Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Lights - Interior & Exterior
Old 07-02-2018, 05:24 PM   #1
RxGuy's Avatar
2010 27' FB International
Deforest , Wisconsin
LED running light plastic mounting tabs broken......
Hi all,
While washing the trailer today I came across an LED running light that was loose from the base. The light still works. One of the two dinky little tabs that snap into the base has broken off.
I just want to use some sort of adhesive to put it back in place on the base.
What have you used to do this?
I was thinking of maybe a clear silicone.
Would there be anything better?
Hope everyone has a great 4th!!!
Blair
RxGuy is offline   Reply With Quote
Old 07-04-2018, 07:30 AM   #2
Dan@LED4RV's Avatar
Denton , North Carolina
something stronger
Originally Posted by RxGuy View Post
Hi all,
Blair
I would think you would need to use something stronger and more permanent that silicone. Since what you use is not going to be seen I would use an epoxy in a small amount. If at some point the light has to come off you should be able to break it away from the base being that they are both plastic. This light is only sold with the base so if it breaks, when you take it back apart, your not out anything.
Dan Brown
Denton NC
Dan@LED4RV is offline   Reply With Quote
Old 07-04-2018, 09:23 AM   #3
RxGuy's Avatar
Thanks for the feedback. I didn't know that the base and light come together as a unit. In that case, epoxy definitely would be better than the silicone.
Blair
Window curtains with plastic tabs button and elastic for 78 landyacht javaschlava Airstream Classifieds 0 04-26-2015 11:36 AM
Various Interior Parts: dinette cushions, curtains, curtain tabs, 12 V light, writing table AustinAnnie Airstream Classifieds 2 01-23-2014 08:36 AM
Broken plastic rear light? Argosy facade on rear tomzargosy All Argosy Trailers 9 06-11-2011 10:45 PM
Clipper, Hella LED, Design Line Hella, LED Kit, Stop/turn LED masseyfarm Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 1 12-15-2010 11:03 AM
