Old 12-19-2006, 12:09 AM   #1
Motoman's Avatar
2005 25' International CCD
1960 18' "Footer"
Riverside , California
City Water Connection to Potable Tank?
Our 25'CCD has the city water connection on the street side and the potable water tank fill on the curb side. I would ike to connect a valve in between the city water connection and the potable wate rtank so that it can be filled without disconnecting. I believe there is even a blanked off Tee on the city water side that could be used.
Has anyone made this modification?
Don (KD6UVT) & Gail Williams
What do you want to be in life, a spectator or a participant?
SNU #157
FCU #004
Motoman is offline   Reply With Quote
Old 12-19-2006, 03:54 AM   #2
peegreen's Avatar
1998 31' Excella 1000
South Berwick , Maine
I'm not sure of your plumbing configuration, but all you should have to do is bypass the water pump. My trailer came with a solenoid valve called the 'auto fill' and automatically shuts off when the fresh tank is 3/4 full.
WBCCI 24291
New England Unit
Metropolitan NY Unit
peegreen is offline   Reply With Quote
Old 12-19-2006, 06:22 AM   #3
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
I suppose to make it simple, I would place a tee off the garden hose (potable water approved) and then attach a hose to that outside tee running to the tank and when needed, activate it, let it run through a bit and fill the fresh tank?
Safari owners Jerry Sulkin 1969 - 1973 Safari 30 02-20-2006 07:07 PM
Water Heater & Water Tank mgordon Water Heaters, Filters & Pumps 23 01-15-2003 06:58 PM
63' tradewinds black water tank Pberrini Waste Systems, Tanks & Totes 1 09-22-2002 12:57 PM
Looking for ideas hot water FrankR Water Heaters, Filters & Pumps 3 05-09-2002 10:28 AM
Black Water Tank Flush-Install JaceBeck Waste Systems, Tanks & Totes 0 04-30-2002 11:54 AM
