Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 03-29-2014, 07:14 PM   #1
Rob
2014 25' International
Littleton , Colorado
Water Heater Repair
Hello,
I'm a newbie with an 2014 International Signature 25 foot Onyx Special Edition. I searched the forum for this water heater problem but couldn't find a thread. Hope I'm doing this posting correctly; apologies in advance if not; this is my first posting. Took delivery last month and have not been able to get the water heater to work. The unit came winterized so I inserted the drain plug in the external compartment and turned the ball valve (inside compartment) to in use. I then turn on one of the water heater buttons (one for gas and one electric located in bathroom - have tried both). The light to indicate a fault does not turn on. Water comes out when I turn the bath or kitchen faucets to hot but the water is cold. When I go outside to listen by the external water heater panel, I don't hear a flame. I also checked the fuse box; nothing seems wrong but am not sure which fuse is the right one to check. I've checked the AS manual and the Atwood manual but can't figure out what I'm doing wrong. The Atwood manual refers to a lock out situation and suggests resetting the switch (off then on) but I can't find any switch.
Would appreciate any suggestions.
Rob
zenstream is offline   Reply With Quote
Old 03-29-2014, 07:43 PM   #2
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
First - do you have propane in the tanks and are the tanks turned on? I fulltime so I don't winterize it, but if I did, I would have turned off the tank valves! Check them. No propane, no fire. You might have air in the propane lines. Light a burner on the stove to make sure you have propane and to purge any air. If you just bought it new, some dealers don't top off the propane tanks for you.
Second, when winterizing, it's normal to bypass the water heater tank. There are valves often above the tank that allow water to flow AROUND the tank rather than through it. The tank is then drained, the lines are drained, and then filled with RV antifreeze. Bypassing the water tank saves 6 gallons of antifreeze that would otherwise flow into the tank. Are you sure you aren't still bypassing the tank... so the water isn't going in there to heat up? Loosen drain plug again... if no water comes out there's your problem. If you leave the electric heating element on with no water it will burn up, so turn it back off. Also... someone may have removed the element to keep it from getting calcium buildup. Make sure it's IN the tank.
You are plugged into electric power aren't you? Water heater won't work on electric from batteries. Also when breakers blow, the breaker won't flip all the way to OFF and to reset it you have to push it all the way to OFF, then back ON.
Those are the simple things to try... after that I yield to those with more experience.
Paula
Old 03-30-2014, 08:05 AM   #3
Rob
Thanks for the reply Paula,
1. Yes, the AS came with propane; I've used the stove and furnace and they work fine.
2. I turned the bypass valve from "Winterize" to "In-Use" and have not seen any other bypass valves.
3. Yes, water comes out of the drain plug when loosened so it has water in it.
4. Yes, I'm plugged into electric power.
5. Unsure how to check what you said about ensuring the heating element is IN the tank.
Rob
Old 03-30-2014, 09:24 AM   #4
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
Water Heater Repair
Welcome to the club, glad to have you, sorry you're facing a problem so soon.
I'm assuming your dealer is too far away for a quick resolution... For problem determination it helps to understand what is separate and what is common to the gas and electric water heater. They are pretty much independent.
For electric operation, a low voltage switch operates a relay that provides 120VAC power to a heating element submerged within the tank. A non-adjustable button sized thermostat mounted on the surface of the tank switches the current on and off to regulate the water temperature. Depending on initial water temperature, it may take an hour or more for the water in the tank to warm up. There is no indication that the electric portion of the water heater is working other than the water eventually gets hot. A 120V circuit breaker provides power for this system except for the low voltage switch/relay. This low voltage circuit connects through the circuit board on the front of the water heater.
For gas operation, a separate low voltage switch also connects to the circuit board. When operated, the board cause the gas valve to open and starts the ignition sequence. When operating, you should be able to hear the Lund of the sparking followed by the burner igniting. Once lit the igniter shuts off and the flame burns until a different non-adjustable button sized thermostat mounted on the surface tells the gas valve to close. This cycle repeats as needed. The fault indicator only comes on if the ignition starts, but no flame is detected and the system goes into a fail safe state by closing the gas valve. Turning the switch off and on resets the condition and retries. A 12V fuse provides power for this system. In gas operation the water comes up to temperature sooner.
The electric and gas systems can be operated separately or together. As Paula noted, it is important to insure the hot water tank is full before operating the water heater, especially in electric mode. Older water heater winterizing bypass systems used a combination of 3 valves, newer systems use 1. Since both types bypass the WH, the only way to know the tank is full is to manually operate the brass temperature pressure relief valve located near the top of the WH.
As part of my winterizing regimen, I pull the 12V fuse. This disables both the gas and electric operation to prevent me or a curious grandson from accidentally turning on an empty water heater.
If your fuse tests good (swap or replace as vision can be misleading) unplug from shore power and then try reseating the connections on the circuit board and to the thermostats under the foam rubber cover. Excessive dampness around the board has delayed mine from operating until things dried out.
Name:	ImageUploadedByAirstream Forums1396192611.255079.jpg
Ignore the line about wired by customer, the customer was Airstream.
If you know how to use a volt meter or test light, you could verify if you are getting 12V to the board. Verify the ground is good. See if you have 12V at the switches.
If this has never worked, it is possible the installer neglected to connect something. The board could be defective. If it isn't a simple fix, a visit to the dealer might be the thing to do.
AIR 47751
Silver Goose is offline   Reply With Quote
Old 03-30-2014, 11:39 AM   #5
Gary W Wong's Avatar
Milpitas , California
I have the same problem as I ran out of propane on my last trip. I tried the electrical switch and was unable to get I to hear water. I realized I had no propane. I know there was water in the tank when I turned on the electrical button but it did not work without propane. Yes newbie problem.
I have not been able to test it to see if it works but it has worked before. Does the water heater work on 110 power connection? Also I think I do have air in my system since I have not turned on the electric button yet. If I turn on the gas one will this purge the air out?
Gary W Wong is offline   Reply With Quote
Old 03-30-2014, 03:04 PM   #6
2008 27' Classic FB
Burkburnett , Texas
Originally Posted by Gary W Wong View Post
... I tried the electrical switch and was unable to get I to heat water. I realized I had no propane. I know there was water in the tank when I turned on the electrical button but it did not work without propane. ... If I turn on the gas one will this purge the air out?
Gary, If you have a combo gas/electric water heater, it will work on 120V shore power without gas. If you have a gas only WH it will obviously work only on gas. If it has the electric feature and it's not heating the water, there is something wrong.
If you have run out of gas or the gas has been turned off at the tank, the line will likely need to be purged 1st as Paula suggested earlier in this thread. The easiest way I know of is to light a stove top burner and let it run for a minute until the flame appears steady. If the WH is on the end of the line, it sill may take a couple of attempts to light it. After that, it should light on the 1st try as long as the gas line remains pressurized.
AIR 47751
Old 03-30-2014, 03:11 PM   #7
I have the two switches electric and gas so I am not sure but I think it needs gas to run even with electric.
I have a 2014 international 23' and yes the water heater is at the end. Once when I ran out of gas the electric did not turn it on by itself. So I am assuming it is electric srarter with propane to run?? I'm new to this.
I am assuming you both are right in air in The line. But I am confused by the propane button to the water heater would have filled the line with propane. The water heater comes on with propane.
Of course now that I think of it the electrical has to run without propane or I would use up all my propane on the water heater.
Confused and hope you can clarify ...
Old 03-31-2014, 07:56 AM   #8
Rob
Gary,
Thanks so much for taking the time to write a detailed reply!
Yes, dealer is too far away to stop by; however, I have called them twice but they were unable to diagnose over the phone.
I've been on shore power almost exclusively to learn about my AS before going boon docking; however, I head out today to several days of dry camping.
I have plenty of propane and tested again this morning by heating water on my stove; the furnace also works.
I don't understand everything in your email - electricity is one of my many weaknesses; however, I'll study it over the next couple of days while dry camping and try to figure it out. Maybe I haven't been patient enough in letting the water get hot or maybe (more likely) I turned on the water heater before it filled with water. I suspect I'll have to find a dealer somewhere if it isn't resolved by the end of this week.
Thank you so much!
Rob
Old 03-31-2014, 09:41 AM   #9
Wise Elder
Jammer's Avatar
2010 30' Classic
Hi Rob
It's difficult to troubleshoot these over the phone.
The water heater does have a high limit switch called an ECO (energy cut off) which, if it has blown for whatever reason, will have to be replaced for the water heater to work. There is no obvious indication that the ECO has blown without using a test meter.
The most frequent reason for the ECO to blow is for the water heater to be fired when there is no water in the tank. This can also cause the electric element to burn out. The ECO and electric element are cheap and straightforward to replace, and are kept in stock by RV repair places since this is a common problem.
You might be best off to stop by the closest shop that offers RV repairs. Even if they aren't accustomed to working on Airstreams, they should be able to help.
Old 04-01-2014, 08:04 AM   #10
Rob
Thank you for the reply and advice. I'm dry camping now and the water heater still is not working. I've got plenty of propane and have now confirmed it doesn't work on either electric or propane. Thanks for defining "ECO" - I've been wondering http://www.airforums.com/forums/imag...lies/smile.gif) Your suggestion to replace the ECO and electric element seem like a good first step; I'll check in the nearest town (Las Cruces, NM) for an RV repair shop and give it a try.
Thank you!
Rob
Old 04-01-2014, 09:30 AM   #11
1972 27' Overlander
Denver , North Carolina
Why not simply bring it back to the dealer. Surely it's got to be under warranty.
Lucky Dave, Denver NC
mccrosti is offline   Reply With Quote
Old 04-02-2014, 01:06 AM   #12
Yes if it is new it can be repaired under warranty
Old 04-03-2014, 09:38 AM   #13
Rob
Thank you for your responses. I'm 1000 miles from my dealer (Windish). Have earliest appointment available (2 weeks) at dealer closest to me. In addition to water heater not working my inverter has also stopped working.
Appreciate all the suggestions.
Best,
Rob
Best,
Rob
Old 04-06-2014, 01:56 PM   #14
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
I'm not sure about the model water heater you have, but on the one I have, there is an inline thermal breaker that will blow if there is any blockage that prevents the propane from firing into the burner tube - this has happened to me when there were spider webs in the burner tube. The breaker looks like a clear plastic tube with a wire through it and it connects from the +12dc supply to the 12 vdc input of the water heater. These breakers are not reusable. One thing I did was to use compressed air to blow any debris out of the burner tube, and I got a face-full of spider webs.
This may be your issue.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
WBCCI 8080
blkmagikca is offline   Reply With Quote
Old 04-06-2014, 02:41 PM   #15
Rob
Thanks blkmagikca,
Mine is an Atwood gas/electric water heater; attached are photos (hope this works; still new at posting on this site). In the photos, I've pointed to two items that might be the thermal breaker you are referring to but am unsure; the manual seems to refer to them as the thermal cut off and the spark probe. Anyway, at this point, I've given up on fixing this myself and look forward to my appointment (4/14) with Holiday Travel in Albuquerque (closest AS dealer).
Thanks for all the advice.
Rob
ID:	209090   Click image for larger version
Old 04-06-2014, 03:47 PM   #16
2008 27' Classic FB
Burkburnett , Texas
Yes, it's the component you're pointing to that is enclosed in the clear tubing. The dealer should have you on your way in short order.
AIR 47751
Old 04-07-2014, 09:48 AM   #17
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
OK - you have identified the thermal breaker (or cut-off), the purpose of which is to prevent a fire in the event of a blockage in the burner tube. The test you need to do is to use a voltmeter - set to measure 15 vdc, and test the voltage across ground to each side of the thermal breaker. If both sides of the thermal breaker show voltage when tested across to ground, then the issue is not the thermal breaker.
If it is the thermal breaker, you need to make sure the burner tube is cleared of spider webs and any obstructions (blowing through it with compressed air worked for me) and replace the thermal breaker - they come in a 2-pack kit for about $40.
VE3JDZ
AIR 12148
WBCCI 8080
Old 04-07-2014, 12:24 PM   #18
1987 31' Excella
Melbourne Bch. , Florida
" water filter sysrem". When replacing a water filter on my 1987 31ft. electra, I cracked (small) the top plastic housing that that filter canister srews into.
A gentleman at home depot suggested I try a 2 part epoxy to seal the crack.
I'd go ahead and buy a whole new unit, however the install looks very challenging giving the extremely close quarters. It looks like there is 3 different galvanized (i think galvanized ) lines coming into the filtering system.
Has anyone ever successfully repaired a cracked water filter housing?
Also, I realize that this may not be the correct place for me to post questions myself. Can anyone direct me to the proper new questions area? Thank you, Billy
dolphin44 is offline   Reply With Quote
Old 04-27-2014, 07:48 PM   #19
Rob
Thanks to everyone who replied to my request for help about my water heater - it is working. Not sure of the problem but most likely operator error. When I brought it to the fine folks at Holiday Travel Trailers in Albuquerque, they indicated it worked fine.
Not sure what the problem was but here is my best guess. When I first started using the trailer in Colorado it was March and very cold and I may not have been patient enough to let the water heater do its job. After awhile I gave up on it thinking it was broken. By the time of my appointment in Albuquerque, a month later, it was considerably warmer. It works fine on electric and propane now.
Thanks again for all your suggestions.
Best,
Rob
Old 04-27-2014, 07:56 PM   #20
Hi Rob,
I also brought my International into service mainly to install solar panels but I asked them to check the water heater also for the electrical and since it was under warranty, they checked and did not find any problem,
You mentioned you gave up and not waited long enough. I also did so not knowing it takes 30-45 mins upon flipping the switch to start the process and heat the elements. It is not instantaneous as propane is.
I learn my lesson and know I have to be patient and schedule the water heater to kick on in a reasonable time.
Water heater/ heater matrix repair montreal Classic Motorhomes 2 06-08-2012 06:00 AM
Bowen water heater door with newer suburban water heater durans54 Water Heaters, Filters & Pumps 37 11-19-2008 07:17 AM
hot water water on demand with a with a normal water heater Frank's Trailer Works Water Heaters, Filters & Pumps 3 09-25-2007 12:24 AM
Repair or Replace Original Bowen Water Heater? Andy R Water Heaters, Filters & Pumps 8 11-16-2005 03:51 PM
Water heater repair Peter&Denise Water Heaters, Filters & Pumps 10 08-04-2005 03:30 PM
