Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Waste Systems, Tanks & Totes
Old 02-03-2004, 02:22 PM   #1
Profile:
Repacing blackwater dump valve
I want to replace my Thetford blackwater dump valve because it is frozen in the closed position and I cannot unscrew the screws that hold its two pieces together. I tried the Screw-Out product from Sears but the rusted screws gave out. Drilling out the screws presents a bigger problem because of the heat produced and the subsequent melting of the valves plastic body around the screw holes.
As a side note, if you have a tail light assembly with rusted screws, use a drill to drill into the head of the screw and all of a sudden as the screw head heats up the plastic will begin to melt and the nasty old screw can be pulled out before the plastic cools and hardens once again!
I am thinking of cutting the pipe just above the valve and then replacing the frozen valve with a new valve. Is this a normal procedure?
If I cut the pipe, I think I will be left with a shorter than normal pipe on to which I need to cement the new valve. Would it be feasible to use a rubber sleeve that is made to join pipe sections to join an extension piece to which I cement the new valve?
Rick Alston is offline   Reply With Quote
Old 02-03-2004, 02:40 PM   #2
87MH's Avatar
Profile:  1978 31' Sovereign
Katy , West Planet Houston, Texas
Images: 231
Can you cut em?
Rick:
I replaced (rebuilt) my Thetford black water valve just this past weekend.
Just wondering;
1). Could you use a "Left Hand" (counterclockwise) drill bit?
2). How about a small Sawzall (Reciprocating Saw). I believe these can be rented, but they are not all that expensive to buy.
I think I have enough room to cut all four of the screws if I had to.
I ended up having to buy a whole valve ($45) because I could not find the "slide" separately.
I think that I would try to cut the four long screws, and back out the dutchmen with a vice-grip.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign Photos:'78 Sovereign Rebuild
Motorhome '87 Classic Motorhome Saga
Old 02-03-2004, 02:58 PM   #3
Profile:
Cutting the screw heads off may work
Dennis
Your idea to saw off the screw heads is probably a good one. I've got to see how much working space exists in and around the pipes.
Of course, I might end up in the same situation as you and have to purchase the entire valve just to get the slide mechanism. If that is the case, perhaps I should just go ahead and cut off the valve and get it over with.
Thanks for you advice-I will let you know how things turn out.
Rick
Old 02-03-2004, 04:20 PM   #4
Ken J's Avatar
Profile:  1958 26' Overlander
Tijeras , New Mexico
I found the easiest thing to do is to cut both valves out and replace the whole thing. In my case (75 Tradewind) I could not easily replace just one valve.
So now I have new from the tanks to sewer connection. PVC is not that expensive....
Ken J.
Ken J is offline   Reply With Quote
