Old 02-20-2009, 06:44 PM   #1
1989 34' Limited
southern , ontario
Zip Dee awning spring unravels??????
My 20' x 8' awning on the 1989 34' as, TT, had to be rewound by hand, the rewind spring has either snaped in two or I ASSUME the 4 pop rivets located 4' from the end of the rewind tube have sheared off, allowing the spring to unraveled, making one hell of a noise when it happened.
could someone suggest which would be most likely, or is there possibly another problem.
thanks for any input.
letsgo is offline   Reply With Quote
Old 02-20-2009, 06:55 PM   #2
enduroryda's Avatar
1994 21' Sovereign
Down on the corner... , CT
Here's what the guts of your roller look like.
I don't know if you can see from my pic but my spring actually was snapped close to the end of the roller. It was an easy fix replacing it.
Ann & Eric
WBCCI 6274
TAC CT-4
NEU
enduroryda is offline   Reply With Quote
Old 02-20-2009, 07:02 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
Roll the awning out about 4 feet and support it with a ladder. Now remove the bolts that attach the supporting arm to the trailer and remove the lower section of the supporting arm while holding the upper section firmly, I am sure the spring has NO Tension on it but just be safe. Once the 2 sections of the support are separated you will know if the spring has tension or not by the force against your hands.
Assuming there is no longer tension, the spring has broken, remove the roll pin that holds the arm to the spring shaft and remove the arm. Drill the 4 rivets out and remove the spring assembly from the awing tube.
If you do still have tension hold the arm securely and unwind the spring and then drill out the rivet and remove the spring assembly.
Once you define the problem and replace the spring reassemble the tube and wind the arm against the spring for 27 turns and install the lower section of the arm and reattach it to the trailer body.
WBCCI 12156 AIR 3144 WDCU TAC NJ6
2004 Excursion 4x4
1991 34 ft. Excella +150,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
My Kayak mysite.verizon.net/vze54tx9/kayak/
Old 02-20-2009, 07:29 PM   #4
1989 34' Limited
southern , ontario
Thanks for the quick replys, the one question I'm not sure of , do the 4 pop rivets act as stops, stopping the spring from turning, but allow the spring to be removed without drilling out the rivets or do the 4 rivets have to be drilled out before you can remove the spring assembly?????
Old 02-20-2009, 07:44 PM   #5
enduroryda's Avatar
1994 21' Sovereign
The four rivets just hold the end cap in place on mine. The end of the spring assembly
goes through the end cap and then is attached with a bar like clip I believe with a bolt through it.
The thing that stops the spring from turning is a claw like piece you can see in my pic that only goes to the center of the awning pole. It acts as a grab.
Ann & Eric
WBCCI 6274
TAC CT-4
NEU
Old 02-20-2009, 08:27 PM   #6
azflycaster's Avatar
1975 25' Tradewind
Phoenix , Arizona
Images: 63
Here is a breakdown of the parts inside the roller. Once you determine the problem, give Zipdee a call (credit card in hand) and get the replacement parts. Always be careful when working with that spring.
Awnings By ZipDee
Richard
Charter Member Four Corners Unit
Old 02-21-2009, 11:02 AM   #7
enduroryda's Avatar
1994 21' Sovereign
Also Make sure that when you re-rivet the endcap you have it so the Z lock lever (release/locking) mechanism is accessible with the awning wand. Mine is one rivet off making it a little tough to grab. Come to think of it I should have marked it with an indelible marker in a spot so it would line up the same.
Ann & Eric
WBCCI 6274
TAC CT-4
NEU
Old 02-21-2009, 03:44 PM   #8
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
My lock lever is on opposite end of the spring.My spring just broke,and will not come out,I`ll have to drill the the rivets at the inside spring end.What makes it fun is it`s the driver side awning,where the awning is rivited to the tube.Are we having fun yet?? $129.00 from Outdoorsmart.Dave
easyride is offline   Reply With Quote
Old 02-21-2009, 04:59 PM   #9
Dan@LED4RV's Avatar
Kernersville , North Carolina
Lock leaver
Dave
Is the lock lever in good shape???????
Click here to see the Lock lever
There is a kit that is suppose to repair the lock lever.
It takes a big bite out of the price.
Dan
Dan Brown
Kernersville NC
Dan@LED4RV is offline   Reply With Quote
Old 02-22-2009, 06:39 AM   #10
easyride's Avatar
1977 27' Overlander
Naples , Florida
Dan there is nothing wrong with my lock lever,it is on the end away from the spring end,
it`s my spring that is shot . Do they sell just the spring ? thanks,Dave
Old 02-22-2009, 07:20 AM   #11
enduroryda's Avatar
1994 21' Sovereign
Zip Dee does sell just the spring. See part Number in az's post above.
You can remove the spring, I had the same issue with getting it out. I had to use some long pipe I had lying around and just wacked it a few times to dislodge it. Like I said that claw at the end of the spring is weged in there.
Are you trying to do this with it still attached to your trailer?
Ann & Eric
WBCCI 6274
TAC CT-4
NEU
Zip Dee Awning Chitown AirStreamers Awnings 14 06-09-2011 03:11 PM
Used Zip Dee Awning Needed! cobra93 Awnings 0 12-01-2008 03:20 PM
Zip Dee Awning 63 Safari Awnings 8 07-17-2006 06:49 PM
Zip Dee Awning Adjustment handn Awnings 3 04-28-2006 06:42 PM
Zip Dee Awning Chitown AirStreamers Awnings 4 06-23-2003 01:12 PM
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
