10-19-2014, 07:24 AM
2005 19' Safari
2007 23' Safari SE
Onekama
, Michigan
Water Heater, one and done
We have an Attwood hot water heater, LP only. It worked great until this last outing. It ignites as it is suppose to once and not again. It will heat the water, not excessively, shut off and and not relight. It will then require turning off, waiting for awhile, then turning back on. ???
10-19-2014, 08:18 AM
Overland Adventurer
2009 34' Panamerica
Telluride
Try unplugging the electrical connector a few times. Those connections can oxidize resulting in poor performance. A little smear of light grease on all the connections helps. If not this check your high limit switches, then unfortunately the circuit board itself. If yours is old enough not to have a fuse on the board, then it's highly probable the board is shot..... The unfused design had a weak trace.
Best luck
10-19-2014, 02:40 PM
2005 19' Safari
2007 23' Safari SE
Onekama
, Michigan
Thanks for the reply and advise. I have cleaned the clean appearing connections with a wire brush. Brush cleaned the igniter. The control board appears to have a fuse. It's a 2005 model. After more intensive experimentation, the water will heat but not a complete 6 gallons. In running the water after it has run and shut itself off, I'll get about 2-3 quarts of hot water, then all cold. Again, then I have to shut it off and wait a considerable amount of time and retry. If it has been off long enough, when I turn it back on it will relight. But it will not on it's own.
10-19-2014, 02:53 PM
2014 27' FB Eddie Bauer
Chelsea
, Michigan
In my humble opinion, I would not mess around with a propane device unless you have a lot of experience with them. I would take it to Woodland RV just north of GR.
Best of luck!
1,
Bob Martel
WBCCI# 5766
10-19-2014, 04:07 PM
Overland Adventurer
2009 34' Panamerica
Telluride
Ok sounds like the hi limit switches are bad. These are $11 at any rv dealer, it's a quarter turn replacement type deal! This is a normal user friendly repair.... The 2 quarter sized thingies under the black foam....
10-21-2014, 07:45 AM
1995 30' Excella
Bowie
, Maryland
Yep, start with the thermostat and ECO. They're cheap and easy to replace, and do sometimes fail.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
10-24-2014, 03:13 PM
2005 19' Safari
2007 23' Safari SE
Onekama
, Michigan
One and done
Replaced the E.C.O. and Thermostat. Absolutely, no difference. I get one gallon of hot water and the rest luke warm. This after running about 45 minutes. The flame is robust and I would have thought I would get more hot hot water, but there was also cold water replacing at the same time. Which would ordinarly tell the heater to restart. It does not. Now what the Circuit Board?
10-24-2014, 08:22 PM
1974 Argosy 26
Morrill
, Nebraska
Are you sure the water heater is not in bypass mode ?
Will it relight on it's own after you run out of hot water?
Is there a thermostat on your particular model? Big red knob on the gas valve.
Sounds to me like the high temp limit. But more like a thermostat. Since you have an electronic controller. It could also be the culprit.
10-24-2014, 09:05 PM
Overland Adventurer
2009 34' Panamerica
Telluride
It does sound like it might be in bypass mode, then again could be the circuit board. It's free to check the bypass valve, $140 for the replacement board. They can fail quickly.
10-25-2014, 06:47 AM
2005 19' Safari
2007 23' Safari SE
Onekama
, Michigan
I have been humbled and my ignorance/stupidity exposed. At the same time I'm very happy to say thanks everyone for staying with me on this and convincing me to check the position of the by-pass valves. It was in particial by-pass mode. That probably makes me sound even dumber. Right now I don't care. For the small price of the ECO and T-stat that I replaced, I'll consider it preventive maintenance.
Thanks again. Now, I can put it away till February.
10-25-2014, 08:46 AM
Overland Adventurer
2009 34' Panamerica
Telluride
Nah....
Just remember all this next spring!
Happy winter, it's 95 in Phoenix today, hot hot hot!
10-25-2014, 08:50 AM
1974 Argosy 26
Morrill
, Nebraska
We have all been there in one way or another. Glad you were successful.
