Old 09-24-2016, 02:07 PM   #1
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
How do I remove this?
I need to remove the flange in the photo so I can remove the plywood cover and remove the black water tank. How do I do this? I see 2 opposite notches in the black flange. Is the flange threaded? Do I back it out? Pry it out? Do I need a special tool to engage the notches? If I bust it are replacements available?
Old 09-24-2016, 02:23 PM   #2
1976 Argosy 26
Fair Oaks , California
Flange is threaded . I used two large flat blade screwdrivers and formed an "x" and spun it out. Others have made a tool, a flat bar with two properly spaced pins . Good luck.
Argosy Heir is offline   Reply With Quote
Old 09-24-2016, 02:30 PM   #3
Lumatic's Avatar
1993 34' Excella
Images: 16
Righty Tighty Lefty Loosey?
Old 09-24-2016, 03:15 PM   #4
Lumatic's Avatar
1993 34' Excella
Images: 16
Got it thanks. It was a little stuck.
Old 09-24-2016, 03:26 PM   #5
1976 Argosy 26
Glad it went along with the program.. Mine was bear to get out.
Old 09-24-2016, 10:24 PM   #6
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Put a little food grade silicone on edges when replacing.. helps seal, too.
Peace and Blessings..
Channing
WBCCI# 30676
Old 09-25-2016, 06:02 AM   #7
Sphere Guy's Avatar
Livingston , Texas
Food grade??? On a toilet flange ???
Sphere Guy
AIR 50601
Sphere Guy is offline   Reply With Quote
Old 09-25-2016, 09:47 AM   #8
Lumatic's Avatar
1993 34' Excella
Images: 16
Is there something about the purity of precious bodily fluids I don't know?
Old 09-25-2016, 01:01 PM   #9
1967 26' Overlander
Spartanburg , South Carolina
If you are talking about sealant, won't that make it impossible to remove later?
Could you mean silicone grease?
Jacob D is offline   Reply With Quote
Old 09-26-2016, 09:49 AM   #10
1972 27' Overlander
Pocahontas , Iowa
Jacob D, food grade silicone is the consistency of petroleum jelly.
I used it all the time when I repaired water softeners. It lubricates
the rubber parts and keeps them soft, and protects them from liquids
that might start to decompose them.
dianalynn is offline   Reply With Quote
Old 10-03-2016, 07:32 AM   #11
1967 26' Overlander
[QUOTE=dianalynn;1856965]Jacob D, food grade silicone is the consistency of petroleum jelly.
that might start to decompose them.[/QUOTE)
Half a century ago, I was a systems engineer in a coal fired power plant that used pneumatic control systems. Silicone grease, similar to that which you describe as "food grade", was used to lubricate tiny ball bearings. We also used silicone sealant which set to a pliable gasket to seal some instrument enclosures against harsh environments. These were "state of the art" substances at that time. The term "food grade" applied to both types of silicone if it did not contain chemicals that could harm a person if ingested. Forgive me if time and progress has changed the technology in a way I am no longer familiar with.
How the heck do you remove the round retaining clips to remove the windows?? bvcg1 Windows, Doors, Locks & Vents 2 08-30-2015 01:57 PM
How to remove door to remove frig Silver84 Refrigerators 6 07-06-2015 01:32 PM
74' Excella, to remove wiring or not to remove? BaltiHimal Electrical - Systems, Generators, Batteries & Solar 3 05-30-2010 10:23 AM
How Do I Remove Rivets melprice General Interior Topics 1 05-31-2002 06:07 PM
inside light lens' how to remove to clean Paul Daugherty Mechanics Corner - Engines, Transmission & More... 12 04-25-2002 10:51 PM
