Old 10-22-2016, 07:12 PM   #1
2013 27' FB International
mamaroneck , New York
Water heater problem
On the road and just lost our hot water. Doesn't work on shore or gas. Used to get a brief light on switch. Now nothing check fuses all look good any ideas?
jackanddiane is offline   Reply With Quote
Old 10-22-2016, 07:37 PM   #2
Vintage Kin
Fort Worth , Texas
Search via google "airforums" "water heater" "no heat".
There's a list of things to run thru. Power and or gas is first.
Get brand, size, year, and model number.
Mines so old (1989) that some of the info won't apply.
Plenty of info online via this or other forums.
1990 35' Silver Streak
2004 555 Cummins
Old 10-22-2016, 09:05 PM   #3
honi soit qui mal y pense
Robere's Avatar
2015 23' FB Flying Cloud
Bend , Oregon
Brief light is normal so you have another issue. Possibly electrical. Check fuses? Previous advice to Google should move you toward resolution. If you heat a bit of water on the cooktop you could take a "spit-bath".
Robere & Jacqueline &
Mia (the mini-poodle)
2016 Chev Silverado LT Crew 4x4
Robere is offline   Reply With Quote
Old 10-23-2016, 01:20 AM   #4
2005 19' Safari
GLENDALE , AZ
Links to water heater troubleshooting tips:
Atwood Water Heater Replacement Parts - AirForums.com
Old 10-23-2016, 03:16 AM   #5
Sag Harbor , New York
Welcome to the forum!
-- check all electrical connections in heater compartment for corrosion etc.
[remove/clean/sand/dilectric grease/etc]
-- other gas appl. OK? -- cooktop/oven/fridge on gas/low pressure port outside
-- battery voltage OK? -- please provide voltage number
-- can you get water heater to fire again maybe? -- describe events/time before shutdown
-- spider nests in the flue pipe?
Thanks for these details, and good luck!
Peter
PS -- Great video Phoenix, thanks, and good link to earlier thread. jackanddianne, does the video cover your model of water heater? Do you have an electric meter with you? After implementing the suggestions in the video, please advise. Thanks.
Bowen water heater door with newer suburban water heater durans54 Water Heaters, Filters & Pumps 37 11-19-2008 07:17 AM
Water Heater Problem LowellN Water Heaters, Filters & Pumps 5 04-01-2006 08:01 PM
Water Heater Problem Cracker Water Heaters, Filters & Pumps 3 06-11-2004 07:42 AM
Bowen water heater problem, anyone know what to look at? Silverfly Water Heaters, Filters & Pumps 4 05-04-2004 10:56 AM
water heater problem Stefrobrts Water Heaters, Filters & Pumps 4 10-23-2003 08:55 AM
