Old 03-24-2010, 03:22 PM   #1
tvanwave's Avatar
1991 34' Limited
Tyler , Texas
Missing my lugs
Hi - I'm a new AS owner (1991 Limited) and have been going through the systems. To my surprise, the PO ground all of the sewer discharge connection lugs off and rigged up some home made work-around for failed valves in the black water tank. I think he tried to put a Valterra valve on and found it would not fit - thus the creativity. Is there a sleeve or something more permanent that I can use to fasten the Valterra valve? The OD of the discharge pipe id 3.75 inches, forgot to measure the ID but typical 3" plumbing supplies may not fit.
Lugless in Nashville
tvanwave is offline   Reply With Quote
Old 03-24-2010, 03:27 PM   #2
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
If you have stub pipes sticking out you should be able to use a fernco coupling.Dave
easyride is offline   Reply With Quote
Old 03-24-2010, 03:36 PM   #3
tvanwave's Avatar
1991 34' Limited
Tyler , Texas
If you mean the black rubber device with clamps on both ends, that is what he tried. He stuck 3" pvc in one end and cemented the valterra fitting to it. The other end slides over the discharge pipe but is quite loose - I dont think it stable enough to travel with in place. Is there some other fernco product you were referring to?
Old 03-24-2010, 04:41 PM   #4
87MH's Avatar
1978 31' Sovereign
Images: 292
If you have enough stub....
On the '78 Sovereign I busted a couple of the lugs - just old, worn out, and degraded by the elements - a bit like me.
I had enough room to cut the Thetford Female Adapter off and glue a Valterra X Female 3" sewer connection directly to the stub - if you have 2" or so of stub it should work.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 03-24-2010, 05:52 PM   #5
tvanwave's Avatar
1991 34' Limited
Tyler , Texas
Great - I will see if I have enough room. I did not know that the piece with the lugs on it was an add-on to std 3" pipe. I have a camping world 20 Mi away and they should have the parts.
Thanks - if it does not work I'll ask for more help.
missing ? critter All Argosy Trailers 6 07-14-2009 12:20 PM
Am I missing something? bullydogsmom Cabinets, Counter Tops & Furnishings 1 04-01-2009 06:49 PM
Missing new PM? RichardT Forum Admin, News and Member Account Info 12 08-31-2007 06:45 PM
Missing , but not gone! RivetED Our Community 2 06-07-2004 02:41 PM
New Owners: Make sure you torque Lugs... hohne Tires 32 03-27-2004 02:54 PM
