Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Fresh Water Systems
Old 07-03-2016, 10:18 PM   #1
2016 26' Flying Cloud
niceville , Florida
Fallen fresh water tank
I was inspecting under my 2016 FC 26u. Noticed odd shaped, bulging under fresh water tank. Like it was pregnant. Crawled under and sure enough looks like the full tank has fallen onto the underbelly pan! Bought this new, 2 months ago. More than a little disappointed with this kind of major issue!! Never been off road, not from road debris, no scrape marks. Belly pan is bending, pulling rivets. Looks like a thanksgiving turkey foil pan with a bowling ball inside, side are buckling from the stress. Pumped it dry.
Anyone else encountered this?
kapt59 is offline   Reply With Quote
Old 07-03-2016, 10:25 PM   #2
CRH
1995 25' Excella
xxxxx , xxxxxx
I am sorry to here your trouble.
CRH is offline   Reply With Quote
Old 07-03-2016, 10:33 PM   #3
niceville , Florida
Picture upside down, my mistake.
Old 07-03-2016, 10:36 PM   #4
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
I hope Airstream is embarrased.
Old 07-03-2016, 10:50 PM   #5
niceville , Florida
I hope Airstream fixes it ASAP.
Old 07-03-2016, 10:52 PM   #6
niceville , Florida
Second pic
Old 07-04-2016, 10:50 AM   #7
Keith Gantt's Avatar
2014 23' Flying Cloud
Woodstock , Georgia
Be sure not to fill water tank with a hose end stuck in fill hole. I over- filled and pressurized my fresh water tank caused a similar problem. Vent could not release enough before tank pressurized and belly bolts pulled out. Looked almost like this. I over filled it- Airstream over tightened and stripped threads out at assembly. The combination of two were disaster! My wife and I pulled and repaired ourselves in a day with larger 3/8 inch bolts and redesigned straps for a total of $60 Click image for larger version
Name:	ImageUploadedByAirstream Forums1467650726.637203.jpg
ID:	265936Click image for larger version
Name:	ImageUploadedByAirstream Forums1467650780.016109.jpg
ID:	265937 10,000 miles later (full tank most trips) all is well.
The Streaming Gantt's
Keith Gantt is offline   Reply With Quote
Old 07-04-2016, 11:50 AM   #8
belen , New Mexico
Never had anything newer than a 79 and back then these were BULLET PROOF! I am saddened by all the poor workmanship I see on this forum in the past year!
alantbird is offline   Reply With Quote
Old 07-04-2016, 11:58 AM   #9
Plan-B's Avatar
2016 25' Flying Cloud
1997 21' Excella
Full-Time , Full-Time
Totally not acceptable and didn't see problems like this in the older models and newer ones too many incidents. I am on an all summer trip with a new 26u, I had better go take a peek at mine.
Greg
2016 RAM 2500 6.7L Cummins, 4WD, Crew, Rear Air
Plan-B is offline   Reply With Quote
Old 07-04-2016, 11:58 AM   #10
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Originally Posted by Keith Gantt View Post
Be sure not to fill water tank with a hose end stuck in fill hole. I over- filled and pressurized my fresh water tank caused a similar problem. Vent could not release enough before tank pressurized and belly bolts pulled out. Looked almost like this. I over filled it- Airstream over tightened and stripped threads out at assembly. The combination of two were disaster! My wife and I pulled and repaired ourselves in a day with larger 3/8 inch bolts and redesigned straps for a total of $60 Attachment 265936Attachment 265937 10,000 miles later (full tank most trips) all is well.
Hi, although my tank is in a plastic box with metal straps, my tank got ballooned because I wasn't watching it being filled. No real damage happened, but my tank does hang down when full. I was going to add support brackets, but at this time I never did.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
Old 07-04-2016, 12:10 PM   #11
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Looks like our plastic tank cover and straps (25 RB) when I stuck our big garden hose in the fill nozzle, turned the water wide open, and walked off doing something else. No air escape, it shot the hose out and water followed several foot geyser when full. Stupid on my part, must have substantial air release when filling.
Doug and Cheryl
Old 07-04-2016, 01:02 PM   #12
jackson center , Ohio
Tank pan
The tank pan is fastened to frame with 5/16 self tapping bolts ,every 6-8 inches around perimeter. The plastic tank rests on styrofoam inside that galvanized pan. The tank pan will bow down with a full tank of water.
Is the buckle on the front side of the tank?
I would inspect the bolts to see if they are loose first.
Schu is offline   Reply With Quote
Old 07-04-2016, 01:10 PM   #13
Anna Maria , Florida
This is disturbing. Sticking a hose into the filler pipe is the normal way of filling a tank. We shouldn't have to worry about slow venting or over filling. The water tank installation and over all design should allow for this.
I am taking our 2013 30' International in for water tank problem as well. It has a leak somewhere and holds only about 3/8 full of water.
The also neglected to install the rubber gasket behind the right front marker light and now I have the beginnings of a serious corrosion problem.
And the overhead galley storage cabinet is lose and bounces up and down. I noticed it recently as I pushed up on it for some odd reason. I have had to take this unit back to Jackson Center for one thing or another every year since we bought it.
Additionally I had to replace the Hot Water Heater as well. It had a faulty weld at one of the fittings and began leaking. At first I thought it was condensation from the fridge until it really began to leak. Atwood didn't want to to do anything about it since it was out of warranty and they were doubtful looking at the pictures I sent them of the lousy welds . So I yanked the damn thing out and drove it their Elkhart factory and shamed them into giving me a new one.
franklyfrank is offline   Reply With Quote
Old 07-04-2016, 03:36 PM   #14
:SPACE A" S/O 11 Air19745
guskmg's Avatar
2006 34' Classic S/O
Fort Worth , Texas
Just be careful of high pressure city water. It will blow up an unvented container in a heartbeat. I use a screw on filler tube that is vented and you can easily see the potential damage possibilities when it is approaching full and starts to spew out. Be sure a use low flow especially if you are going to do something else while it is filling.
guskmg
Old 07-04-2016, 03:59 PM   #15
Sbb
begorragirl
Sbb's Avatar
2017 25' Flying Cloud
Denville , New Jersey
oh no, so sorry to see this happen to you. It is such a pain to bring AS back for repairs when brand new, or any time for that matter.
2006 Bambi CCD ("EireStream!!")
2010 Funfinder
2005 T@B
2001 Teardrop, Mountain Hardware Tent
For some perfection takes a little longer...
Sbb is offline   Reply With Quote
Old 07-05-2016, 05:40 AM   #16
Mantua , Ohio
There should be a warning in the owner's manual. If not, this is an oversight which should be corrected. There's no pressure regulator when filling tnis tank as there is for the shore water hookup. Be careful!
Old 07-05-2016, 06:37 AM   #17
dkottum's Avatar
When I over-pressurized our tank I put a large diameter hose that we use for gardens in the filler neck that allowed almost no air to escape, and then turned on the city supplied water near full volume.
Lesson learned and should know better. An RV potable water hose is smaller and should cause no problem. High volume and pressure water delivery could still be an issue so one should be careful that the full tank of air (the tank is not really empty) can be pushed out easily.
Doug and Cheryl
Old 07-05-2016, 08:23 AM   #18
guskmg
City water pressure is usually 50PSI. The hose stuck loosely into the filler tube will blow out with the water as the tank gets over filled to the top. If the system can't handle 50 PSI pressure how in the world does it hold up a tank weighing over 300 LBS when it is full.
Old 07-05-2016, 08:44 AM   #19
Sag Harbor , New York
Welcome to the forum! Sorry you are having a baptism by water . . .
Have you spoke with the dealer?
A total drag that you should have to take care of this!
Good luck,
Peter
Old 07-05-2016, 11:13 AM   #20
I do not believe it is a structural issue unless the bolts are loose.It appears that it has hit something in the delivery process or unloading off of the transport.
When the tank is full of 40 gallons of water it will bow down.
My thoughts.
waste water tank and fresh water tank size 1964 safari jwmonty72 Waste Systems, Tanks & Totes 1 06-28-2016 04:21 PM
A Memorial Day Tribute To Fallen Vets pappy19 Airstream Lifestyle 1 05-22-2014 08:32 PM
Just Fallen in Love...total newbie VtTim Member Introductions 43 02-07-2013 12:21 AM
O, how the mighty (headliners) have fallen! bake315 Upholstery, Blinds, Walls & Interior Finishes 2 07-05-2006 07:38 AM
Honoring Our Fallen Freedom Fighters BobbyW Off Topic Forum 1 05-28-2002 10:08 AM
