quite a mess u kids are making...
as noted by many veterans of polish'n ...
there is NOT much u can do to prevent what is being called "water spots"
the ONE THING that will work is RE plasti-Kote-ing.
and that stuff might last 3-4 years if not abused.
_________
these 'spots' aren't minerals from rain or simply acid rain, or dust.
these spots are REACTIONS between the water and the aluminum.
in other words basic oxidation/corrosion at the primary earliest stages.
thats WHY the 'spots' don't simply wipe off, they are IN the metal and PART of the metal.
_________
a 'mirror' finish on a polished stream isn't a mirror which is GLASS.
the mirrored finish on aluminum, if LOOKED AT with a microscope
is still very porous/pitted/raw metal, depending on type of alloy.
its not glass so comparisons to glass for product testing are useless.
the polished metal still has PORES on the surface (so does glass btw but they are much smaller than in metal)
_________
as one MOVES through the polishing process (and grades of compounding)
the goal (after getting the obvious crud and pits off) is a progressively smoother surface.
the smoother the surface the smaller the pores, and the LESS raw metal there is to oxidize or react with water.
but it's still never truly as SMOOTH as glass or chrome or even automotive clearcoats.
and the polished metal is never really UNIFORMLY smooth (some areas have bigger pores or deeper pits)
after polishing the "magic grail" is...
finding something that will BLOCK water and PREVENT reactions (oxidation/corrosion) with stuff in the air.
so far the ONLY stuff that does this reliably and LONG TERM is PLASTI-kote.
___________
briefly, flours (ground up grains) do 2 things....
#1. they absorb/lift that last bit of BLACK STUFF from polishing solvents...
#2. they deposit a TINY bit of grain FATS (oil) in/on the metal...
1+2=
#3... the starches, proteins and fats chemically REACT a bit with the aluminum to get IN way (delay) oxidation.
does the 'black stuff' every really stop when polishing? for most NO as each new rag will still get black.
so flour is sorta like a 'disposable rag' made of fine/tiny bits and those bits absorb black and wipe off.
this 'brightens' the aluminum a bit and deposits a FINE LAYER of powder into the PORES in the aluminum.
the 'flour deposits' have proteins, starches and a tiny bit of oil that plugs the small pores leaves a coating and so on...
depending on WHAT floor (ground up stuff) is used MORE or LESS fats/oils will be left behind.
this is WHY folks discuss 'corn starch' vs
pastry floor vs
self rising flour vs
oat flour...and so on.
_________
one could wipe SPAM, a CHOCOLATE bar, a chunk of cocoa butter and slice of avocado on bare polished aluminum...
and then determines WHICH edible gives the LONGEST resistance to oxidation....
(hint the product with the LEAST WATER, hardest FAT and most NEUTRAL pH, might work best)
_________
the good/bad outcomes using various "automotive waxes, sealants, dressings and so on....
will DEPEND on how much WATER is in each and how much FAT/oil/wax, the pH
and how the 'chemistry' of that product reacts with the alloy.
_________
how ANY given product works will also depend on WHAT POLISHING COMPOUND and MATERIAL was used on the metal....
because the POLISHING PROCESS leaves STUFF on/IN the aluminum pores
and that stuff ALSO reacts with goops applied in a good or bad way.
_________
because of the clean air/environmental regulations,
AUTOMOBILE coatings have largely replaced the solvents (vehicles) in their products with WATER or other 'safer' things...
so ANY of you trying WATER BASED waxes/coatings will get poorer results...
clouding, staining, streaking and so on is a RESULT of the goop reacting with the metal (or plugging the pores)...
multi purpose products (polish/clean/shine/wax/protect) have more ways to REACT with the metal and CLOUD the shine.
PURE carnauba wax (palm tree LEAF extract) is very HARD durable stuff but it's also slightly acidic and may react with an aluminum alloy...
Carnauba wax - Wikipedia, the free encyclopedia
but like the other plant/animal/mineral fats/oils it can provide protection IF properly mixed.
___________
simply WIPING the polished surface with mineral oil will delay oxidation/spotting...
till the OIL EVAPORATES.
waxes don't evaporate as QUICKLY as oil but still do eventually.
SYNTHETIC waxes might evaporate even slower and therefor last LONGER...
but any AUTOMOTIVE finish used needs to have the RIGHT CHEMISTRY not to react with the aluminum.
___________
the MYTHICAL GOOP would be something that...
-goes on CLEAR and doesn't optically cloud the shine...
-goes on without reacting with the metal to form OXIDATION...
-'bonds' with the metal to plug pores and stabilize the oxidative process...
-goes on easily (hand or buffer) and yet LASTS a long time...
-doesn't break down to get UGLY as it ages...
-protects or resisting environmental attack on the surfaces...
-is free or cheap to buy and use...
-is totally safe for the trailer, the humans and the environment (in that order)
-smells good and makes the USER look younger...
_________
mix baby oil, cocoa butter, bacon fat and coconut oil...
this might really be the stuff!
or substitute olive oil for the 'mediterranean formulae'
cheers
2air'
