11-13-2015, 06:40 PM
Airstream Driver
1994 30' Excella
1992 35' Airstream 350
Austin
Water heater temp adjustment-auto ignite system
I just replaced the old circuit board on my water heater to fix the auto ignite.
Now the water gets extremely hot and I am not sure if it would shut off by itself.
How do you adjust the Temp on these? The manual water heater i have in my other trailer has a manual lever for the temp setting.
AIR #13
11-13-2015, 07:24 PM
2008 27' Safari FB SE
Miami
There is a disk shaped thermostat that cuts off the burner at 160f. There is a backup, the ECO (emergency cut off) that will open at 190.
So, yep, your RV water heater is set to deliver water that is about 40f hotter than a residential w/h. It helps to compensate for the fact that you only have 6 gallons (well, sometimes 10)
Let it run until it quits, then measure the water temp
Mike
Middle-aged Safari SE
Young, lovely bride
Dismissive cat
11-13-2015, 07:28 PM
Rivet Puller
2003 28' Safari S/O
Atlanta Burbs
If you decide the temperature is too hot, you can purchase thermostats, 'disks,' with a shutoff temperature with another setting, e.g., 140, 130, etc.
11-13-2015, 07:32 PM
1999 34' Excella
Hillsboro
Peter,
Try this link Service Documents and Manuals
Also check that the temp sensor to the right of the exhaust vent is in contact with the water tank.
Peace and Blessings..
Channing
WBCCI# 30676
11-13-2015, 08:06 PM
Airstream Driver
1994 30' Excella
Austin
Originally Posted by cwf
Peter,
Thanks everyone for the replies and thanks for the docs link, Channing.
I would check the temp sensor contact, if there would be one ??
I am puzzled by the way the temp is read on this old system .
AIR #13
11-13-2015, 08:21 PM
1999 34' Excella
Hillsboro
There should be wires going to a round "disc" component then the board.
Look to the lower right of your exhaust vent of the water heater. I think I can see one there in your picture.
Channing
WBCCI# 30676
11-14-2015, 07:02 AM
Airstream Driver
1994 30' Excella
Austin
That would be just too easy, wouldn't it Channing
What you see is a plastic wire holder
AIR #13
11-14-2015, 07:20 AM
1999 34' Excella
Hillsboro
Peter, there MUST be a sensor...
Do you have the model? I will try to locate in drawing for you.
We can then find the correct wire on your BOARD that the sensor attaches with. Then you can test
Channing
WBCCI# 30676
11-14-2015, 07:37 AM
Airstream Driver
1994 30' Excella
Austin
I understand the logic and wiring. its the brown power wire going to the circuit board that is the supposed to have the sensor, but it goes straight inside the wall. I will have to dig deeper from the inside later, when I have time. I will look for the model number as well.
thanks Channing
AIR #13
11-14-2015, 10:36 AM
Airstream Driver
1994 30' Excella
Austin
found the sensor and the thermal cut -off switch at the back of the unit. Took some dismantling and digging to get to.
Thermostat says 140 degrees as some of you suggested, but my unit did not shut off until the water temp was 165 degrees and it took well over 1 hour to get there. I am sure part of the reason is the 2 radiator hoses connected to the unit.
I removed the thermostat and cleaned the surfaces and made sure that a good contact was made and now it shuts off at 155 degrees. Still a bit hot for my taste, but it will allow for longer showers.
Thanks for all the input
AIR #13
11-14-2015, 11:44 AM
Rivet Puller
2003 28' Safari S/O
Atlanta Burbs
You may need to remove the sensor again and install it correctly. By that, I mean use thermal grease between the surfaces. That is the only way to ensure proper contact and an accurate temperature reading. Here is an example of the product:
Cooler Master Co., Ltd HTK002U1 - Best Buy
11-15-2015, 06:50 AM
Yertle01.com
2006 22' International CCD
Estes Park
I have the same problem, so I asked my local Airstream dealership to check it out and lower the temperature if possible. They told me they researched it and that there is no adjustment, so I just turn the water heater off in the morning after about 20 minutes or so, and turn it back on again in the afternoon for about 20 minutes or less when the water is no longer hot enough for doing dishes or whatever.
Terry P. Rizzuti, "Yertle"
TRizzuti.com
Yertle01.com
"My two cents is worth every penny."
11-15-2015, 07:49 AM
Airstream Driver
1994 30' Excella
Austin
They must not have spent much time researching.
With the help of the kind folks of this forum, i was able to diagnose and find the right remedy:
120-Degrees-Fahrenheit-Water-Overheat-Thermostats-4-DC-water-heater-element | eBay
AIR #13
11-15-2015, 07:19 PM
1999 34' Excella
Hillsboro
If you want specific temp sensors, your local AC or industrial supply (Granger, McMaster Carr, etc) may have just what you need... And it won't have the "Airstream penalty" ( higher cost).
Channing
WBCCI# 30676
