Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Waste Systems, Tanks & Totes
Old 12-30-2017, 12:50 AM   #1
1972 25' Tradewind
Los angeles , California
Valterra handle extension
Hello I have Valterra T40 3x3. I am not able to remove the handle nor the rod so I can find a way to extend it. Would you please help me how I am suppose to remove the tube or the handle? Thank you.
Spookies is offline   Reply With Quote
Old 12-30-2017, 01:44 AM   #2
A W Warn's Avatar
2000 25' Safari
Davidson County , NC Highlands County, FL
When I was replacing the valves on my Excella I found Valterra valves would not work for that application, for two reasons:
1)There is no handle extension that uses the crooked solid rod like the Thetford valves do .
2)The Valterra valve will not work within the space between the tanks and/or with the tank adapter flange.
The Valterra valves work fine on my Safari since those valves do not require a handle extension and the valves are outside the belly so they are placed within the exposed sewer pipe.
Alan
Old 12-30-2017, 10:39 PM   #3
1972 25' Tradewind
So there is no way I can remove the existing original rod and the handle and install the longer one?
Old 12-31-2017, 06:57 AM   #4
A W Warn's Avatar
2000 25' Safari
I'm not saying there is no way. There is always an alternate way. The answer might be to cut the rod and make a coupling, using the old handle.
What I am saying.... I did not find a way that was satisfactory to me. For $30 more I bought the exact replacement. In my case easier/faster trumped less expensive.
The valve was leaking while I was living in my trailer, so had to repair it quickly.
Alan
Old 12-31-2017, 09:07 AM   #5
1972 25' Tradewind
Now got it, thank you! I will see what can I do.
Old 01-01-2018, 10:04 AM   #6
57Vintage's Avatar
1958 26' Overlander
Battle Ground , Washington
Images: 22
Rod extensions
A photo would help. There are extension rods for Valterra.
http://www.valterra.com/product-cate...xtension-kits/
There are also cables for a long extension, but they can be a pain if you have to use in tight places.
Harold & Rebecca
Our thread:
https://www.airforums.com/forums/f97...er-172124.html
57Vintage is offline   Reply With Quote
Old 01-01-2018, 10:05 AM   #7
1972 25' Tradewind
Thank you however I couldn't find the wat to uninstall the current original rod/handle! So I don't know how to install the new one.
Old 01-01-2018, 10:16 AM   #8
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
On a 72 the original extension handle is connected to the Thetford dump valve with a cotter pin. You would have to go in through the belly pan. You could cut a window.
Old 01-01-2018, 11:45 AM   #9
A W Warn's Avatar
2000 25' Safari
In my trailer the rod that is the extension acts like a coupling, slipping over the existing rod, and a uses rivet to connect the two. Other year model valves I have seen used a cotter pin where mine was riveted. I posted a photo of that valve handle in the thread explaining my repair. (post #1, third photo down, the valve on the right) You can barely see the connection.
http://www.airforums.com/forums/f444...es-162941.html
Hope this helps!
Alan
Old 01-01-2018, 11:49 AM   #10
1972 25' Tradewind
In my trailer the rod that is the extension acts like a coupling over the existing rod, and a uses rivet to connect the two. Other year model valves I have seen used a cotter pin where mine was riveted. I posted a photo of that valve handle in the thread explaining my repair. (post #1, third photo down, the valve on the right) You can barely see the connection.
Hope this helps!
Yes! Thanks a lot, I appreciate your time.
Valterra to Thetford connection Craig Waste Systems, Tanks & Totes 30 03-05-2011 07:49 PM
Valterra or Thedford? Grandpapa Waste Systems, Tanks & Totes 4 07-19-2009 07:32 PM
Valterra Valve question 65CV Waste Systems, Tanks & Totes 0 07-14-2009 09:14 PM
Replace a Thetford Valve with a Valterra? thunder433 Waste Systems, Tanks & Totes 2 03-03-2008 04:41 PM
Thetford vs Valterra pilgrim_still Waste Systems, Tanks & Totes 8 06-11-2005 01:34 PM
