Brass Dump Valve Dimensions
I am going to replace my original brass black water dump valve this weekend. I would like to make an adapter plate to bolt from a valterra to the original brass valve mounting flange on the tank. The GSM vehicle way I read about. The details are missing as to the bolt pattern dimension of the mating flange to the tank. Does anyone have a brass valve they could measure for me? Diameter of the dump hole and bolt pattern circle diameter with bolt size.
My overlander is hours away and I wanted to make the part prior to going there.
1962 Overlander International
