Originally Posted by bredlo
RV systems are designed to push water in and out of the toilet, whereas the hand pumps in these marine heads aren't.
You've got it just backwards (if I understand what you're saying).
RV toilets operate like a glorified outhouse - the waste falls from the bowl into the tank below when the foot valve is opened and pressurized water is allowed in to clean the bowl. An RV toilet hooked up to an elevated water tank could be used to make a nicer outhouse.
Study the photo of the Blakes Baby to understand how a marine head works. The baby has separate pumps for flush water and waste ejection so it's operating functions are easily seen.
The T handle of the flush water pump when pulled upward draws flush water into that pump. A downward push pumps the water into the bowl.
The black handle of the waste ejection pump when pulled upward draws the waste and flush water mix from the bowl into the ejection pump. A downward push pumps the waste mix into the holding tank.
In the W-C head that you have, the two pumps have been replaced with one pump for both functions. The two different functions happen according to the position of the foot valve when the handle is operated. That's why it's possible to get fresh water contamination with that head since it was designed to use sea water for flushing rather than potable water. All marine heads operate using these two functions but there is a wide variety across models in the implementation.
