Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Cleaning, Stripping & Polishing
Old 07-06-2006, 11:37 PM   #1
alumacoach1
Profile:  Currently Looking...
Terrace , British Columbia
Stripping orginal Decals off aluminum!!
Hey
Does anyone have any ideas on how to remove old decals off Aluminum Trailers? I have a 1971 Alumacoach that we are repairing and I would like to be able to take off the old Blue Stripes without scratching the aluminum. There is also old Duct tape residue around the windows too.. If anyone has any ideas I would LOVE to hear them!!!!
alumacoach1 is offline   Reply With Quote
Old 07-06-2006, 11:47 PM   #2
flyfshr
ModeratorMan
flyfshr's Avatar
Profile:  1959 24' Tradewind
Phoenix , Arizona
Well, i can tell you about the duct tape reside removal but not the stripes. For the residue, use a product called Bestine available in metal quart cans from an art store. Works better than any other product of tried. Absolutely will not harm the aluminum.
FF
WBCCI/VAC #2699
Air #10
I'm haunted by aluminum.
http://www.airztream.com
http://59tradewind.blogspot.com
flyfshr is offline   Reply With Quote
Old 07-07-2006, 01:07 AM   #3
InsideOut
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
I'll second Brad's recommendation
Bestine removes stubborn sticky tape residue like a charm.
But I'm sorry to say, it won't get rid of any oxidation resulting from it, like what is found under old WBCCI numbers.
Shari
RMVAC | WBCCI DenCO Unit | Maxwell | Birdie
Old 07-07-2006, 07:34 AM   #4
hotLAVA
hotLAVA's Avatar
Profile:  1979 Argosy Minuet 7.3 Metre
Wilmington , Illinois
What a coincidence.....
Just had a conversation with my brother-in-law who stripes cars as a profession. He was admiring our Argosy and going on and on about the stripes he'd like to put on it. He said the old come right off with a rubber wheel.
Now what a rubber wheel is or where you get one is your next queston.....
I would guess any sign store could help you out.
hotLAVA is offline   Reply With Quote
Old 07-07-2006, 08:09 AM   #5
thecatsandi
More than one rivet loose
thecatsandi's Avatar
Profile:  2006 31' Classic
Missoula , Montana
De natured alcohol. if the clear coat is gone..... Acetone or MEK.
Wear a resperator or your will be feeling very fine shortly.
Michelle
If you think you are having a bad day go to the hospital and visit the children.
Sarah
Ruby, (05 BMW R1200RT)
Daisy, (06 Turbo Diesel F-250 w/Tow Command, the perfect TV)
Butter Cup, (06 Classic 31 w/dinette, solar)
45,000 miles in two years!
http://Michelles-Adventures.US
Old 07-07-2006, 09:44 AM   #6
lewster
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
3M makes the rubber wheels that you put on a drill to remove vinyl graphics and striping. Check with a local sign shop or sign supply company. Some automotive paint suppliers also carry them. A hair dryer and 3M all-purpose adhesive remover will also work well, but slower.
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
Old 07-07-2006, 09:46 AM   #7
peegreen
peegreen's Avatar
Profile:  1998 31' Excella 1000
South Berwick , Maine
Do not use Goo Gone - it will take the clear coat off, I know from personal experience.
WBCCI 24291
New England Unit
Metropolitan NY Unit
peegreen is offline   Reply With Quote
Old 07-12-2006, 02:40 PM   #8
Sunshine Jim
cottag grove , Oregon
rubber cement trix
This works for bumper stickers, old masking and duct tape, reflective stripes etc. Basically anything held on with rubber type adhesives.
soak with old style paint thinner first if porous like ancient masking tape.
then gently heat with a hair dryer or heat gun.
Be cautious... Sneak up on the temp.
use the same thinner and a
soft flannel "white rag"
to remove the goo!
Worried about the thinner? use wax and grease remover instead.
Painted striping is a whole different ball of wax. it really depends on the specifics.
Is it on top of a clear coat or just a polished surface? how big makes a difference too.
Rubbing compound is sometimes the trick, used with exactly the right kind of pad, hand or power.
The wheel type stripe removers can generate enough heat to melt and remove paint if used too aggresively.
Don't be afraid to strip a panel if neccessary. Sometimes it's the easiest way.
Sunshine Jim is offline   Reply With Quote
Aluminum Trim Source? melprice Cabinets, Counter Tops & Furnishings 5 09-24-2006 11:17 AM
463 inches Aluminum Curtain Tracks 4 Sale Cat Parts Archive 8 05-10-2004 12:56 PM
Stripping paint off aluminum tin can luv General Interior Topics 4 04-18-2004 09:32 PM
believer in aluminum tanks! JohnGalt48 On The Road... 7 08-15-2002 05:49 PM
aluminum restoring rdm Cleaning, Stripping & Polishing 1 02-27-2002 11:37 AM
