11-30-2010, 08:55 AM
1976 31' Sovereign
2000 33' Land Yacht
Ball Ground
, Georgia
All new Pex - replacing old plumbing
Started checking the fresh water system in my "76" referb and found some intresting things. The previous owner did not winterize so I found several splits and naturally in difficult places like behind the shower and can't even see. The water pump was bad and discovered the fresh water tank was full and has been full for at least 25 years or more. Seems the tank is still OK. I decided to rip all the plumbing out and start new. Pex is really neat to work with. I used the compression rings on two joints and quit. Went back to Lowes and paid the money for the pinch ring tool (expensive) and made lots of difference. Does better and easier to get in tight places but was costly. This allowed me to also put a hot water bypass and antifreeze valve on the pump and a valve to fill the water tank from the shore water internally.I also used the old shower valve and mounted it in the back compartment with a hand wand for a foot washer. Tomorrow I put air pressure and soap leak test and then the real test Water It was not as bad as I thought and happy it's done. The most work was many trips bask and forth to Loews and HD for fittings as it's impossible to get every thing you need. .
11-30-2010, 09:14 AM
1966 26' Overlander
Woodstock
, Georgia
I am doing the same on my 66 Overlander. After years of storage the pipes were split in many places. Using sharkbite connectors.
I can't get to the back of sink in the bathroom where those pipes are without pulling the sink I guess. Got to most everything else so far.
12-16-2010, 04:43 AM
1987 34' Excella
Blowing Rock
, North Carolina
PEX Project
First of all, this forum is awesome for us novice Airstream owners that choose to take on renovations and repairs. Thank many of you, for taking the time to share your experience and knowledge with us, it is greatly appreciated.
We are also tackleing a re plumb of a 77 Tradewind, not by choice.. the PO "drained" the water lines before winter, but we discovered 4 splits in the copper. Since the original copper is virtually impossible to repair,given the odd size it had evolved into over the years, we decided to replace it.
Off I went to Lowe's, (about 6 trips) to buy the PEX lines in combo with CPVC, compression fittings, and Sharkbite connectors. All going well so far, and expect to test the lines today.
I agree with someone on this forum that stated plumbing with Pex is a alot of head scratchin, planning your layout, and making the connections in the proper sequence, given the tight spaces. We bought the large compression crimpers...not so great to use in the tight spaces... so that is where the Sharkbite compression fittings came into play.
Will have photos up one of these days..
12-16-2010, 08:49 AM
Airstream - Other
Bosque Farms
, New Mexico
I did the same last summer, all PEX, combination of different push-on connectors. The only errors I found was during my recent trip: One connector under the kitchen sink was leaking, and the leads to the water heater were reversed, creating some interesting gurgling action. It was a pretty easy job to correct the errors.
The pile of old copper pipe, complete with all of the patches and repairs, was a good recycle.
Lynn
ACI Big Red Number 21043
12-16-2010, 09:44 AM
1966 26' Overlander
Woodstock
, Georgia
curious- about how much was the copper worth? I have to travel some to recycle for cash.
12-16-2010, 09:51 AM
Airstream - Other
Bosque Farms
, New Mexico
Oh, I didn't sell it. The local trash facility collects all manner of metals to recycle. So far (and in addition to the regular recycling), I've taken over the old AS axles and the old copper pipe.
Lynn
12-16-2010, 10:20 AM
1959 24' Tradewind
The Grass Capital of the World
, Oregon
Photos?
Sound like some good ideas. Any chance you can post photos of these?
12-16-2010, 10:39 AM
1974 Argosy 26
Morrill
, Nebraska
Pex is great!
Here is what I completed on the '74 Argosy. Replaced every inch, like previous post the old copper must have had a repair every 6 feet and mostly with garden hose. I used "Flair It" fittings, no special tools required.
12-16-2010, 11:15 AM
1959 24' Tradewind
, Oregon
Cool. Beautiful job.
Looks like the hot water bypass allows you to have cold water flowing from all hot water faucet knobs?
How did you handle the city water inlet? And do you also have an anti-freeze valve? I'm unfamiliar with what this is. This is my first trailer and everything I tore out was leaky copper junk and PO-rigged for strictly city-water.
btw, what part of the trailer am I looking at in these photos. I'm guessing the front-street-side corner - correct? What is the large 2" white pipe for? Seems too high for sink drainage?
12-16-2010, 11:34 AM
1988 25' Excella
1987 32' Excella
Knoxville
, Tennessee
I second the reccomendation for PEX. I paid about 40 bucks for the crimper at Lowes. Good deal, because the only one I had seen before that was at a camper place and it was $120. Best plumbing money I ever spent. One way to winterize is to dump the antifreeze into the fresh water tank and use the pump. Another is to introduce the antifreeze into the line back at the water intake and pump it through. The by pass allows you to pump to both sids of all the faucets without filling the hot water heater. thats 6 gallons of antifreeze saved. Plus if you do not put it in the hot water heater and fresh water tank it is easier to get the taste out in the spring. I bought a small paint tank at Harbor freight and rigged it up with my compressor to pump antifreeze into the water inlet. I do not use it for anything else so it stays clean. Some people add the little antifreeze tee and valve in front of the pump. But ours in in a closet and hard to get to and I was afraid I would spill the jug in the trailer, so I prefer the outside pumping.
12-16-2010, 04:09 PM
1974 Argosy 26
Morrill
, Nebraska
City water inlet
I put a larger image for a little better view. The city water inlet comes in just to the right and below the blue pipe that has the stainless steel hose hanging from the end. See the metal electrical box? It comes thru the wall just below that. The blue pipe along with the red are the cold and hot water to the bath sink. With the bypass valve I can winterize without putting anti freeze in the water heater tank. I just shut off the valve labeled COLD H2O and the one labeled HOT H2O then open the bypass valve. To winterize I just remove the inlet hose on the pump and attach a hose that goes into a jug of RV antifreeze, but I do blow the lines out prior to putting in the anti freeze.
It is all located under the vanity in the bath. The white pipe you see is the vent pipe. It use to run up and over thru a closet that was there. The black pipe is the sink drain. If you look close you can see where the vent pipe goes up, there is a notch in the vanity counter top on the right side. I have yet to finish the wall to cover it.
12-16-2010, 05:10 PM
1959 24' Tradewind
, Oregon
Got it, thanks!
I also just saw that you are restoring an Argosy, not an Airstream, so this must be a rear corner of the Argosy. Unless of course, you drive from the bathroom which could possibly be genius.
To the point, thanks for walking me through the bypass - the larger photo helped tremendously. Do you just drain the HWH during the winter and leave it empty, or half empty? Or not even worry about it, since it's probably made of sturdy metal?
12-16-2010, 06:09 PM
1974 Argosy 26
Morrill
, Nebraska
I definetly drain the water heater, it sometimes gets to -40 below here.
Glad I could help.
It's a 26' trailer. The bath is in the rear. Were you thinking motor home?
12-16-2010, 06:22 PM
1959 24' Tradewind
, Oregon
Glad I could help.
Yeah, I was. Still so much to learn...
12-16-2010, 07:35 PM
1974 Argosy 26
Morrill
, Nebraska
Argosy is an Airstream. They built them for a few years back in the '70's. I'm not sure how long they were made. Looks like you have a nice rig! Are you restoring it?
12-17-2010, 12:03 PM
1959 24' Tradewind
, Oregon
Thanks.
I'm a little unclear where the line for "restoration" is actually drawn. I know what the general idea is, but it gets down to brass tacks (literally) pretty quickly.
Let's just say I'm restoring it as best I can. The only things I eliminated that were original were the dinette lights (gifted to another Airstreamer) and the original toilet and tanks (still have them if anyone is interested).
In other words, I'm keeping everything she's got, and adding a little mid-century-modern updates to her according to personal taste. It's pretty fun to keep her looking vintage, and also a challenge that we embrace.
Certain things like solar panels and laptop docking stations are difficult to fit into this category, so our goals are to give the illusion of vintage, or blend modern technology into the 50s as best we can.
Also, a modern heater and PEX piping don't seem too vintage, but clearly better and safer ideas...
Oh and one final thing - the trailer was built with a twin bunk set-up that I find unacceptable. We kept one twin, and are reconverting it to a fold-out double bed (think futon). You see, we currently have no heater, so...
Anyway, I'm not too good at providing simple yes or no answers unless I'm at work, so I hope this clarifies.
Happy trails!
p.s. the only Argosy I've seen was a motorhome. It was like a gigantic VW Bus and felt like we were in an oval fishbowl with all the windows. It was super cool.
12-18-2010, 07:42 AM
1966 26' Overlander
Woodstock
, Georgia
On the previous Airstreams we had we drained the system in Dec. added anti freeze until it ran out of the faucets, and bypassed the water heater. Then invarfiably we would take a late Dec trip, have to unwinterize ( dewinterize?) and then do it again after we got home, or in one especially cold return trip we did it before we got home.
A pain but it worked.
On my current trailer I eliminated the water tank and connections as we have never needed them. We will have city water only, which will work for us.
On the fence about sharkbite or flair it fittings, I guess I will go with what the nearest Home Depot has to make it easier to reurn what we don't use.
Thanks for the photos above. I am truly a visual learner.
12-24-2010, 08:41 AM
Nashville
, Tennessee
This might be kind of late but, I repair plumbing on homes and see shark bites popping off all the time. I wouldn't recommend using them in the rear, if you use water in the winter, or ever. I replaced my plumbing with pex and used the solid rings you clamp. I have two water heaters, one of which is under the sink, and an extra cold line running to both sinks which supply drinking water from lines that have only been used for filtered/non tank water. It got very tight in spots, I had to resort to the two piece hand clap, which is a pain, and putting sections together and sliding them in.
I have yet to use the white connectors, and have yet to see one broken, that could be a good sign. The screw on grey stuff is absolute junk.
12-24-2010, 10:51 AM
1981 24' International
Torrance
I have a 1970 Airstream Overlander, need to replace the furance, but can not fine the ducting that the furance sits on, don't have a part or model number, the housing that was use is all one part to the heater housing, now need Furance and ducting.
12-24-2010, 01:32 PM
1977 27' Overlander
Trotwood
, Ohio
I did the PEX thing this past summer. I replaced all the kinked over copper tubing,hose covered with bolts for plugs that one of the PO'S had done. I went front to back,new drops for the Galley sink and Shower and Lavatory. It pushed thru from the galley without a problem and around the rear corner. If you shop you will find the Gator BITES or SHarkbite fitting are priced about the same. Fittings are kinda pricey. It takes a little measurin and figurin and layin out. BUT OH BABY does it make it simple. Cut PEX tubing to the proper lengths,install tee's and connectors that just click on and if ya make a mistake ,buy the small unlocking tool and start over ,NO BIG DEAL. I think its well worth the money.
GOOD LUCK
Roger
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
