Old 07-09-2011, 03:28 PM   #1
1989 34' Excella
Holly , Michigan
Dinosaur board question
I just bought a Dinosaur board for my water heater and when I installed it will not work. It is getting power (green light is lit) but nothing else. Do I need to cut the jumper for the "instant fire"? My heater is an Atwood G6A-6E. Thanks.
cathy624 is offline   Reply With Quote
Old 07-09-2011, 03:32 PM   #2
dznf0g's Avatar
Oswego , Illinois
Did you also buy the gas igniter board that goes on the side of the "master" board. This is necessary for the self igniting feature of the HWH.
Old 07-09-2011, 03:35 PM   #3
dznf0g's Avatar
Oswego , Illinois
It's the little green board piggybacked on the master in the lower left picture here:
R&G's Ignitor Board Page
Old 07-09-2011, 03:37 PM   #4
1989 34' Excella
Holly , Michigan
Not sure what the gas igniter board is. My unit just had the black potted board (I think that's what it's call) There is no other board in the water heater. My unit is the original part from '89.
Old 07-09-2011, 03:45 PM   #5
1989 34' Excella
Holly , Michigan
The place I ordered the part from only mentioned that I would need the waterproof cover, nothing about another board. now I'm confused. Would this extra board fit inside the cover I bought?
Old 07-09-2011, 08:06 PM   #6
dznf0g's Avatar
Oswego , Illinois
no, it plugs onto the dinosaur board where you now have your harness plugged in. The harness will plug onto the "piggyback board. See the pic in my previous post link.
Old 12-10-2015, 06:07 PM   #7
ddruker's Avatar
1999 27' Safari
Palo Alto , California
This post is just because I found this old thread confusing.
I also have an Atwood six gallon electronic ignition water heater. On my unit, and on the new Dinosaur UIB-S boards as of 2015, there is no extra adapter needed as described above. It's just plug and play, working with the existing wiring. You want to buy the UIB-S board, and the matching two-tab mounting kit, which comes with a waterproof cover for your new board.
- Dan
1999 27' Airstream Safari + 2011 Mercedes GL 350 Turbo-diesel + 2021 Ford F150 Platinum Hybrid w/ 7,200 Watt Pro Power
ddruker is offline   Reply With Quote
Steel / Aluminum wheel question polarlyse Wheels, Hubs & Bearings 12 05-29-2011 07:49 PM
1980 Caravelle axle question Seymour Axles 5 05-14-2011 08:28 PM
Water heater needs new circuit board. Boondocker Water Heaters, Filters & Pumps 0 04-30-2011 08:07 AM
EVAP Canister? question 8rmesse Classic Motorhomes 23 04-24-2011 06:41 AM
Blasphemous question woytovich General Repair Forum 15 04-09-2011 08:36 AM
