Originally Posted by jackanddiane
On the road and just lost our hot water. Doesn't work on shore or gas. Used to get a brief light on switch. Now nothing check fuses all look good any ideas?
Welcome to the forum!
-- check all electrical connections in heater compartment for corrosion etc.
[remove/clean/sand/dilectric grease/etc]
-- other gas appl. OK? -- cooktop/oven/fridge on gas/low pressure port outside
-- battery voltage OK? -- please provide voltage number
-- can you get water heater to fire again maybe? -- describe events/time before shutdown
-- spider nests in the flue pipe?
Thanks for these details, and good luck!
Peter
PS -- Great video Phoenix, thanks, and good link to earlier thread. jackanddianne, does the video cover your model of water heater? Do you have an electric meter with you? After implementing the suggestions in the video, please advise. Thanks.
