Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Cleaning, Stripping & Polishing
Old 03-27-2011, 04:42 AM   #1
Hertford , North Carolina
Dealing with clear coat
My 1965 Boles Aero has coating on the skin. It's scratched and scuffed.
Any strategies for dealing with it? Can I strip it and then polish the bare aluminium? Can it be restored?
hertfordnc is offline   Reply With Quote
Old 03-27-2011, 08:23 AM   #2
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
By the looks of this Hertford, you can get the clearcoat off with some semi paste zip strip. Make sure you try a small area first- it should bubble right up, but give it about ten minutes or so (as instructed).
This aluminum I see here looks like it will clean up good, and you can stay in your TEST AREA to see if it will polish. Before you go running down the street buying expensive polishes, try some MOTHERS MAG and ALUMINUM POLISH, get yourself plenty (and I mean LOTS) of Tee shirts for rags, and a gallon of kerosene. Kerosene disolves oxidation and wipes up quickly. All this is a good place to start without knocking your self out at first. It may polish up to shine, and it may not. But irregardless you will be cleaning it and improving the metal. If you go to have it cleared again, take it to a pro for this duty.
https://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
Classic Motorhome Picture thread! Keyair Classic Motorhomes 719 10-28-2022 06:57 PM
'58 Flying Cloud- Clear Lens for Coronado Lights- HELP! 745classic Cleaning, Stripping & Polishing 11 02-04-2019 05:07 PM
WBCCI MOHO issue - 2010 to 2012 rideair WBCCI Forum 1129 03-27-2013 09:09 PM
2011 Mid Winter Meeting wkerfoot WBCCI Forum 372 02-07-2011 02:07 PM
