
1967 24' Tradewind
Greenville
, South Carolina
Thanks Chris and Rick. I thought so. There was a switch on the ceiling as you entered my 67 that I think probably was for 12V lights. Since I tore it apart prior to checking I thought it best to be sure. Bet it is a bad idea vice-versa though.
07-14-2011, 08:04 PM
Airstream - Other
Bosque Farms
That household-looking switch runs the light over the galley area. It's double-switched, so for the switch above the door to work, the switch at the light itself has to be on, too. It's mighty handy if you wind up coming back to the rig in the dark.
Lynn
ACI Big Red Number 21043
07-15-2011, 06:29 AM
1967 24' Tradewind
Greenville
, South Carolina
Too late
Lynn
Thanks for the info!
Too late now, mine is now wired to turn on the ceiling lights...when I get them
07-15-2011, 07:23 AM
1961 24' Tradewind
1969 29' Ambassador
Jamestown
The switch in my 61 located in the ceiling slightly to the right of the door is for the main ceiling 120 volt lite.
Possibly by 67 they had gone to all 12 volt lights.
13 Ram 2500 TD
07-15-2011, 07:39 AM
Airstream - Other
Bosque Farms
Yep, you're right. There are no high-voltage lights in the 67. The only things run by the 110v. system are the converter, the AC, the 110v. outlets, and the fridge (if switched to that setting).
Lynn
07-15-2011, 07:51 AM
Central
, Mississippi
I spent a few years designing switches and can confirm the 110v switches, although they will usually work, will fail sooner than they are supposed to when used on 12v...be prepared to only get, say 5,000 cycles instread of, say, 10,000
My '63 has the same switches for 12V as the 110V lighting...
07-15-2011, 08:13 AM
1972 31' Sovereign
Lexington
If you mean using a 12 volt switch for a 110 VAC circuit, it depends on the switch. In general, you're right. But there are some switches out there sold as 12 VDC switches, that if you read the specs, are rated to switch 110 VAC circuits as well.
Chris
07-15-2011, 08:44 AM
1961 24' Tradewind
1969 29' Ambassador
Jamestown
I hate it when a switch fails after only 5000 cycles
13 Ram 2500 TD
