08-29-2012, 10:20 AM
San Diego
, CA
Polishing Question - Go to F9?
Received my F7 from VTS a few days ago. Finally got time to start last night. Did a 3'x3' area. I am unimpressed. Still lots of oxidation and pitting:
Go over it again with F7, or get some F9? Is there a place to get F9 locally, or do I have to wait another week+ for VTS to ship it?
08-29-2012, 10:35 AM
1953 Flying Cloud
1953 21' Flying Cloud
West Sacramento
You might not be able to get all of the pitting to go away. It also looks like you have some polishing remaining in the pits them selves. I used corn starch and a micro fiber towel to get rid of the remaining amount. So, I don't know if F9 is needed. I do know as I went along from F7 all the way down to the S the pitting and swirl mark were less noticeable. It looks like your doing a fantastic job though.
Nu Vite is local here in N. Calif. He's real quick to ship things out and it's two day's shipping UPS ground from here to there.
08-29-2012, 10:39 AM
1982 34' Limited
Brunswick
, Georgia
What buffing pads are you using? I found that the right pads make a big difference! I used the twisted wool pads from VTS and they did a good job.
I used F9 in some difficult/ heavily oxidized areas; it seemed to work well.
Just keep swimming! Mine has some pitting.... its barely noticeable.
1982 34' Limited
2000 Excursion V10 4x4
WBCCI #3321
TAC #GA-24
08-29-2012, 10:44 AM
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen
What kind of compounder are you using or did you go stright in with a CycloPolisher? Usually several passes with a compounder are required for a first-time polishing job...we have used the Nivite products with great sucess following the techniques (Compound first, then Cyclo) described on the Perfect Poish website.
Shari
12-09-2012, 08:01 PM
Full-Timing
, All states!
I'm having the same problem: Compounded my '65 with a wool pad from VTS, but using Nuvite G6 (we have pretty bad oxidation). After a couple passes, it still looks like this. I've read a few recommendations for wet sanding but it really scares me to try. Maybe on the roof or something, but for now I'm just trying to do the areas that I have to reinstall lights and trim.
Kristin
Previously owned a 1965 Overlander, fully renovated it, then sold it after a year of full-time travel. We're taking a break from trailers to try a class A for a while, but we're still Airstreamers at heart!
Our blog | Video tour of our trailer
12-09-2012, 08:11 PM
1982 34' Limited
Brunswick
, Georgia
I had to use nuvite F9 to get some of the corrosion off. That might be worth trying before wet sanding
1982 34' Limited
WBCCI #3321
TAC #GA-24
12-10-2012, 08:16 AM
Full-Timing
, All states!
Thanks for the tip, I will try that!
12-10-2012, 08:26 AM
1982 34' Limited
Brunswick
, Georgia
Insideout make a good point too; equipment is important. From my experience, getting the sweet spot on rpm's with the rotary polisher will make the process go smoother. If I remember it was in the 2800/3000 range with a twisted wool bonnet (the VTS variety). I also wiped down the area with mineral spirits/ soapy water after each pass to get all the polish residue out. the F9/7 will put swirls in the finish, but will come out with subsequent passes of the G6 and S.
Good luck! Post progress pics!
1982 34' Limited
WBCCI #3321
TAC #GA-24
12-10-2012, 09:00 AM
1965 22' Safari
Vassar
, Michigan
Ditto with c_lewis77 above. I tried G6 and found that it only cut for a short time. 7 worked well for me but some areas took up to 5 passes before all oxidation was gone.
Tim
TAC MI 14
Everyday is a Saturday
12-10-2012, 08:37 PM
Full-Timing
, All states!
I can't thank you all enough for your helpful advice. This forum has been such a godsend for first-time Airstream owners like us. I have a renovation thread in the '65 Overlander forum if you want to follow our progress. So far we just have an empty, partially-polished shell on blocks, but she's making progress from the stinky, rotting mess she was when we bought her!
Kristin
02-08-2013, 07:49 PM
Full-Timing
, All states!
I did 5 passes with Nuvite F9 today and it still has bad filiform corrosion where the holes were for the plaque to attach. It still feels rough to the touch. Do I need to wet sand? I'm so scared that I'll mess up the cladding badly and have to replace the aluminum. Any pointers for wet sanding?
Thanks!!
Kristin
02-08-2013, 08:19 PM
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View
Look at it from another point of view
When you run into a polish problem like scratches or severe corrosion forget the Nuvite route. Take a look at Jetsco or Caswell sites and info. I have found that the sewn cotton wheels and the hello wheel get it done. Use a grinder type buffer. Use the polish bars (inexpensive). Finish up with a cycle and Nuvite S. http://www.jestcoproducts.com
02-08-2013, 08:31 PM
Full-Timing
, All states!
Thanks, will try that. The surface corrosion is pretty rough to the touch though - will the cotton wheel be enough? It looks like filiform that started from the holes where the plaque attaches through the skin.
Kristin
