07-11-2010, 03:08 AM
1959 24' Tradewind
The Grass Capital of the World
, Oregon
Gords Aluminum Polish - test 1
(photos in next post - still learning the ropes)
I gave Gord's Aluminum Polish a test run on some interior aluminum before embarking on the exterior.
This stuff is so easy to work with. It's main purpose in life seems to be to consume aluminum oxide. It turns it black and oily (like my hand in the photo) and then it just wipes off. The scratches were already on the railings when I found them.
I used a #0000 steel wool pad to scrub the thin, oily, stearic-acid based polish onto the aluminum. It didn't take much. I used a red shop rag for removal. I will substitute an adjustable low-rpm buffer for the steel wool when I do the exterior.
All six rails took me just over an hour and a half - photo documentation and coffee break included. Better living through chemistry.
07-11-2010, 03:15 AM
1959 24' Tradewind
, Oregon
part deux - photos
Photos (correctly attached). Top two are Brasso, bottom ones are Gords.
These are the railing tracks that hold the sliding doors for the overhead compartments to a Tradewind. Mine are very old. The top two are what Brasso was able to accomplish.
Then I used Gord's Aluminum Polish to see what it could do. Bottom photos are after the first "cut" (about 5 min). There's actually no grit to the polish, it's thinner than olive oil.
07-11-2010, 03:20 AM
1959 24' Tradewind
, Oregon
part trois
My proficiency improved by the third rail (right to left). Ignore the dirty hand and check out the difference in reflection between the pre- and post-Gords' Polish.
The rail on the right shows the type of residual gunk that was removed from the rail on the left (bottom image).
It helps to have GoJo or FastOrange around to clean your hands!
07-11-2010, 05:12 AM
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana
, Pennsylvania
Looks good. Never heard of Gords. Where do you get it? Let us know how it works on the exterior. It would be interesting to see the results when you hit it with a buffer.
TAC PA-5
07-11-2010, 05:16 AM
Baltimore
, Maryland
I think you would find that diamond brite would give you the same result. There is a big difference between chemical removing of oxide and polishing. Steel wool and aluminum are also a very bad combination. Instead of steel wool try wet dry aluminum oxide sand paper. Just a suggestion.
07-11-2010, 06:59 AM
1958 26' Overlander
Mesa
Very interesting. Thanks for sharing.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
https://mellomikesairstreams.blogspot.com/
07-11-2010, 07:10 AM
1972 31' Sovereign
1985 31' Excella
2010 31' Classic
Hendersonville
, Tennessee
Thanks keep us updated!
07-11-2010, 08:04 AM
1968 28' Ambassador
Cedaredge
I would agree with the steel wool except that #0000 is pretty dam fine and wouldn't scratch the aluminum. My farther, and Antique restorer used it to strip and finish 500+ year old furniture.
This stuff my be the ticket. I about to start striping mine in about 3 weeks. I'm not looking to get all the scratches out I just want it to shine and not have half the clear coat on and half off. And I don't want to have to do the whole trailer 3 times.
Keep us updated.
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
07-11-2010, 08:13 AM
1965 28' Ambassador
Irving
Idid see the promo video on Gord's site and it looks good.I think I would look at a body shop supply for an aluminum wool instead of the steel.Since I am trying all of these methods on my first polish job Gord's will be next.Using the bar method is still time consuming,but tried a pre wipe with Gojo and that worked pretty well.
Have you used Gord's on an area with filiform?I would like to see how it works on such an area as this seems to be the most challenging area for me to deal with on the skin.
07-11-2010, 10:18 AM
1977 25' Caravanner
Jeffersonville
, Kentucky
Ask an ole Aircraft Guy ,,, steel wool and aluminum is a no no,,,,
Movie Stars and Film Crews come to Me from hundreds of miles enticed by My knowledge, My imagination,expertise, creativity and innovations!
07-11-2010, 11:42 AM
Maniacal Engineer
Lopez Island
Scotch-Brite pads are available in a wide variety of grades, and leave no metallic residues behind. Alternatively, stainless steel wool is also available, but is definitely more costly.
- Bart
07-11-2010, 01:57 PM
1976 23' Safari
Chauvin
, Alberta
Tried this stuff on my trailer this spring, worked well, as long as you not trying to buff out the scratches. Do small areas and keep it out of the direct sunlight, seems to provide a good finish afterwards. Its been raining for the last 3 months up here and the water is still beading off. I will post some pictures later. I think its a good alternative for those of us that don't have alot time. Good luck.
Larry Atkins
Chauvin AB
07-15-2010, 01:49 PM
1959 24' Tradewind
, Oregon
Gord's genie grants you 3 wishes!
Originally Posted by 2airishuman
folks love mystery products that do magic.
one could use lighter fluid, mixed with flour and achieve the same results with LESS harm.
cheers
2air'
Incorrect. What you just described is a crummy version of homemade napalm.
Viewpoints like this are what led me to believe this product didn't get a fair turn on these forums. I found all the referenced threads above, I spoke directly with the vendor, I thoroughly read his patent online, and decided to give it a shot. Simply sharing my experience with a new product.
For the speed, cost, and effectiveness, I think this product may be a superior overall package. What appeals to me is the staying power of the sealant, as referenced by lpatkins (photos?) and evidenced by the areas on my Tradewind that I've done by hand. I think it may far outlast the results from Nuvite/cyclo. Don't need another "labor of Sisyphus" in my life.
Gord's does have it's drawbacks. For instance, when applied, the product turns black before it rubs off, and if there are scratches, the black rubs into the scratches, probably until it's buffed out the old-fashioned way (photo below).
Important to remember these photos are taken with a 10.0 megapixel Macro lens from one inch away. My eyes can't even focus on something that close.
Gord's Aluminum & Chrome, Cleaner, Polish, & Sealer
I'm hoping to make time in July to take the buffer to the exterior with this product, and I'll post the results. Keep that parachute open.
Adios Earthlings.
07-15-2010, 02:24 PM
1958 26' Overlander
Mesa
Thanks, SpaceEgg, for the report. I might give this stuff a try on a few stained, heavily oxidized areas on my Sovereign. I've been researching Gord's, too, and while it doesn't give you a true mirror shine, like traditional methods, it does give a clean, even shine for those who don't want to spend numerous hours working on their 'stream. I will be getting some aluminum pads for this work vice what is called for.
1958 Overlander
4CU 1st VP
07-15-2010, 02:32 PM
_
Viewpoints like this are what led me to believe this product didn't get a fair turn on these forums. I found all the referenced threads above, I spoke directly with the vendor, I thoroughly read his patent online, and decided to give it a shot. Simply sharing my experience with a new product...
share away.
but it's not a new product, except 4U.
_________
and apparently u r unaware that 'stoddards solvent is an aliphatic petrol distillate...
and so is charcoal ligher fluid.
_________
flour or corn starch have been LONG used as part of the diy aluminum polishing techniques.
google it and wear shades while reading...
there's even a PROFESSIONAL crew on THIS planet that shinestreams this way.
(another old thread with pix)
i DID leave of the stearic acid info...
the stearate is simply rendered animal fats...
((also in cocoa butter but more $$ and in texas it's gonna be STEER fat)
__________
so my comparison was incomplete...
lighter fluid, flour plus SPAM is a better version...
as a matter of fact has LONG been used to shine cars and other spacecraft...
a chunk of hog jowl or slab of lard depending on desired aroma.
________
so please continue the journey of discover...
chees
2air'
07-15-2010, 02:50 PM
1959 24' Tradewind
, Oregon
spam, the wonder food
Interesting info, airing human.
I wonder if spacecraft slathered in spam will attract or repel creatures while boondocking...
07-15-2010, 05:11 PM
1970 27' Overlander
Espanola
, Full Timer
...might also attract Chupacabras!!!! I have been using 3m super duty rubbing cream compound (gravel in a bottle and it has a kerosene base that keeps it wet longer and clean up black with plain kerosene. Then finish out with mothers mag seems to do well on alclad. But now I am going to try 'Gel Gloss' this other patron says works well...anyone tried it? What I have mentioned above is very very affordable too around 14 dollars a cream quart for 3m
07-15-2010, 05:12 PM
1967 26' Overlander
Winston Salem
, North Carolina
IMHO,
Polishing an Airstream is a nasty dirty time consuming process.
Been there done that.
Greg
Winston Salem, NC
WBCCI 5218,
Corresponding Secretary Piedmont NC Unit 161,
1967 Overlander International.
1979 Avion 30ft rear bath
TV's 88 Chevy Suburban 454, 3:42, TH400
95 Cadillac FW Brougham, LT1,3:42, 7k tow pk.
07-15-2010, 07:07 PM
2007 25' International CCD
1964 19' Globetrotter
2012 Interstate Coach
vero beach
Hey SpaceEgg:
Taking it up a notch! Loved the " labor of Sysiphus" reference.
Dennis & Ellen
07, 25' Ocean Breeze
64, 19' Globetrotter
Air #7609
