Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 02-06-2017, 09:01 AM   #1
brattwurzt's Avatar
1968 30' Sovereign
Baltimore , Maryland
Trapless Shower Drain
Am I crazy? Because I am very tall, I'm thinking of draining my shower directly into my grey tank using a trapless drain. Can anyone think why this could not work?
dreamin' of streamin'
brattwurzt is offline   Reply With Quote
Old 02-06-2017, 09:13 AM   #2
jdalrymple's Avatar
2009 27' FB Flying Cloud
1982 31' International
1991 35' Airstream 350
Jay , Oklahoma
The smells from the grey tank will vent directly into the shower.
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud;'82 31 International
'91 350 LE MH; '21 Interstate 24GT
Old 02-06-2017, 09:16 AM   #3
brattwurzt's Avatar
1968 30' Sovereign
Regards,
JD
A trapless drain does not allow gasses to escape.
http://proventsystems.com/product-so...uard/overview/
Old 02-06-2017, 09:19 AM   #4
jdalrymple's Avatar
Jay , Oklahoma
My bad,
I didn't see you mentioned a special drain fitting.
Regards,
JD
Jeff & Cindy
Old 02-06-2017, 09:26 AM   #5
1978 25' Tradewind
1954 15' Byam Holiday
Linden , Michigan
Future Considerations
Over time, you will have to replace the drain once the SMELL starts entering your shower. They do not last forever.
StevieB is offline   Reply With Quote
Old 02-06-2017, 10:18 AM   #6
Sag Harbor , New York
Could you post a link or spec sheet for that drain? Never heard of one, but maybe it would work OK. What prevents the gases from the grey tank coming back up into the shower?
PS -- edit -- like these?
http://www.supplyhouse.com/SureSeal-...FQiBswodE_8PZA
http://www.kessel.com/products/drain...multistop.html
Do you have to manually engage the rubber seal each time you leave the shower? If it does not seal well, and the grey tank is really full, won't the contents slosh out/up into the shower while the trailer is being towed?
Old 02-06-2017, 11:05 AM   #7
brattwurzt's Avatar
1968 30' Sovereign
They have a video.
Old 02-06-2017, 11:30 AM   #8
Thanks. Pretty neat.
Old 02-06-2017, 11:40 AM   #9
Rivets?
nvestysly's Avatar
1992 29' Excella
2010 22' Interstate
Van By The River , Georgia
Seems like an interesting product. I watched the video as well as looking at several of the PDF files showing dimensions for the installed drain. The dimensions were not entirely conclusive.
Do you really save any vertical space? It appears the "tongue" of the trapless drain will end up submerged in gray water as the tank approaches the full level. Will the drain still work when it's submerged? If it still works when submerged then you may be saving some space. Be sure to double-check all the dimensions before designing this into your system.
Keep us posted if you decide to use the system.
Lucius and Danielle
1992 29' Excella Classic / 2010 Interstate
2005 Chevrolet Suburban K2500 8.1L
2018 GMC Sierra K1500 SLT, 6.2L, Max Trailering
Got a cooped-up feeling, gotta get out of town, got those Airstream campin' blues...
nvestysly is offline   Reply With Quote
Old 02-06-2017, 12:05 PM   #10
brattwurzt's Avatar
1968 30' Sovereign
I have to think if there is space in the tank, the higher water will find it's way down. Yes, I would purchase the drain and internals prior to committing to the install.
Old 02-06-2017, 12:46 PM   #11
AlinCal's Avatar
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez , California
If I were to try using this I would design for the tip of that flapper to be no lower than the top of the tank and not submerged at all, so whether that gains you anything or not you need to calculate.
My thought of keeping it out of the tank is to keep it flushed every use so that hair or any other nasties don't build up and keep it from sealing 100%, I also doubt it does seal 100% so tank slouching on the road could leak thru.
My 2 cents
Alan
AlinCal is offline   Reply With Quote
Old 02-06-2017, 03:13 PM   #12
brattwurzt's Avatar
1968 30' Sovereign
My 2 cents
Alan
I was sort of thinking the same thing, but then again, who runs their grey tank that full? If you notice the drain slowing, you can always let out some grey water.
Old 02-06-2017, 03:48 PM   #13
Kevin245's Avatar
I think this will work fine and my bet is that once the tank is full and there is no water flowing into the gray tank, the rubber flap will simply close, eliminating any significant backup.
BTW when we have full hookups I typically leave the bath gray tank valve open.
Might try contacting the manufacturer.
William C. Swinney
Re working kitchen drain- pex for drain lines?? bwilson1 General Repair Forum 4 04-20-2014 08:42 PM
Shower drain seal Safari Tim Waste Systems, Tanks & Totes 6 08-15-2004 11:18 PM
A/C Drain ...leaking at drain hose connection Sav'h Steve Furnaces, Heaters, Fireplaces & Air Conditioning 5 08-01-2004 04:09 PM
Shower Drain Dbraw Sinks, Showers & Toilets 1 03-12-2003 10:59 PM
Shower drain plug Zed2 Sinks, Showers & Toilets 1 01-04-2003 05:33 PM
