Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Lights - Interior & Exterior
Old 07-22-2007, 08:05 PM   #1
ole81
ole81's Avatar
Profile:  1981 31' Excella II
Richmond , Texas
Angry broken ceiling light toggle switch
Hi Folks,
Can anyone shed light on how to remove/repair/open a ceiling light toggle switch? today I switched it on, and am unable to toggle it off. I had to remove the cover and remove the bulbs so that it would not drain my battery.
Thanks.
Bob and Gail
31' 1981 Excella II
2001 F250 Crew, 8' bed, Pullrite hitch.
ole81 is offline   Reply With Quote
Old 07-22-2007, 08:11 PM   #2
Ganglin
Ganglin's Avatar
Profile:  1971 27' Overlander
Gahanna , Ohio
Any chance you can post a photo of the offending switch....
OHIO - WE ARE THE MOTHER SHIP
Gary
Old 07-22-2007, 08:56 PM   #3
ole81
ole81's Avatar
Richmond , Texas
Smile picture of stuck switch
Thanks for the quick reply.
Am attaching a picture of the switch..
The base (touching the ceiling) is a slightly darker shade then the toggle and its surround.
Bob and Gail
Old 07-22-2007, 09:02 PM   #4
WayWard Wind
WayWard Wind's Avatar
Profile:  2004 25' Safari
slide something flat and thin behind the large outer cover and GENTLY pry the cover away from the switch section. This will expose the switch it's self, which is fasten to a bracket of sorts. From there you can fix and/or replace. Be gentle and go slow.
Best,
Home of the Wayward Wind
Bogfrog & Mr. Turbo
If in life you stumble, make it part of the dance
WayWard Wind is offline   Reply With Quote
Old 07-23-2007, 03:53 PM   #5
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
Bob and Gail
Unfortunately, that switch has not been available from Airstream for some time.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Old 07-23-2007, 04:15 PM   #6
Pop Rivet
Pop Rivet's Avatar
Profile:  Salt Springs , Florida
Smile
Bob and Gail
Lucky you - I have a couple you may have - The outer frame measures 2 and 1/4 by 1 and 3/8ths inch. No lettering on toggle. PM me an address and I'll send them to you.
Pop Rivet is offline   Reply With Quote
Outlet under sink, night light LI Pets Electrical - Systems, Generators, Batteries & Solar 5 09-24-2006 06:25 PM
Broken wiring in tail lights Argosy74 Electrical - Systems, Generators, Batteries & Solar 4 10-23-2002 10:09 PM
Rotary Light Switch 74SovereignInt. Electrical - Systems, Generators, Batteries & Solar 20 10-15-2002 07:31 PM
What the heck is that switch on the wall??? TRAPEZE Airstream Motorhome Forums 7 09-10-2002 05:05 AM
Oven gas line broken lbrodsky LP Gas, Piping, Tanks & Regulators 4 07-23-2002 04:52 AM
