Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Waste Systems, Tanks & Totes
Old 03-05-2005, 10:04 PM   #1
ShinyTiny
Profile:  Oceanside
Arrow Sewage/Termination Cap 1963 Globetrotter
We are looking for a Sewage/Termination Cap for our 1963 Globetrotter. We heard that you can modify the opening so that it would accept the modern caps found in RV stores. Has anyone done this before? Any suggestions?
ShinyTiny is offline   Reply With Quote
Old 03-05-2005, 11:20 PM   #2
InsideOut
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
We were in the same boat a couple of years ago looking for a termination cap for our '64. We eventually found one, after searching for two years, on ebay...they do come up occaisionally. So we didn't modify our outlet however we did look into doing it. You basically cut off the end of the outlet and either epoxy or otherwise bond the new fitting to the existing sewer line. Then the standard fittings can be used...kinda kludge, but it works...we decided to hold out for the original term cap even though everybody told me it couldn't be found! Patience paid off...good luck on your search!
Shari
RMVAC | WBCCI DenCO Unit | Maxwell | Birdie
Old 03-06-2005, 04:52 AM   #3
balrgn
balrgn's Avatar
Profile:  1974 27' Overlander
Rockingham County , New Hampshire
Images: 74
We just picked up an new 4" PVC assembly for ours. The original is in good shape just it is a pain to store the hose. The new style fits into a 4" PVC pip and is easy to store and is much cleaner way too. I have to cut off the original and cement the new one on, waiting for warmer weather. I found the new assembly at a local camper parts department...
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'77 20' Argosy MH (Peanut)
2006 GMC Sierra 5.3 V8
WBCCI 1754 - AIR # 6281
Member of VAC
www.balrgn.com
www.balrgn.com/Airstream.htm
balrgn is offline   Reply With Quote
Old 03-07-2005, 10:05 PM   #4
Silver Bullet
Silver Bullet's Avatar
Profile:
Term. cap castings......
Thought I'd let you folks know that term cap patterns are about 50% complete.
Two styles for the bottom exit (pan handle style) and one for side exit (round, no handle)
The two styles for bottom exit are original and one with a 1" boss in the center for adding a hose fitting for grey water release when boondockin'.
I thought about building one with a boss for grey water on the round, but it could be used only one way, at the bottom of the cap, otherwise back-up will occur if it is at centerline or above, plus REAL messy when you take the cap off. Anyone interested in something like that?
Oscar
Silver Bullet is offline   Reply With Quote
Old 03-08-2005, 10:10 AM   #5
65GT
Supposititious Blue
65GT's Avatar
Profile:  1953 21' Flying Cloud
1965 20' Globetrotter
WBCCI Metropolitan New York Unit #072 , New York
Images: 26
Here's all you need to use newer caps and adapters on your 60's series trailer...
No cutting, no fuss -- screw this on and then you can use all the modern stuff...
http://www.valterra.com/RV/term_assemblies.htm
Go to the very bottom of the page and then scroll up to the first green package. It's part# T05-2285VP
If you look at that photo the top part twists right onto what is stock on a 60's era airstream and then you'll be able to twist the newer stuff right onto the base of this adapter.
I broke our hose adapter on the very 1st try and although the local RV store didn't have a clue as to why my stuff was a different size (and neither did I!), I actually found this adapter on THEIR shelves on my second visit! It adds about 2" to the drop, but I twist this off and store it as I still have the original cap!
Put that hack saw down!
7000+ Airsteam families having fun!
1100+ Airstream Events including 650+ Rallies in 2008!
SaveWally's WBCCI Unit Guide
65GT is offline   Reply With Quote
Old 03-08-2005, 10:20 AM   #6
kayelm
kayelm's Avatar
Profile:  Owings Mills , Maryland
Oscar
Hi Oscar,
I have a 1961 Caravel and would be interested in the bottom exit with the 1" boss in the center.
Kaye
Kaye and Lynn
1961 Caravel
kayelm is offline   Reply With Quote
Old 03-08-2005, 01:29 PM   #7
InsideOut
InsideOut's Avatar
1956 22' Safari
Images: 87
Nope...it may have worked on your '65 but not on my '64.
I tried the kit mentioned a couple of years ago and it doesn't fit...sorry! It's my understanding that '64 was the last year that the type of connector I have was used.
Shari
Old 03-08-2005, 01:43 PM   #8
65GT
Supposititious Blue
65GT's Avatar
Images: 26
I can only tell you that I've got a '65 and that doesn't match what they use now either. I was told that these systems changed over some time in the 70's and that there was only one standard prior. If ShinyTiny can get a hold of one of these it's easy enough to match it up without taking it out of the package. New stuff will definitely work out the bottom, and the top cinched up perfectly with what is on my trailer now.
Regards,
Old 03-09-2005, 05:57 PM   #9
ShinyTiny
Profile:  Oceanside
Post Thanks
Thanks everyone for your suggestions. We will keep looking for the original part until we get tired of camping near the restrooms. Of course we will keep the suggestion of modifying the opening as a backup. Great information!
Old 03-09-2005, 08:33 PM   #10
61Overlander
61Overlander's Avatar
Profile:
termination cap
Way to go Oscar! When you have your cap ready I'll be in the market. I was lucky enough to buy a termination cap with the threaded hose fitting for a grey water hose drain (sorry I outbidded you Shari) on ebay. However, since it's rarer than a Cubs World Series win I'm in the market for an insurance cap. ( I had a panic stop recently when I realized I'd pulled out of the campground and traveled 50 miles and hadn't safely put the termination cap in the locked and secure glove compartment of the Tahoe in it's velvet lined traveling bag). So cool now to just have the cap and my hose draining to the blue wheeled tank. Mike
61Overlander is offline   Reply With Quote
1961 - 1963 Bambi Serial Number Guide Andy R 1961 - 1963 Bambi 35 07-27-2008 11:38 PM
HELP PART NEEDED! Aluminum Termination Cap... InsideOut Waste Systems, Tanks & Totes 46 03-20-2006 07:08 AM
1964 GlobeTrotter InsideOut 1964 Globetrotter 3 09-30-2005 12:56 AM
need to replace a radiator cap stuart1 Mechanics Corner - Engines, Transmission & More... 1 10-28-2002 03:12 PM
Globetrotter 1963 - Kitchen Sink Drain Leak Under the Floor Uncle_Phil Plumbing - Systems & Fixtures 3 08-09-2002 07:59 PM
