Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 08-14-2017, 09:46 AM   #1
@steadystreamincashios
Zcashio's Avatar
1968 28' Ambassador
1964 26' Overlander
1976 Argosy 26
Heber Springs , Arkansas
Composting toilet questions and draining grey waste
Sorry if this has been asked before. But I'm getting ready to close up the underside of the trailer with the new belly pan and since I will not have any sewer waste from a toilet, do I have to have a 3" connection?? All that will be used is sinks and shower. So no solids at all. Could I just have a 1/2" water hose adapter or at the most a 2" adapter?
Thanks for the help.
Zcashio is offline   Reply With Quote
Old 08-14-2017, 10:26 AM   #2
1979 23' Safari
Wayland , New York
I think you'd be best off keeping a 3" connection for several reasons. 1. With the nice big pipe you can get a good speedy flush to help get gunk out of the grey water tank. 2. Rv sewer hose size will be 3". 3. Most campgrounds want tight connections between sewer connection and hose, you'll probably have a hard time getting that from a off size hose going into a campground rv dump connection.
You'll still get some solids from the sinks and shower, you want to be able to get them flushed out with a speedy flush.
Old 08-14-2017, 10:38 AM   #3
LifeIsRiveting's Avatar
1976 25' Caravanner
Kansas City , Kansas
I came to the same conclusion as HiJoeSilver and I too am about to close up the belly pan with gray only plumbing. It all came down to the fact that 3" hoses are readily available and fit right up to dump stations. It is really hard to find 1.5" hose of any type, especially one that has a smooth interior and is flexible/compact.
So all my plumbing is 1.5" until after the gate valve where it curves 90* and turns into a 3" connection. It's hard to explain but I recently posted some pics on instagram (lifeisriveting)
Follow our shell-off renovation on Instagram @LifeIsRiveting
LifeIsRiveting is offline   Reply With Quote
Composting Toilet- Shower- Grey tank ?'s Monza Sinks, Showers & Toilets 1 07-19-2016 06:11 PM
Combining the Black and grey tanks after installing a composting toilet Chrisy Boondocking 1 03-06-2016 08:00 PM
Can the waste tank be partially used in a composting system blkmagikca Waste Systems, Tanks & Totes 9 02-02-2016 07:06 PM
grey water draining help needed dereks57 Waste Systems, Tanks & Totes 2 05-26-2013 08:26 PM
Your questions about our Composting Toilet FLYNCLD Waste Systems, Tanks & Totes 55 03-28-2011 05:04 PM
