Old 03-05-2007, 09:20 PM   #1
2005 22' International CCD
biloxi , Mississippi
Water Pump 2005 22' International Airstream
We have a 2005 22 foot international airstream. We just bought it and it is our first airstream. I can't seem to get the water pump to come on. When we first bought it, the water pump came on great. The water pressure works only when a hose is attached. I was wondering what and where the things are that I should check (breakers, resets, switches), Any help is greatly appreciated!
pgold is offline   Reply With Quote
Old 03-05-2007, 09:29 PM   #2
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Sounds like the water tank is empty.
Bill
Just my personal opinion
wkerfoot is offline   Reply With Quote
Old 03-05-2007, 09:48 PM   #3
The water tank shows that it is full.
Old 03-06-2007, 04:19 AM   #4
Moonstruck's Avatar
1986 31' Sovereign
1975 25' Tradewind
1967 17' Caravel
Sherfield English , Hampshire
Send a message via MSN to Moonstruck Send a message via Yahoo to Moonstruck
The think the water pump should have a switch to turn it off when you are hooked up to city water. Have you switched it off by accident? On my AS there are two switches: one on the control panel and one in the bathroom. Either one switches on the pump.
Silvertwinkie
Hampshire, UK
Moonstruck is offline   Reply With Quote
Old 03-06-2007, 07:05 AM   #5
The one on the panel in the kitchen is switched on. It doesn't change noises or pressure when it is turned off and on. I didn't know there was a switch in the bathroom. I'll check that one out. I was thinking there might be a fuse, a breaker, a reset switch or something like that for the waterpump. Thanks for the advice.. I am going to turn the bathroom upside down looking for that switch.
Old 03-06-2007, 07:12 AM   #6
Roadtoaster's Avatar
2019 30' Classic
Byhalia , Mississippi
Sometimes the monitor panel doesn't read correctly. I assume you have filled the tank from the curbside water fill. I believe there is an inline fuse at the pump as well as a fuse on the 12 volt panel.
Good luck.
Greg
Roadtoaster is offline   Reply With Quote
Old 03-06-2007, 07:29 AM   #7
2017 27' Flying Cloud
Altoona , Florida
I hate to even mention this but - you are not hooked up to city water are you?
Poprivet is offline   Reply With Quote
Old 03-06-2007, 08:36 AM   #8
I think we are definitely getting somewhere now. I am not hooked up to city water (but i am curious what that would affect). I have no clue where the fuse panel is located. (we just bought the airstream). And the gauge could be stuck. I haven't tried refilling the tank. I just assumed it has water considering the gauge read 80% full. If you can tell me where the fuse panel is, that should be everything I need to know to fix the problem.
Old 03-08-2007, 10:07 PM   #9
The only problem was a stuck water level gauge. I filled the tank and it works great. Thanks for all the advice.
Water Leak jcanavera Leaks - Weatherstrips, Gaskets, Caulks & Sealants 9 06-03-2005 08:28 AM
Water Pump Not Working Properly? 74SovereignInt. Water Heaters, Filters & Pumps 8 11-11-2002 12:44 PM
Water Hammer melprice Water Heaters, Filters & Pumps 10 07-30-2002 01:10 PM
Water Drip uwe Fresh Water Systems 6 07-11-2002 08:39 AM
Airstream Related List Servers Andy R Link Archive 0 02-22-2002 02:05 PM
